01-25-2017, 05:41 | #676 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Not Reachable Age: 31
Member: 1351351 Status: Offline Thanks Meter: 277 | LG_D295 write imei succesfull V1.0.5.3 test 32 after write imei UFST V1.0.5.3 test32uploading images 277634#*# >>port setting >>diag setting >>usb set for diag again set null port Last edited by suriyas1; 01-25-2017 at 05:42. Reason: Missing words |
The Following 4 Users Say Thank You to suriyas1 For This Useful Post: |
02-01-2017, 09:16 | #679 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | samsung j500h 6.0.1 frp removed hi flash it with this combination file COMBINATION_OXE_FA51_J500HXXU1AOF8 then go download mode do frp reset flash mode I Mistakenly deleted logs Last edited by profkefah; 02-01-2017 at 09:22. |
02-03-2017, 12:27 | #681 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | G d295 flash succesfully LG D295 FLASH SUCCESSFULLY- File: D29510e_00_D29510n.dz File Format: DZ Type 2 Model: LG-D295 File: D29510n Partitions {Chunks): 30 RbId: A1445950722-M1445950722-C1445953792-U1445953792-0 user Partitions (Chunks) to Flash: 30 (1.46 GB) LG D295 (L Fino DS) at USB (COM22) [LG FLASH 5] {Write Flash} DL MODE : 2 DL REQM : 5 DL MODEL: LG-D295 DL SWVER: D29510a DL IMEI : 000000-00-000000-0 LF MODEL: LG-D295 LF SERNO: LGD2953a14510 LF SWVER: LGD295AT-00-V10a-IND-XX-AUG-27-2014+0 LF MINOS: unknown LF OSVER: 4.4.2 LF IMEI : 356274-06-074409-2 LF DVPID: CT69S140924004192 LF SOCTY: msm8610 LF CABLE: USER Writing Partition: PrimaryGPT Writing Partition: modem Writing Partition: sbl1 Writing Partition: rpm Writing Partition: tz Writing Partition: sdi Writing Partition: aboot Writing Partition: rpmb Writing Partition: tzb Writing Partition: abootb Writing Partition: persist Writing Partition: laf Writing Partition: boot Writing Partition: recovery Writing Partition: factory Writing Partition: sbl1b Writing Partition: cust Writing Partition: system Writing Partition: BackupGPT Flash Write Done in: 02:45.555 LF CLOSE: 0k RESTART : 2 |
The Following 2 Users Say Thank You to galaxycompue For This Useful Post: |
02-03-2017, 14:03 | #682 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Yu 5010 dead flash No Fastboot PHP Code: |
The Following 4 Users Say Thank You to 4G Telecom For This Useful Post: |
02-05-2017, 08:55 | #683 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Mumbai
Member: 1612956 Status: Offline Sonork: 1605465 Thanks Meter: 70 | World 1St Moto E3 Pwr Xt1706 Frp Unlock Done By UFST MTK MT6735 (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM25 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 510001154D333145FA610742F53CF0D0 [M31E] PR Version: 4.2 [0x9B] (5) eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000003A3E00000 [15.634.268.160] eMMC CID : 150100514531334D420761FAD0F093F5 [QE13MB] ERAM Size : 0x0000000080000000 [2.147.483.648] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 84214DBE8F54B7D2B8DFDF6DD8293DB7 PMT (GPT) Found : 29 Partition Entries Reset FRP Done in: 00:02.745 DA Shutdown Done, Disconnect Cable |
The Following 3 Users Say Thank You to gsmali1 For This Useful Post: |
