02-13-2017, 17:24 | #692 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | nokia 112 hangs fixed by flashing nokia 112 hangs fixed by flashing Quote:
02-14-2017, 06:53 | #693 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Noitacol Age: 37
Member: 2532428 Status: Offline Thanks Meter: 40 | I m 2g Network problem solved in Sarassoft UFS Turbo Samsung SM-G900F (S5) at USB (COM58) [DIAGS] {Read ENVM} OFFLMODE: OK Set SPC Password: 000000, OK MDMVERSN: Jan 2 201718:18:11Jul 28 201600:00:00AAAAANRZ MDMBUILD: MPSS.DI.2.0.1.c2.7-00047-M8974AAAAANRZM-1 NV IMEI1: 352###-##-######-# Get Names GN PROTECTED_NODE: /.efs_private Get Names GN PROTECTED_NODE: /nvm Get Names GN PROTECTED_NODE: /safe EFS2 Read Found: 850 File(s), 0 Link(s) EFS2 Read Done : 850 File(s), Time: 00:38.452 NVM_SIM_1 Read Done: Start 0, 1 Active Item(s), Time: 01:14.369 NVM Read Done: Start 0, 794 Active Item(s), Time: 01:16.607 Saved as: SM-G900F_352170-06-101828-4_07 [2017_02_14_10_40_05].envm Path: C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\SM-G900F\NVM\ Samsung SM-G900F (S5) at USB (COM58) [DIAGS] {Write ENVM} OFFLMODE: OK Set SPC Password: 000000, OK ENVM Image: SM-G900F_SM-G900FZWABTU_353222062158640_07_OK.envm Image Version: 100 Image DEVICE_INFO: SM-G900FZWABTU_353222062158640 Image MDM_VERSION: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Directory Created: /rfc/0207/selfcal/dev0_lte_rsb_cal_data.dat NVM SIM_1 Write Done: 1 Item(s), Time: 00:00.011 Cannot Write NVM Item: 0x0001, Write Protected Cannot Write NVM Item: 0x0002, Write Protected Cannot Write NVM Item: 0x0003, Write Protected NVM IMEI: 353###-##-######-# Write of IMEI Item Skipped Cannot Write NVM Item: 0x0797, Write Protected Cannot Write NVM Item: 0x15DD, Write Protected Cannot Write NVM Item: 0x15DE, Write Protected Cannot Write NVM Item: 0x27AB, NACK: 14 NVM Write Done: 795 Item(s), Time: 00:32.925 ENVM Write Done: 880 File(s), Time: 02:30.989 Samsung SM-G900F (S5) at USB [ADB] {ADB Reboot} ADB Reboot Done |
The Following User Says Thank You to BootYa For This Useful Post: |
02-14-2017, 07:01 | #694 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 575256 Status: Offline Thanks Meter: 34 | D2005 flashing done succes Sony Ericson D2005 flashing done, sukseee,,, this problem of device is restart2 continuous Quote:
The Following User Says Thank You to sbycell For This Useful Post: |
02-14-2017, 10:56 | #696 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Lyf Wind 7 (LS-5016) Read flash & Frp Reset Done Read Flash Var LYF-LS-5016 (Wind 7 LTE DS) at Auto Select Flash Port [SAHARA] {Read Flash} SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_ddr_lyf.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO PAR0: 30535680 x 512 Sectors (14.56 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) Physical Partition (Disk) Number: 0 Logical Partitions to Read: 24 (2.24 GB) FHREAD DONE: ST 0x0000000000 PrimaryGPT 17 KB FHREAD DONE: ST 0x0000020000 modem 64 MB FHREAD DONE: ST 0x0000040000 sbl1 512 KB FHREAD DONE: ST 0x0000040400 sbl1bak 512 KB FHREAD DONE: ST 0x0000040800 aboot 1024 KB FHREAD DONE: ST 0x0000041000 abootbak 1024 KB FHREAD DONE: ST 0x0000041800 rpm 512 KB FHREAD DONE: ST 0x0000041C00 rpmbak 512 KB FHREAD DONE: ST 0x0000042000 tz 768 KB FHREAD DONE: ST 0x0000042600 tzbak 768 KB FHREAD DONE: ST 0x0000042C00 pad 1024 KB FHREAD DONE: ST 0x0000045402 ssd 8 KB FHREAD DONE: ST 0x0000045412 splash 10 MB FHREAD DONE: ST 0x0000060000 DDR 32 KB FHREAD DONE: ST 0x0000060C40 sec 16 KB FHREAD DONE: ST 0x0000060C60 boot 32 MB FHREAD DONE: ST 0x0000070C60 