GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
03-02-2010, 20:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | [How to] Read BB5 pm Note: i'm using usb frame , for fbus you can add checksum bytes (2) to the end , change 1B -> 1E For save times i will use same sequence bytes on all frames Good explanation about building fbus frame is here -> 1B 00 10 23 00 06 00 0D 03 0E 01 34 01 34 = hex(308) <- 1B 10 00 23 00 0A 0D 29 03 0F 00 01 03 04 00 04 00 04 = now we know that 308 field has 0004h sub_fields now can start us cycle (0 to 4h) sub_ field 0 -> 1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 00 00 00 <-1B 10 00 23 00 0E 0D 29 04 0D 00 01 06 08 00 00 00 00 00 01 00 01h = len of sub_field data ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 00 00 00 00 00 00 00 00 00 00 01 <-1B 10 00 23 00 16 0D 29 05 05 00 01 00 00 00 00 00 00 00 10 00 00 00 01 01 00 00 00 00 01 h = len 01=data so atm us pm is [308] 0=01 sub_ field 1 -> 1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 01 00 00 <-1B 10 00 23 00 0E 0D 29 04 0D 00 01 06 08 00 00 00 00 10 00 10 00h = len of sub_field data because len is very big we can split reading process for example reading FF bytes to the time: you can calculate how times are needed like this: 1000h / FF = 10h=16dec we read firts ff bytes ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 01 00 00 00 00 00 00 00 00 00 FF <-1B 10 00 23 01 12 0D 29 05 05 00 01 00 00 00 00 00 00 01 0C 00 00 00 FF ................... now we read ff + ff bytes ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 01 00 00 00 00 00 FF 00 00 00 FF <-1B 10 00 23 01 12 0D 29 05 05 00 01 00 00 00 00 00 00 01 0C 00 00 00 FF ................... now we read ff + ff +ff bytes ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 01 00 00 00 00 01 FE 00 00 00 FF <-1B 10 00 23 01 12 0D 29 05 05 00 01 00 00 00 00 00 00 01 0C 00 00 00 FF ................... after 16 times we have < FF bytes to reading 1000h mod FF = 10h ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 01 00 00 00 00 0F F0 00 00 00 10 <-1B 10 00 23 00 22 0D 29 05 05 00 01 00 00 00 00 00 00 00 1C 00 00 00 10 ................. now us pm is: [308] 0=01 1=........................... sub_ field 2 ->1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 02 00 00 <-1B 10 00 23 00 06 0D 29 04 0D 11 00 11 00 = sub_field 2 don't exist sub_ field 3 ->1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 03 00 00->1B 10 00 23 00 0E 0D 29 04 0D 00 01 06 08 00 00 00 00 00 01 ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 03 00 00 00 00 00 00 00 00 00 01 <-1B 10 00 23 00 16 0D 29 05 05 00 01 00 00 00 00 00 00 00 10 00 00 00 01 03 00 00 00 [308] 0=01 1=........................... 3=01 sub_ field 4 ->1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 04 00 00->1B 10 00 23 00 0E 0D 29 04 0D 00 01 06 08 00 00 00 00 00 01 ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 04 00 00 00 00 00 00 00 00 00 01 <-1B 10 00 23 00 16 0D 29 05 05 00 01 00 00 00 00 00 00 00 10 00 00 00 01 07 00 00 00 [308] 0=01 1=........................... 3=01 4=07 us field is now complete ( 4 sub_field readed) can be same errors , i'm not a guru , i'm not a programmer ... but i like read and know next step: write pm please don't ask for source....you can meke it yourself |
The Following 22 Users Say Thank You to fr3nsis For This Useful Post: |
03-02-2010, 23:58 | #3 (permalink) |
