12-02-2013, 08:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 682988 Status: Offline Thanks Meter: 45 | SIM NOT VALID on an FACTORY UNLOCKED Iphone 5 I have just unlocked (bought a code), the server that I use gave me unlock done. Even check of this Iphone 5, the status changed to UNLOCKED. But when I tried to unlock it with Itunes or Wifi, I get SIM NOT VALID! What's the problem??? I am really confused!!! I have also an Ihpone 4 in the same situation!!! Thanks! |
12-03-2013, 03:16 | #7 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1870114 Status: Offline Thanks Meter: 4 | Most Common iPhone No Service Errors and How To Fix Them (the best one is the last method : The full restore but leave it at the end because it is time consuming) 1. The easiest method, and I can confirm that it works in most cases, to reset network settings: Insert unsupported Sim card, open Settings on iPhone, go to General -> Reset -> Reset Network Settings. 2. In Setting you will see AirPlane mode which you can also use to fix No Service on iPhone as well: Insert Sim card and turn on/off Airplane mode several time while it will pick the signal. 3. Also while your iPhone is on, pop the Sim card out and turn off the power. Insert Sim card and turn iPhone On. Or, turn iPhone on, pop up the Sim card, turn iPhone on and insert Sim card. It worked for many. 4. Go to Settings – General – Cellular/Network and turn on Cellular Data, Enable 3G, Data Roaming and wait for the signal. If they already on – turn it off and wait for the signal. Note: Some say that you need just reboot iPhone holding two buttons and you will get service. 5. No Service iPhone problem can be after activating and deactivating iPhone using just app as SAMPrefs (SAM unlock tool) or Redsn0w. In this case follow steps in method 6. 6. If methods above don’t work to fix No Service on iPhone, you can try the third method which is the best because it works in 90% cases: 1). Insert non-valid Sim card in iPhone and connect it to iTunes using USB. 2). When iTunes detects your device perform a backup and after backup just click Restore. 3). Wait till the program finish restore and you will see two options in iTunes: Restore from a backup; Set up iPhone as a new phone. so choose Set up as a new. |
12-04-2013, 23:48 | #8 (permalink) |
Member: 682988 Status: Offline Thanks Meter: 45 | Finaly UNLOCKED! I just give a try this morning and it's done! 7-10 days after unlock via server. So the SOLUTION was: TO WAIT! Maybe Apple server problem?! Thank you evrybody! |
12-06-2013, 05:47 | #9 (permalink) |
Member: 1870114 Status: Offline Thanks Meter: 4 | I don't think "wait" was the solution. if the lock status shows unlocked it means unlocked you just was not lucky at the first try that' it . now you have it working so enjoy |
The Following User Says Thank You to adlezz For This Useful Post: |
12-15-2013, 21:10 | #11 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Gujrat Age: 31
Member: 1912761 Status: Offline Sonork: 100.1650678 Thanks Meter: 105 | Check the status of you imei is unlocked, then complain to your service provider, But i am sure its not factory unlocked, its carrier has been converted to : Unassigned factory defaults, apple carriers only. IMEI: 013403009418154 Serial: C35JMBVKDTWF Model: iPhone 5 (GSM/LTE135/International) White 16GB Warranty: Out of Warranty Warranty Start Date: N/A Warranty End Date: N/A Activation Status: Yes Locked By Carrier: Unassigned factory default - Apple carriers only. SIM Swap triggers rebricking Find My iPhone: OFF Sim Lock: Locked I had the same problem with my *******r. |
