Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 12-02-2013, 08:58   #1 (permalink)
Member: 682988
Thanks Meter: 45
Angry SIM NOT VALID on an FACTORY UNLOCKED Iphone 5
Dears,
I have just unlocked (bought a code), the server that I use gave me unlock done. Even check of this Iphone 5, the status changed to UNLOCKED.
But when I tried to unlock it with Itunes or Wifi, I get SIM NOT VALID!
What's the problem??? I am really confused!!! I have also an Ihpone 4 in the same situation!!!
Thanks!
Old 12-02-2013, 12:00   #2 (permalink)
Member: 1520741
Sonork: zboubdepanda
Thanks Meter: 72
connect it to itunes with invalid simcard .... if same issue restore it and activ your iphone with your sim card
Old 12-02-2013, 12:22   #3 (permalink)
ASHIF's Avatar
Member: 8353
Sonork: 113276
Thanks Meter: 335
reflash new firmware and reactivate it
Old 12-02-2013, 23:12   #4 (permalink)
Member: 682988
Thanks Meter: 45
Reflashed to 7.0.4, tried to unlock/activate with Itunes/Wifi, same thing!
Really strange problem!!!
sugestions please?
Old 12-02-2013, 23:32   #5 (permalink)
Crazy Poster
Member: 1957167
Thanks Meter: 6
just reset network setting
that sh0uld solve ur problem
Old 12-02-2013, 23:43   #6 (permalink)
Member: 682988
Thanks Meter: 45
I just give a try, "reset network settings", even delete and reset all data... and I am ready to try any solution!
Thanks anyway!
Old 12-03-2013, 03:16   #7 (permalink)
Member: 1870114
Thanks Meter: 4
Most Common iPhone No Service Errors and How To Fix Them (the best one is the last method : The full restore but leave it at the end because it is time consuming)
1. The easiest method, and I can confirm that it works in most cases, to reset network settings:
Insert unsupported Sim card, open Settings on iPhone, go to General -> Reset -> Reset Network Settings.
2. In Setting you will see AirPlane mode which you can also use to fix No Service on iPhone as well:
Insert Sim card and turn on/off Airplane mode several time while it will pick the signal.
3. Also while your iPhone is on, pop the Sim card out and turn off the power. Insert Sim card and turn iPhone On. Or, turn iPhone on, pop up the Sim card, turn iPhone on and insert Sim card. It worked for many.
4. Go to Settings – General – Cellular/Network and turn on Cellular Data, Enable 3G, Data Roaming and wait for the signal. If they already on – turn it off and wait for the signal.
Note: Some say that you need just reboot iPhone holding two buttons and you will get service.
5. No Service iPhone problem can be after activating and deactivating iPhone using just app as SAMPrefs (SAM unlock tool) or Redsn0w. In this case follow steps in method 6.
6. If methods above don’t work to fix No Service on iPhone, you can try the third method which is the best because it works in 90% cases:
1). Insert non-valid Sim card in iPhone and connect it to iTunes using USB.
2). When iTunes detects your device perform a backup and after backup just click Restore.
3). Wait till the program finish restore and you will see two options in iTunes:
Restore from a backup;
Set up iPhone as a new phone.
so choose Set up as a new.
Old 12-04-2013, 23:48   #8 (permalink)
Member: 682988
Thanks Meter: 45
Finaly UNLOCKED! I just give a try this morning and it's done!
7-10 days after unlock via server.
So the SOLUTION was: TO WAIT! Maybe Apple server problem?!
Thank you evrybody!
Old 12-06-2013, 05:47   #9 (permalink)
Member: 1870114
Thanks Meter: 4
Thank you evrybody!
I don't think "wait" was the solution. if the lock status shows unlocked it means unlocked you just was not lucky at the first try that' it . now you have it working so enjoy
The Following User Says Thank You to adlezz For This Useful Post:
Old 12-13-2013, 23:00   #10 (permalink)
Member: 1973965
Thanks Meter: 6
dogeatdog,
Can you please post where you got your iphone unlocked? Thanks.
Old 12-15-2013, 21:10   #11 (permalink)
Member: 1912761
Sonork: 100.1650678
Thanks Meter: 105
Check the status of you imei is unlocked, then complain to your service provider, But i am sure its not factory unlocked, its carrier has been converted to : Unassigned factory defaults, apple carriers only.
IMEI: 013403009418154
Serial: C35JMBVKDTWF
Model: iPhone 5 (GSM/LTE135/International) White 16GB
Warranty: Out of Warranty
Warranty Start Date: N/A
Warranty End Date: N/A
Activation Status: Yes
Locked By Carrier: Unassigned factory default - Apple carriers only. SIM Swap triggers rebricking
Find My iPhone: OFF
Sim Lock: Locked
I had the same problem with my *******r.
Page generated in 0.22282 seconds with 8 queries