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 422015 Status: Offline Thanks Meter: 64 | hi, Thanks, its good knowledge for the beginer like me My question is if i want to read pm via ufs, what should i do: I already do this step 1. make init ufs ------>already done 2. make boot ufs ------>already done 3. make fbus ufs ------>already done 4. make sincronize(55 55 55 55 55 55) ------>already done what next step? br, dhiet Last edited by dhiet; 03-03-2010 at 00:07. |
03-03-2010, 09:52 | #4 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | there is an "error" but i cant edit post here modified post sub_ field 3 ->1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 03 00 00 <-1B 10 00 23 00 0E 0D 29 04 0D 00 01 06 08 00 00 00 00 00 01 ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 03 00 00 00 00 00 00 00 00 00 01 <-1B 10 00 23 00 16 0D 29 05 05 00 01 00 00 00 00 00 00 00 10 00 00 00 01 03 00 00 00 [308] 0=01 1=........................... 3=03 sub_ field 4 ->1B 00 10 23 00 0A 00 0D 04 0C 01 34 00 04 00 00 <-1B 10 00 23 00 0E 0D 29 04 0D 00 01 06 08 00 00 00 00 00 01 ->1B 00 10 23 00 12 00 0D 05 04 01 34 00 04 00 00 00 00 00 00 00 00 00 01 <-1B 10 00 23 00 16 0D 29 05 05 00 01 00 00 00 00 00 00 00 10 00 00 00 01 07 00 00 00 [308] 0=01 1=........................... 3=03 4=07 |
The Following 6 Users Say Thank You to fr3nsis For This Useful Post: |
03-03-2010, 19:36 | #5 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | Video test application (Read&Write PM) http://www.mediafire.com/?ygznnyqznym i have done ... now it's your time |
The Following 2 Users Say Thank You to fr3nsis For This Useful Post: |
03-08-2010, 09:29 | #7 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Romania
Member: 230657 Status: Offline Thanks Meter: 10 | Quote:
05-05-2010, 15:30 | #11 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | in comparing PM's readed via my soft (using this methode) and others readed by MX-Key i found a difference in some fields !! here is the log for the same phone : My soft Code: Field [1] Keys: 25 Key: 0 : 114 Bytes Key: 1 : 4 Bytes Key: 2 : 98 Bytes Key: 4 : 110 Bytes Key: 5 : 4 Bytes Key: 6 : 98 Bytes Key: 8 : 110 Bytes Key: 13 : 98 Bytes Key: 15 : 4 Bytes Key: 16 : 98 Bytes Key: 18 : 98 Bytes Key: 20 : 98 Bytes Key: 22 : 16 Bytes Key: 23 : 4 Bytes Key: 24 : 84 Bytes Field [2] Keys: 2 Key: 0 : 440 Bytes Field [4] Keys: 5 Key: 3 : 10 Bytes Key: 4 : 8 Bytes Field [8] Keys: 9 Key: 0 : 12 Bytes Key: 1 : 12 Bytes Key: 2 : 128 Bytes Key: 3 : 128 Bytes Key: 6 : 4 Bytes Key: 7 : 8 Bytes Key: 8 : 8 Bytes Code: Section: 1 - got 24 key(s) - key: 0, readed 114 bytes - key: 1, readed 4 bytes - key: 2, readed 98 bytes - key: 4, readed 110 bytes - key: 5, readed 4 bytes - key: 6, readed 98 bytes - key: 8, readed 110 bytes - key: 13, readed 98 bytes - key: 15, readed 4 bytes - key: 16, readed 98 bytes - key: 18, readed 98 bytes - key: 20, readed 98 bytes - key: 22, readed 16 bytes - key: 23, readed 4 bytes - key: 24, readed 84 bytes - key: 25, readed 4 bytes - key: 26, readed 110 bytes - key: 27, readed 4 bytes - key: 28, readed 98 bytes - key: 29, readed 10 bytes - key: 31, readed 98 bytes - key: 33, readed 36 bytes - key: 34, readed 80 bytes - key: 44, readed 182 bytes Section: 2 - got 1 key(s) - key: 0, readed 440 bytes Section: 4 - got 4 key(s) - key: 3, readed 10 bytes - key: 4, readed 8 bytes - key: 5, readed 8 bytes - key: 9, readed 5 bytes Section: 8 - got 8 key(s) - key: 0, readed 12 bytes - key: 1, readed 12 bytes - key: 2, readed 128 bytes - key: 3, readed 128 bytes - key: 6, readed 4 bytes - key: 7, readed 8 bytes - key: 8, readed 8 bytes - key: 9, readed 16 bytes my soft : send: 1B 00 10 23 00 06 00 0D 03 0E 00 04 recieve :1B 10 00 23 00 0A 0D 