Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 07-10-2009, 13:19   #1 (permalink)
recepoz's Avatar
Member: 167500
Thanks Meter: 16
iphone 3g downgrade from 3.0 to 2.2.1 itunes error
Hi to everyone.
I have an iPhone 3g with this fw iPhone1,2_3.0_7A341_Restore. I want to downgrade it to iPhone1,2_2.2.1_5H11_Restore.
I am putting the phone in dfu mode and try to restore it from itunes (7.5.0.20) with shift restore after a while i get error in the image
[IMG][/IMG]
In the dfu mode itunes shows the device as ipod.
Is there anyone who can help me?
Old 07-10-2009, 13:24   #2 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I'm 99% sure you can't downgrade your iphone to this version,be careful or you'll damage your phone
Old 07-10-2009, 13:38   #3 (permalink)
arybraga's Avatar
Member: 837940
Sonork: 83906941
Thanks Meter: 48
Indeed, with its attempt you will permanently damage your iphone, as it is with your 3.0 will be better.
Old 07-10-2009, 13:38   #4 (permalink)
recepoz's Avatar
Member: 167500
Thanks Meter: 16
I also can not restore it to its original fw which is iPhone1,2_3.0_7A341_Restore it gives the same error.
Old 07-10-2009, 14:31   #5 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
3G with OS3 cannot be downgraded? I had 2.2.1 with wifi ok, now after update no wifi with OS3. Iphone is 16GB. I get similar errors while trying to downgrade. Any downgrade guide that has been tested ?
Thanks
Old 07-10-2009, 14:38   #6 (permalink)
MUNEEB_AKHTAR_RAZA's Avatar
Member: 152244
Sonork: 100.1591179
Thanks Meter: 162
Originally Posted by recepoz View Post
Hi to everyone.
You r using old version of itunes which not support 3G phones so download latest 8.2.023 for updating your iphone!
Old 07-10-2009, 15:30   #7 (permalink)
.:==di@bila==:.'s Avatar
Member: 254137
Sonork: 1592525
Thanks Meter: 275
Update iTunes then restore, will be ok
Old 07-10-2009, 16:35   #8 (permalink)
Member: 1071736
Sonork: n/a
3g Upgrade Error/ dilema
I unlocked my iPhone 3G couple of months ago. Worked very well!
Decided to upgrade to FW3.0. NOW, Phone is locked; can't jailbreak; lost ALL applications except making and recieving calls. HELP!!!! HELP!!!! How do I restore the APPLICATIONS on the phone.
Old 07-10-2009, 16:49   #9 (permalink)
Registered User
Member: 310695
Thanks Meter: 26
Smile
Itune 7.5 support Iphone 2G but Itune 8.2.023 support version 3.x!!
Restore Iphone 3G FW 2.x use Itune 8.1!!!!
Good luck
Old 07-10-2009, 16:50   #10 (permalink)
lypen17's Avatar
Member: 44223
Thanks Meter: 20
dont upgrade to v3.0 and dont try to downgrade back after you allready upgradet to v3.0 .............
Old 07-10-2009, 17:47   #11 (permalink)
bootgsm's Avatar
Member: 527800
Thanks Meter: 234
i have the same problem the error is microprogram is not compatible
Old 07-10-2009, 18:22   #12 (permalink)
recepoz's Avatar
Member: 167500
Thanks Meter: 16
I have installed the new version of itunes and i can restore it with the same fw. Actually my problem was the phone could not find any network and in the settings there is no such a menu like choosing or searching for carriers. Is there any solution for the network problem? without downgrading. Thanks for replies.
Old 07-11-2009, 09:14   #13 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 507
Try to use itunes 8.0.2.20 and restore your phone if it gives error just keep your phone plugged to your pc for 1 hour and again try to restore it will be done without any problem as far as i have seen the version 3.0 both for 3g and 2g are a bit buggy and the previous versions are much better than it i have personally downgraded my 2g and 3g to 2.2 successfully try and post result.
Old 07-11-2009, 15:57   #14 (permalink)
recepoz's Avatar
Member: 167500
Thanks Meter: 16
Thanks for the reply but it did not work.. It gives error 1600.thx
Old 07-11-2009, 16:31   #15 (permalink)
Member: 711402
Sonork: 100.1580671
Thanks Meter: 656
Hi to everyone.
[IMG][/IMG]
chk here
http://forum.gsmhosting.com/vbb/show...00#post4647500
Can i restore iphone 3G firmeare from 3.1 to 3.0 kamransohail786 iPhone 2 / iPhone 3G / iPhone 3GS 4 10-06-2009 20:22
how to downgrade from 3.0 to 2.2 kissssna iPhone 2 / iPhone 3G / iPhone 3GS 16 07-19-2009 07:24
iPhone Downgrade Firmware 3.0 to 2.2.1 zeeshanawan iPhone 2 / iPhone 3G / iPhone 3GS 25 07-17-2009 18:26
How to Jailbreak Your iPhone 3G on OS 3.0 Using PwnageTool (Mac) zahid_gsm iPhone 2 / iPhone 3G / iPhone 3GS 0 06-19-2009 19:28
Page generated in 0.24000 seconds with 9 queries