system 2 GB FHREAD DONE: ST 0x0000470C60 persist 32 MB FHREAD DONE: ST 0x0000500C60 recovery 32 MB FHREAD DONE: ST 0x0000510C60 devinfo 1024 KB FHREAD DONE: ST 0x0000520000 keystore 512 KB FHREAD DONE: ST 0x0000520400 oem 64 MB FHREAD DONE: ST 0x0000540400 config 512 KB FHREAD DONE: ST 0x0001D1EFDF BackupGPT 16.5 KB Flash Definitions Saved as: Rawprogram0_sparsed.xml Path: H:\Nokia\Phoenix\LYF-LS-5016\READ\[2017_02_14_15_18_20]\ FHREST DONE: Ok Read Flash Done in: 02:08.061 Frp Reset [B]Var LYF-LS-5016 (Wind 7 LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_ddr_lyf.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO PAR0: 30535680 x 512 Sectors (14.56 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHREST DONE: Ok |
02-16-2017, 22:11 | #699 (permalink) |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | LANIX L1050 MSM8916 FRP REMOVED FULL IN SAHARA MODE BY UFST NOTE: I USED L950 MODEL IN LIST. Var LANIX-L950 (Ilium L950 LTE) at Auto Select Flashing Port [SAHARA] {Reset FRP} SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8916_qm.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8916 FHPROG MEMT: eMMC FHINFO PAR0: 30535680 x 512 Sectors (14,56 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) Reset FRP Done in: 00:03.708 FHREST DONE: Ok Br. Unlocker84 |
The Following User Says Thank You to Hacker84 For This Useful Post: |
02-16-2017, 22:15 | #700 (permalink) |
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | LANIX L1050 MSM8916 READ EFS IN SAHARA MODE FULL BY UFST NOTE: I used L1000 model in list. Var LANIX-L1000 (Ilium L1000 LTE) at Auto Select Flash Port [SAHARA] {Read EFS} SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8916_qm.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8916 FHPROG MEMT: eMMC FHINFO PAR0: 30535680 x 512 Sectors (14,56 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHREAD DONE: ST 0x0000042012 modemst1 1,5 MB FHREAD DONE: ST 0x0000042C12 modemst2 1,5 MB FHREAD DONE: ST 0x0000060040 fsg 1,5 MB FHREST DONE: Ok Read EFS Done in: 00:00.461 Saved as: LANIX-L1000_NVM_BACKUP [2017_02_16_16_02_42].tar Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\LANIX-L1000\EFS\ Wait, Restarting Br. Unlocker84 |
02-18-2017, 16:04 | #701 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 48
Member: 24115 Status: Offline Thanks Meter: 46 | Tablet Prestigio Wize PMT3407 (MT8735M) FRP done :) Great tool ! Code: MTK MT8735 (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM76 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 38000115334450577C990052AB061AEC [3DPW|] PR Version: 4.2 [0x9B] (5) eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000080000 [524.288] eMMC USER : 0x00000001D2000000 [7.818.182.656] eMMC CID : 15010038575044335200997CEC1A63AB [8WPD3R] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 8BD2B69BD7E35409E39BAE981980AD67 PMT (GPT) Found : 25 Partition Entries Reset FRP Done in: 00:02.800 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to milenjs For This Useful Post: |
02-28-2017, 12:53 | #704 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | LG-E410 Write Flash Done With Android UFST LG-E410 Write Flash Done With Android UFST ________ Regards Rehan |
The Following User Says Thank You to rehansk8879 For This Useful Post: |
03-08-2017, 06:25 | #705 (permalink) |
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Xperia M C2004 Pattern lock Remove Done in 18 Seconds With Android UFST Xperia M C2004 Pattern lock Remove Done in 18 Seconds With Android UFST Just Select loader.sin & userdata.sin _______ Regards Rehan |