02-06-2017, 19:51 | #684 (permalink) |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | LG-H635C WRITE FLASH FULL BY UFST File: H635C20a_00_1110_H63520a.dz File Format: DZ Type 2 Model: LG-H635 File: H63520a Partitions {Chunks): 46 RbId: A1478781921-M1478781921-C1478786718-U1478786718-0 user Partitions (Chunks) to Flash: 46 (2,08 GB) LG H635C (G4 Stylus LTE) at USB (COM111) [LG FLASH 5] {Write Flash} DL MODE : 2 DL REQM : 5 DL MODEL: LG-H635C DL SWVER: H63510b DL IMEI : 0000000-07-000000-7 LF MODEL: LG-H635C LF SERNO: LGH6351d7c5777 LF SWVER: LGH635CAT-00-V10b-732-101-NOV-11-2015+0 LF MINOS: MiniOS 3.0 LF OSVER: 5.0.2 LF IMEI : 000000-07-090926-7 LF DVPID: CY20S151107006378 LF SOCTY: msm8916 LF CABLE: USER Writing Partition: PrimaryGPT Writing Partition: sbl1 Writing Partition: tz Writing Partition: hyp Writing Partition: rpm Writing Partition: aboot Writing Partition: sbl1bak Writing Partition: tzbak Writing Partition: hypbak Writing Partition: rpmbak Writing Partition: abootbak Writing Partition: persist Writing Partition: laf Writing Partition: boot Writing Partition: recovery Writing Partition: rct Writing Partition: cust Writing Partition: factory Writing Partition: modem Writing Partition: system Writing Partition: BackupGPT Flash Write Done in: 03:19.057 LF CLOSE: 0k RESTART : 2 |
02-06-2017, 19:52 | #685 (permalink) |
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | LG-H635C RESET FRP FULL BY UFST LG H635C (G4 Stylus LTE) at USB (COM113) [LG FLASH 5] {Reset FRP} DL MODE : 2 DL REQM : 5 DL MODEL: LG-H635C DL SWVER: H63510b DL IMEI : 000000-07-000000-7 LF MODEL: LG-H635C LF SERNO: LGH6351d7c5777 LF SWVER: LGH635CAT-00-V20a-732-101-NOV-10-2016+0 LF MINOS: MiniOS 3.0 LF OSVER: 6.0 LF IMEI : 352740-07-090926-7 LF DVPID: CY20S151107006378 LF SOCTY: msm8916 LF CABLE: 633A Reset FRP Done in 00:06.322 |
The Following User Says Thank You to Hacker84 For This Useful Post: |
02-08-2017, 13:32 | #686 (permalink) |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | MicroMax Q416 Flashing MicroMax Q416 (Canvas Pace 4G LTE) at Auto Select Flash Port [SAHARA] {Write Flash} Flash Bundle: rawprogram0.xml SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8909_ddr.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO PAR0: 15269888 x 512 Sectors (7.28 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) Partitions to Write: 96 (1.84 GB) FWRITE DONE: ST 0x0000020000 modem 47.75 MB FWRITE DONE: ST 0x0000040000 sbl1 241.18 KB FWRITE DONE: ST 0x0000040400 sbl1bak 241.18 KB FWRITE DONE: ST 0x0000040800 aboot 415.66 KB FWRITE DONE: ST 0x0000041000 abootbak 415.66 KB FWRITE DONE: ST 0x0000041800 rpm 155.97 KB FWRITE DONE: ST 0x0000041C00 rpmbak 155.97 KB FWRITE DONE: ST 0x0000042000 tz 511.04 KB FWRITE DONE: ST 0x0000042600 tzbak 511.04 KB FWRITE DONE: ST 0x0000045412 splash 1.17 MB FWRITE DONE: ST 0x0000060C60 boot 7.9 MB FWRITE DONE: ST 0x0000070C60 system 128.01 MB FWRITE DONE: ST 0x00000B10E8 system 8 KB FWRITE DONE: ST 0x00000B20F8 system 125.42 MB FWRITE DONE: ST 0x00000F0C60 system 8 KB FWRITE DONE: ST 0x00000F1C70 system 125.99 MB FWRITE DONE: ST 0x0000130C60 system 8 KB FWRITE DONE: ST 0x00001310E8 system 8 KB FWRITE DONE: ST 0x00001320F8 system 125.42 MB FWRITE DONE: ST 0x0000170C60 system 8 KB FWRITE DONE: ST 0x0000171C70 system 125.99 MB FWRITE DONE: ST 0x00001B0C60 system 8 KB FWRITE DONE: ST 0x00001B10E8 system 8 KB FWRITE DONE: ST 0x00001B20F8 system 125.42 MB FWRITE DONE: ST 0x00001F0C60 system 8 KB FWRITE DONE: ST 0x00001F1C70 system 125.99 MB FWRITE DONE: ST 0x0000230C60 system 8 KB FWRITE DONE: ST 0x00002310E8 system 8 KB FWRITE DONE: ST 0x00002320F8 system 125.42 MB FWRITE DONE: ST 0x0000270C60 system 8 KB FWRITE DONE: ST 0x0000271C70 system 125.99 MB FWRITE DONE: ST 0x00002B0C60 system 8 KB FWRITE DONE: