[Warning] New iPhone 3GS 8GB Hardware Do not unlock with iPad Baseband [Warning] Apple has released a brand new iPhone 3GS that have a new bootroom this 28 weeks of 2011. Version is 4.3.5 with baseband 5.14. A lot of jailbreakers and unlockers have encountered that when you update this baseband to 6.15 to unlock it, You got corrupted baseband and it cannot used anymore. Symptoms are: No wifi No ECID No Imei No bluetooth as of now all informations i've got is all serial up to XXX109XXX is risky to update baseband. XX109XX = 1 is the year of 2011 and 09 is week 9 of 1 year. so if serial is XX931XXX means 2009 with week 31. and its safe to update baseband. Much better check the serial first before you update to baseband 6.15 http://i670.photobucket.com/albums/v...igXX128XXX.png THANX FOR EVERY ONE WORKS ON THIS INFO..And be carful. BR Niad |
i forget to say.. since iPhone 3Gs 8Gb are equipped with a Toshiba chip. The upgrade to a ipad baseband (06.15.00) make it unusable. Result = imei/Bluetooth/Wifi :mad::mad::confused: The only supported baseband is Qualcomm chip! press thanks if u see this IFO useful for u:) |
1 Attachment(s) Thread sticky i hope this help all. i can confirm this information is correct. update/edit: its seems its very hot stuff i have mad small utility to check serial number. please test and post results.. software is attached. warning recode set to 201125 any release after or same will show warning. Regards:Chevli |
Thread now is stuck, very interesting and hope it help some members.;) |
This is VERY usefull info!! Good that this thread is sticky, so other people can be aware about this. Also thanks for the little software. Nice post bro. |
according to very useful tool posted by stanner austin both 3gs and 3g are in this category or just 3gs only please confirm and according to first post of this thread starting from 09 week of 2011 is risky but according to software above 25th week please confirm both questions |
but small credits from where you got this information is much be appreciated...:D whiteshome Be aware of new iphone 3gs (update) |
Only for info 3g cannot be affected by this problem due to production of 3g are stopped time ago last firmware is 4.2.1 so don't ask if 3g also only 3gs. |
1 Attachment(s) Quote:
Thanx Sir, It means i can update ipad baseband n unlock ? as i have 4.1 n bb 5.14 which is not unlockable BR |
I THINK IF U WANT RESTOR UR DEVICE DO IT BY CUSTOM FRIMWaRE |
I kill 1 today with imei 01276xxxxxxxxxxxx. Any way to repair via software? |
The answer is just check out the software made "Stanner" posted in 2nd post ;) Hope that will help you :) |
I have two phones that received under these conditions, any solution? |
thanks for the info it so usefull |
