Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 11-01-2012, 05:51   #1 (permalink)
Member: 67927
Thanks Meter: 108
Samsung MSL Bypass?
Can you please explain what exactly is the MSL in Samsung phones? Examples like bypass/reset MSL is needed to unlock/repair imei on phones. Some phone require it others don't. I know on qualcomm based samsungs the SPC is always 000000 but then what is the MSL reset used for? I though they were the same. Anyway I know many tricks for samsung such as imei repair and unlock in many newer android models but MSL reset on others models is very different.
Examples like i9100/i9000/i927 require bypass msl after rewrite nv_data.bin with desired imei in order to repair the IMEI, and others models like i997 only require to rewrite nv_data.bin.
The Following 2 Users Say Thank You to dest For This Useful Post:
Old 11-02-2012, 09:04   #2 (permalink)
Member: 1111849
Thanks Meter: 17
You already answered yourself.
The main part of MSL is work with security flag to get access to hidden NVM units or to some additional service in AT commands.
Broadcom example:
AT+MSLADDSNUM, AT+MSLSECUR, AT+SECUNBLOCK
Qualcomm diagnostic example:
0xFA, 0xB4, 0XB5
But there many algorithms of MSL so no way to explain all of them
The Following User Says Thank You to kr0m For This Useful Post:
Old 11-03-2012, 05:21   #3 (permalink)
Member: 67927
Thanks Meter: 108
thank you for the answer. Can you explain one way of reset msl on android? I noticed they don't use the modem but ADB with root privilege. Would the bml3/stl3 partition contain this? I am not sure if you are familiar with CDMA QCM, but is the msl almost the same as the SPC?
Old 08-27-2015, 22:50   #4 (permalink)
Member: 416710
Thanks Meter: 391
Broadcom example:
0xFA, 0xB4, 0XB5
Reopen thread cause need send msl to a samsung with qsc62xx I tried default AT+MSLSECUR=2,222222 but not work. Its there a way to calc for this cpu?
Old 08-28-2015, 13:31   #5 (permalink)
Member: 2076039
Thanks Meter: 648
Isn't 222222 the default SPC for Sprint Samsung CDMA phones? I thought the MSL was a much longer string...?
Old 08-28-2015, 17:35   #6 (permalink)
Member: 1808628
Thanks Meter: 26
To bypass spc on Sprint is very simple
AT+MEIDAUTH=0,0,2012112120131219
AT+MEIDAUTH=1,0,0
AT+MEIDAUTH=0,1,[SPC]
then you can do wherever you want because this model no need akseedno
SPC= 6 digits
Old 08-29-2015, 06:40   #7 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
AT+MEIDAUTH=1,0,0
SPC= 6 digits
HELLO
FEW MODEL HAVE DIFFRENT SP LIKE L710T and other check google for it all posted on various forum
Old 08-29-2015, 12:46   #8 (permalink)
Member: 416710
Thanks Meter: 391
Originally Posted by DYNET View Post
HELLO
Yes Some old phone have diferent passwords. But main problem here I never said is an sprint phone. I have an gsm qualcomm samsung and testing some thing to learn.
Old 08-29-2015, 20:46   #9 (permalink)
Member: 416710
Thanks Meter: 391
Ohh its a non android devices. I just want test imei write on this phone..
Old 08-30-2015, 16:13   #10 (permalink)
Member: 416710
Thanks Meter: 391
Ohh I forgot write msl address, I reset it with z3x but maybe dont work and have original one yet.
Page generated in 0.14410 seconds with 8 queries
