11-06-2009, 15:01 | #1 (permalink) |
Banned Join Date: Feb 2005 Location: www.S y r i a 4 S o f t .Com
Member: 112281 Status: Offline Thanks Meter: 1,385 | iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware Blackra1n RC3 with blacksn0w unlocks iPhone 3G and 3GS running on iPhone 3.1.2 firmware with 05.11.07 baseband. But like most other tools, it comes with its share of problems as well. There are problems with WiFi, Youtube and GPS not working when jailbreaking iPhone 3G/3GS with blackra1n RC3, and unlocking with blacksn0w on iPhone 3.1.2 firmware. Fix1 Reset Network Settings This fix comes right from geohot himself. Those of you who are having issues with WiFi failing to connect to a nearby hotspot or network should reset your network settings by following three simple steps. Step 1: On your iPhone 3G and 3GS, navigate to Settings –> General –> Reset –> Reset Network Settings. Step 2: A dialog will prompt you with “Reset Network Settings” button. Step 3: Hit this button and turn off your iPhone by holding down power button on the top and then slide to turn off your phone. Now turn on your iPhone by holding down the power button on the top again until you see the Apple logo. Resetting your network setting will fix your WiFi problem temporarily. The problem will come back once you have rebooted your iPhone again. You will have to reset your network settings pretty much every time you reboot your iPhone. Fix 2 Install Push Fix App Push Fix app from Cydia is used to fix Push Notifications on hacktivated iPhone 3.1.x firmware. Installing this app also fixes all issues caused by blacksn0w related to WiFi, Youtube app and GPS along with Push Notifications on hacktivated iPhone’s. Follow the steps below to install Push Fix app: Step 1: First reset your network settings as mentioned in Fix 1 above to bring back WiFi temporarily. We need WiFi to install Push Fix app from Cydia. Step 2: Now start “Cydia” on your iPhone. Touch on “Manage” tab on the bottom and then on “Sources” Step 3: Touch on “Edit” and then on “Add”. You will be prompted to enter a url source as seen in the screenshot below. Type “http://cydia.iphoneil.net” and touch on “Add Source”. Cydia will now automatically update your sources by following a series of automated steps. Step 4: After installation is completed. Search for “Push Fix” in Cydia and install this application. This app will automatically fix Push Notification System on your unlocked and jailbroken iPhone. Install Push Fix App Step 5: Restart you iPhone. |
The Following 12 Users Say Thank You to HZZORY4GSM For This Useful Post: |
11-06-2009, 17:24 | #4 (permalink) |
No Life Poster Join Date: Sep 2005 Location: The Netherlands Antilles Age: 50
Member: 179391 Status: Offline Thanks Meter: 57 | In have done few 3G iPhones using blackra1n RC3 for jailbrake and unlock. I did not get any network problem at all. But only 1 device was showing "Cannot connect to youtube" I have follow Fix 2 and my problem resolved! Great work...! |
The Following User Says Thank You to Black_Daimond For This Useful Post: |
11-07-2009, 00:53 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Still no solution for me. I tried all the Reset ways posted and running blackra1n 2 or 3 times but the same: I tried this on almost 6 different iPhones 3G and 3GS till now, but no chance for me to install Cydia nor any other app from Rock on them!!! I tried also Installing Cydia without installing blacksnow, immediately after blackra1n, but sometimes it takes ages to download it - but never succeeds |
The Following User Says Thank You to byteforce For This Useful Post: |
11-09-2009, 04:58 | #12 (permalink) |
Junior Member Join Date: Sep 2005 Age: 39
Member: 185352 Status: Offline Thanks Meter: 19 | You could try this: http://forum.gsmhosting.com/vbb/showthread.php?t=856023 It fixes all the issues currently with blackra1n Jailbreak, including WiFi signal and Push notifications. |
11-09-2009, 08:43 | #13 (permalink) |
Freak Poster Join Date: Mar 2005 Location: INDIA Age: 48
Member: 125065 Status: Offline Thanks Meter: 36 | just add this source http://fishbone.ge in cydia and install push notification fix .100% solved |
The Following 5 Users Say Thank You to sandeep928 For This Useful Post: |
11-12-2009, 10:45 | #14 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Hoogeveen Age: 36
Member: 82928 Status: Offline Thanks Meter: 17 | Quote:
Thank you this works great !! | |
iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware 100% ok | sandeep928 | iPhone 2 / iPhone 3G / iPhone 3GS | 21 | 07-24-2010 14:27 |
Finally Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware | ..::Waqar::.. | iPhone 2 / iPhone 3G / iPhone 3GS | 14 | 12-04-2009 07:05 |
iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware | sandeep928 | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-08-2009 17:00 |
