Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola CDMA
Motorola CDMA here all threads Related to Motorola CDMA Hardware Servicing and Repairing.
Old 02-20-2011, 14:36   #1 (permalink)
Registered User
Member: 804452
Thanks Meter: 249
motorola Q (tata base) only boot mode show
any solution this modal pls post ya send this id [email protected]
Hariom
Old 02-20-2011, 18:07   #2 (permalink)
kumar_gsm_kumar's Avatar
Member: 230569
Sonork: 1608865
Thanks Meter: 271
Hariom
without battery
To perform a hard reset, hold down the center select key (s) for
5 seconds while turning the phone on.
your problem solf
hariom
ok.......
The Following User Says Thank You to kumar_gsm_kumar For This Useful Post:
Old 02-21-2011, 08:22   #3 (permalink)
Registered User
Member: 804452
Thanks Meter: 249
confuse me this solution pls any pic
Hariom
Old 02-21-2011, 11:50   #4 (permalink)
Member: 230569
Sonork: 1608865
Thanks Meter: 271
here pic .............
Old 03-03-2011, 10:44   #5 (permalink)
Registered User
Member: 804452
Thanks Meter: 249
This recipe will explain how to do a true master/hard reset and wipe all device data, restoring it to factory defaults/state.
1. Be sure to have atleast 75% battery on your Motorola Q
2. Be sure that you have backed up all data on the device since this will wipe the device clean
3. Power off the Motorola Q
4. Power on the Motorola Q
5. Once you see the initial carrier screen, hold the center button on the navigation pad.
6. Keep it held until you get a “Master Reset?” screen.
7. Click the left softkey for “Yes” and the phone will wipe and reload the OS from ROM
BE SURE NOT TO REMOVE THE BATTERY WHEN YOU DO THIS or you may ‘brick’ your phone.
Hariom
The Following User Says Thank You to Hariom123 For This Useful Post:
Old 03-03-2011, 14:11   #6 (permalink)
MOHIT_THAREJA's Avatar
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
Hariom
good information hariom sir..............
Old 03-04-2011, 09:59   #7 (permalink)
baba_sandeep's Avatar
Member: 931438
Sonork: 1614828
Thanks Meter: 26
nice job
[QUOTE=Hariom123;7026078]This recipe will explain how to do a true master/hard reset and wipe all device data, restoring it to factory defaults/state.
thank u sir
Old 03-04-2011, 10:05   #8 (permalink)
Member: 931438
Sonork: 1614828
Thanks Meter: 26
nice job
thank u sir
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 09:41
I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! MC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-14-1999 13:02
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.18224 seconds with 10 queries
