04-16-2015, 05:32 | #16 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Quote:
Check this Oficial Thread http://forum.gsmhosting.com/vbb/f311...l#post10440693 Best Regard aUTo | |
04-16-2015, 07:07 | #17 (permalink) |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | Check "Samsung android info". All information is there. http://forum.gsmhosting.com/vbb/f863...2/#post9621105 |
04-16-2015, 07:18 | #18 (permalink) | |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Quote:
04-18-2015, 03:41 | #22 (permalink) |
Banned Join Date: Mar 2015
Member: 2371548 Status: Offline Thanks Meter: 27 | So basically all you need to do is root the phone then patch the MSL then write cert via UART? and to unlock you just root phone then patch MSL and software will reset unlock codes to 12345678? Is that correct? |
04-18-2015, 05:43 | #23 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | NOT NEED to write cert ! only: root phone, backup efs, to be sure can do back to original, patch MSL, and unlock need use original UFST cable and select RJ45 in modem port box |
04-18-2015, 05:55 | #26 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | have step by step documment here: Galaxy S6 how to do full procedure with root, backup, unlock, etc. |
04-18-2015, 08:41 | #27 (permalink) | |
Member: 2371548 Status: Offline Thanks Meter: 27 | Quote:
The Update text includes:\ Galaxy S6 with CP=SS333 Certificate write (Need have Certificate from 3rd sources) So when you need to write cert you just root phone then patch MSL then write cert via UART? | |
04-18-2015, 08:45 | #28 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | I am confused. why would write cert option only apply to restoring original IMEI. After you patch/bypass MSL you would be able to write any cert not just original cert. Restoring original IMEI can be done by writing EFS back to phone without any need for a cert. This is the same process that many people are not aware about that is used on the note 3. That is patching the msl so you can do direct unlock. Also, when you patch msl that allows you to write cert without wiping efs first. Last edited by iowahawk; 04-18-2015 at 08:54. |
04-18-2015, 09:00 | #29 (permalink) |
Member: 2371548 Status: Offline Thanks Meter: 27 | I dont know if you are saying that to protect yourself legally because i am aware it is illegal in most countries to change IMEI. However, it is not in my country. I just need to know if you can write any compatible cert to the phone as it suggests in the update text. |
04-18-2015, 13:46 | #30 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
Man can you read ?? UNLOCK NOT CHANGE IMEI THIS SHA WRITE WHAT MORE YOU NEED TO WRITE YOU TO UNDERSTAND ? READ CERTIFICATE NOT AVALIBLE RIGHT NOW ON S6. | |
