12-07-2009, 22:36 | #47 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Cracow
Member: 739941 Status: Offline Thanks Meter: 111 | PEOPLE!!!!!! NOW IF YOU HAVE NEW IPHONE 3GS (WITH NEW BOOTROM) WHEN YOU USE Blackra1n FOR THE UNLOCK YOU ALWAYS HAVE GOT RECOVERY MODE AFTER REBOOT !!!! FOR NOW NO SOLUTION!!!!! (you can use Blackra1n once again, your iphone will be activated, but when you reboot it, it will be blocked again) |
12-13-2009, 15:11 | #51 (permalink) |
Freak Poster Join Date: May 2006 Location: Addis Ababa
Member: 279453 Status: Offline Thanks Meter: 29 | still waiting for a solution on the new boot. i think now its concerning many people i was one of the first to in counter the problem. And the holidays are coming that means many new iboot iphone will be in the market. |
12-14-2009, 03:02 | #54 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | just connect iphone 3gs to computer and run blacksn0w and all ok until u turn off phone or reboot, then do it again and again until new hack is available, ... wait days or months ... |
The Following User Says Thank You to mrfixit For This Useful Post: |
12-14-2009, 06:16 | #55 (permalink) | |
Junior Member Join Date: Jun 2008
Member: 796992 Status: Offline Thanks Meter: 6 | Quote:
Don't make that statement...that is not true...I just unlocked a 44 serial number without any problems... You do have to do connect to the computer to reboot your phone if you ever need to or if your battery runs down. If you consider that a problem then that is a different story but serial 44 isn't a problem to unlock or jailbreak. I just did it. Follow the tutorial, Make sure you are actually connected to a wifi network (mine said it was connected and it wasn't) and then download and install Cydia, Rock, & Snow and you should have no issues at all. Make sure you change your /root password once you get into your phone | |
12-16-2009, 20:25 | #57 (permalink) |
Freak Poster Join Date: Oct 2008 Location: dominican republic
Member: 874313 Status: Offline Sonork: polocell Thanks Meter: 37 | same issue with 3gs after run blackrain i was trying to restore with custom firmware but stuck in dfu mode any solution?please help.... |
12-17-2009, 14:40 | #58 (permalink) |
Freak Poster Join Date: Aug 2006 Location: INdia
Member: 335008 Status: Offline Thanks Meter: 57 | For me Having 3G's ....Same Problem With Me... As I tried All Way... Everything Is going ok..bot not working...still the same problem Here Is Log C:\I>irecovery -s iRecovery - Recovery Utility by wEsTbAeR-- and Tom3q Got USB ======================================= :: :: iBoot for n88ap, Copyright 2009, Apple Inc. :: :: BUILD_TAG: iBoot-636.66 :: :: BUILD_STYLE: RELEASE :: :: USB_SERIAL_NUMBER: CPID:8920 CPRV:15 CPFM:03 SCEP:03 BDID:00 ECID:00000 343A12038D IBFL:01 SRNM:[87942G443NQ] :: ======================================= [FTL:MSG] Apple NAND Driver (AND) RO [NAND] Found Chip ID 0x3E94D72C84 on FMI0:CE0 [NAND] Found Chip ID 0x3E94D72C84 on FMI0:CE1 [NAND] Found Chip ID 0x3E94D72C84 on FMI1:C8 [NAND] Found Chip ID 0x3E94D72C84 on FMI1:CE9 [FTL:MSG] FIL_Init [OK] [FTL:MSG] BUF_Init [OK] [FTL:MSG] FPart Init [OK] read new style signature 0x43313133 (line:375) [FTL:MSG] VSVFL Register [OK] [FTL:MSG] VFL Init [OK] [FTL:MSG] VFL_Open [OK] [FTL:MSG] YAFTL Register [OK] yaFTL::YAFTL_Open(l:2630): CXT is not valid . Performing full NAND R/O restore .. [FTL:MSG] FTL_Open [OK] Boot Failure Count: 2 Panic Fail Cout: 0 Delaying boot for 0 seconds. Hit enter to break into the command prompt... HFSInitPartition: 0x4fafeb40 Kernelcache image not valid Entering recovery mode, starting command prompt (Recovery) iPhone$ setenv auto-boot true (Recovery) iPhone$ saveenv (Recovery) iPhone$ /exit Closing USB connection... |
12-17-2009, 21:03 | #59 (permalink) |
Member: 739941 Status: Offline Thanks Meter: 111 | Tell me what dou have when you type 'help' My Iphone don't answer eny command :/ Only workt "reboot" - iphone is restarting I don't know what is wrong with connection with PC <-> Iphone |
Without problem "ALWAYZ recovery mode after reboot with Blackra1n" | anpha72000 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-27-2010 10:16 |
Recovery mode after reboot | coeugh | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 01-07-2010 01:03 |
3GS stuck in recovery mode after power on | leebok | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 12-06-2009 17:12 |
After jailbreakin iphone 3GS still in recovery mode | xpcenter | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-11-2009 06:50 |
