11-07-2009, 12:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | Finally Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware How to: Jailbreak & Unlock iPhone 3.1.2 Firmware with blackra1n RC3 (with blacksn0w) Please refer to the guide posted here to unlock, and here to jailbreak your iPhone 3G and 3GS on 3.1.2 firmware. Fix #1: Reset Network Settings This fix comes right from geohot himself. Those of you who are having issues with WiFi failing to connect to a nearby hotspot or network should reset your network settings by following three simple steps. Step 1: On your iPhone 3G and 3GS, navigate to Settings –> General –> Reset –> Reset Network Settings. Step 2: A dialog will prompt you with “Reset Network Settings” button as shown in the screenshot below. Step 3: Hit this button and turn off your iPhone by holding down power button on the top and then slide to turn off your phone. Now turn on your iPhone by holding down the power button on the top again until you see the Apple logo. Resetting your network setting will fix your WiFi problem temporarily. The problem will come back once you have rebooted your iPhone again. You will have to reset your network settings pretty much every time you reboot your iPhone. Fix #2: Install Push Fix App Push Fix app from Cydia is used to fix Push Notifications on hacktivated iPhone 3.1.x firmware. I found out that installing this app also fixes all issues caused by blacksn0w related to WiFi, Youtube app and GPS along with Push Notifications on hacktivated iPhone’s. Follow the steps below to install Push Fix app: Step 1: First reset your network settings as mentioned in Fix #1 above to bring back WiFi temporarily. We need WiFi to install Push Fix app from Cydia. Step 2: Now start “Cydia” on your iPhone. Touch on “Manage” tab on the bottom and then on “Sources” as seen in the screenshot below: Step 3: Touch on “Edit” and then on “Add”. You will be prompted to enter a url source as seen in the screenshot below. Type “http://cydia.iphoneil.net” and touch on “Add Source”. Cydia will now automatically update your sources by following a series of automated steps. Step 4: After installation is completed. Search for “Push Fix” in Cydia and install this application. This app will automatically fix Push Notification System on your unlocked and jailbroken iPhone. Step 5: Restart you iPhone. Credit for Fix #2 goes to our reader Keneth_C. It should fix all issues related to WiFi, Youtube and GPS which some of you might have encountered when unlocking your iPhone with blacksn0w. BR. Waqar |
The Following 10 Users Say Thank You to ..::Waqar::.. For This Useful Post: |
11-12-2009, 23:43 | #4 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: SPAIN
Member: 352041 Status: Offline Thanks Meter: 52 | Quote:
hi bro i just click reset network setting then mobile reboot and go to recovery mode...is it possible..i have 3gs 32gb....i think it is new room ,i always got the recovery mode problem.after unlock when change sim card ,then also got in recovery mode..help if u have the solution this problem.thxs in advance...ikrash | |
11-22-2009, 12:00 | #7 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | This solution is not working for me! I instaled push fix and restarted iphone, but still cant connect to youtube? Any other idea? |
12-03-2009, 18:09 | #13 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 666861 Status: Offline Thanks Meter: 19 | [ Step 3: Hit this button and turn off your iPhone by holding down power button on the top and then slide to turn off your phone. Now turn on your iPhone by holding down the power button on the top again until you see the Apple logo. [/QUOTE] WHEN I HIT THIS BUTTON IPHONE WILL START AUTOMATICALLY BUT STILL NO WIFI FIXED. |
iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware 100% ok | sandeep928 | iPhone 2 / iPhone 3G / iPhone 3GS | 21 | 07-24-2010 14:27 |
iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware | HZZORY4GSM | iPhone 2 / iPhone 3G / iPhone 3GS | 19 | 07-23-2010 23:00 |
iPhone – Fix blacksn0w WiFi Youtube GPS Problem on iPhone 3.1.2 Firmware | sandeep928 | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-08-2009 17:00 |