2A 03 0F 00 01 03 04 00 04 MX-Key: send: 1B 00 10 23 00 06 00 08 67 0E 00 04 recieve:1B 10 00 23 00 0A 08 2A 67 0F 00 01 03 04 00 04 04:using this methode I got 0,1,2,3,4 subfields with 03 empty (fake) subfields (0,1,2) But Mx-Key got 04 real subfields so I concluse: 04 is the number of the real keys (not empty data) and before to read them (0,1,2,3,4) we must use another command to get their real positions (3,4,5,9) !! after a few sniff I got It using my example : (section 04) here is the correct way to read subfields : 01/: >>> 1B 00 10 23 00 06 00 0D 03 0E 00 04 <<< 1B 10 00 23 00 0A 0D 2A 03 0F 00 01 03 04 00 04 02/ get the real first position of subfields : >>> 1B 00 10 23 00 0A 00 08 68 0A 00 04 FF FF 00 00 <<< 1B 10 00 23 00 0A 08 2A 68 0B 00 01 03 04 00 03 03 is the first subfield to read and 04 is field number (section) 03/ get the next real postion after 03 >>> 1B 00 10 23 00 0A 00 08 68 0A 00 04 00 03 00 00 <<< 1B 10 00 23 00 0A 08 2A 69 0B 00 01 03 04 00 04 04 is the seconde subfield 04/ >>> 1B 00 10 23 00 0A 00 08 68 0A 00 04 00 04 00 00 <<< 1B 10 00 23 00 0A 08 2A 6A 0B 00 01 03 04 00 05 05 is the third subfield 05/ >>> 1B 00 10 23 00 0A 00 08 68 0A 00 04 00 05 00 00 <<< 1B 10 00 23 00 0A 08 2A 6B 0B 00 01 03 04 00 09 09 is the last real subfield (4th) now we have 4 subfields to read 3 4 5 9 and we can read them using fr3nsis method ./wbr |
05-05-2010, 16:16 | #12 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | yes but with my old codes you can read good subfield , see my first post: after send first command you know that fields are 4 send command for read 0 subfield , len <> 0 -> ok 0 exist with data .... send command for read 1 subfield , len <> 0 -> ok 1 exist with data .... send command for read 2 subfield , len = 0 -> 2 dont exist jump it send command for read 3 subfield , len <> 0 -> ok 3 exist with data .... at the end you have [308] 0= 1= 3= 4= so 4 subfield .... |
05-05-2010, 16:38 | #13 (permalink) | |
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Quote:
07-31-2010, 18:04 | #14 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Amriswil Age: 41
Member: 99073 Status: Offline Thanks Meter: 91 | ?? Code: Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click 'When Tx button clicked 'Clear buffer rxBuff = "" 'If port is closed, then open it If SerialPort1.IsOpen = False Then SerialPort1.Open() ListBox1.Items.Clear() 'Write this data to port 'SerialPort1.Write(ComboBox1.Text & vbCr) SerialPort1.Write(Chr(&H1B) + Chr(&H0) + Chr(&H10) + Chr(&H23) + Chr(&H0) + Chr(&H6) + Chr(&H0) + Chr(&HD) + Chr(&H3) + Chr(&HE) + Chr(&H0) + Chr(&H4)) 'Pause for 800ms System.Threading.Thread.Sleep(800) 'If the port is open, then close it If SerialPort1.IsOpen = True Then SerialPort1.Close() 'If the buffer is still empty then no data. End sub If rxBuff = "" Then MessageBox.Show("NADA FOI RECEBIDO", "SEM DADOS", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1) End If 'Else display the recieved data in the RichTextBox ListBox1.Items.Add(rxBuff) End Sub Im using vb.net and usb cable . Thanks |
07-31-2010, 18:22 | #15 (permalink) |
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | you cant use serial port ...you must open usb connection ps:it's not necessary to read FF bytes to the time ...you can read more |
How to read full PM from dead phone? | Mr.Ultimate | Nokia Hardware & Hardware Repair | 5 | 09-21-2009 14:12 |
How to edit bb5 pm 120? | shimul_777 | Nokia Base Band 5 ( BB-5 ) | 2 | 05-17-2009 18:20 |
how to read full pm for nokia | power cell | HWK | 4 | 11-26-2005 21:46 |