ST 0x00002B10E8 system 8 KB FWRITE DONE: ST 0x00002B20F8 system 125.42 MB FWRITE DONE: ST 0x00002F0C60 system 8 KB FWRITE DONE: ST 0x00002F1C70 system 125.99 MB FWRITE DONE: ST 0x0000330C60 system 8 KB FWRITE DONE: ST 0x0000331C70 system 125.99 MB FWRITE DONE: ST 0x0000370C60 system 8 KB FWRITE DONE: ST 0x0000371C70 system 125.99 MB FWRITE DONE: ST 0x00003B0C60 system 8 KB FWRITE DONE: ST 0x00003B1C70 system 100.02 MB FWRITE DONE: ST 0x00003F0C60 system 8 KB FWRITE DONE: ST 0x0000430C60 system 8 KB FWRITE DONE: ST 0x0000470C60 system 8 KB FWRITE DONE: ST 0x00004B0C60 system 8 KB FWRITE DONE: ST 0x00004F0C60 persist 4.57 MB FWRITE DONE: ST 0x0000500C60 cache 6.09 MB FWRITE DONE: ST 0x0000540C60 cache 8 KB FWRITE DONE: ST 0x0000540CE8 cache 8 KB FWRITE DONE: ST 0x0000580C60 recovery 8.23 MB FWRITE DONE: ST 0x00005C0400 config 512 KB FWRITE DONE: ST 0x00005C0800 userdata 69.09 MB FWRITE DONE: ST 0x0000600800 userdata 8 KB FWRITE DONE: ST 0x0000601088 userdata 8 KB FWRITE DONE: ST 0x0000640800 userdata 8 KB FWRITE DONE: ST 0x0000680800 userdata 8 KB FWRITE DONE: ST 0x0000681088 userdata 8 KB FWRITE DONE: ST 0x00006C0800 userdata 8 KB FWRITE DONE: ST 0x0000700800 userdata 8 KB FWRITE DONE: ST 0x0000701088 userdata 8 KB FWRITE DONE: ST 0x0000740800 userdata 8 KB FWRITE DONE: ST 0x0000780800 userdata 8 KB FWRITE DONE: ST 0x0000781088 userdata 8 KB FWRITE DONE: ST 0x00007C0800 userdata 8 KB FWRITE DONE: ST 0x0000800800 userdata 8 KB FWRITE DONE: ST 0x0000801088 userdata 8 KB FWRITE DONE: ST 0x0000840800 userdata 8 KB FWRITE DONE: ST 0x0000880800 userdata 8 KB FWRITE DONE: ST 0x00008C0800 userdata 8 KB FWRITE DONE: ST 0x0000900800 userdata 8 KB FWRITE DONE: ST 0x0000940800 userdata 8 KB FWRITE DONE: ST 0x0000980800 userdata 8 KB FWRITE DONE: ST 0x00009C0800 userdata 8 KB FWRITE DONE: ST 0x0000A00800 userdata 8 KB FWRITE DONE: ST 0x0000A40800 userdata 8 KB FWRITE DONE: ST 0x0000A80800 userdata 8 KB FWRITE DONE: ST 0x0000AC0800 userdata 8 KB FWRITE DONE: ST 0x0000B00800 userdata 8 KB FWRITE DONE: ST 0x0000B40800 userdata 8 KB FWRITE DONE: ST 0x0000B80800 userdata 8 KB FWRITE DONE: ST 0x0000BC0800 userdata 8 KB FWRITE DONE: ST 0x0000C00800 userdata 8 KB FWRITE DONE: ST 0x0000C01088 userdata 8 KB FWRITE DONE: ST 0x0000C40800 userdata 8 KB FWRITE DONE: ST 0x0000C80800 userdata 8 KB FWRITE DONE: ST 0x0000C81088 userdata 8 KB FWRITE DONE: ST 0x0000CC0800 userdata 8 KB FWRITE DONE: ST 0x0000D00800 userdata 8 KB FWRITE DONE: ST 0x0000D40800 userdata 8 KB FWRITE DONE: ST 0x0000D80800 userdata 8 KB FWRITE DONE: ST 0x0000DC0800 userdata 8 KB FWRITE DONE: ST 0x0000E00800 userdata 8 KB FWRITE DONE: ST 0x0000E017A0 userdata 80 KB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Done in: 05:41.362 |
02-11-2017, 00:34 | #689 (permalink) |
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | LANIX L950 FLASH FULL BY UFST Use [FH] Button to select Flash Program .xml Var LANIX-L950 (Ilium L950 LTE) at Auto Select Flashing Port [SAHARA] {Write Flash} Flash Bundle: rawprogram_unsparse.xml SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8916_qm.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8916 FHPROG MEMT: eMMC FHINFO PAR0: 30785536 x 512 Sectors (14,68 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) Partitions to Write: 161 (1,92 GB) FWRITE DONE: ST 0x0000020000 modem 47,53 MB FWRITE DONE: ST 0x0000040000 sbl1 244,23 KB FWRITE DONE: ST 0x0000040400 sbl1bak 244,23 KB FWRITE DONE: ST 0x0000040800 aboot 446,14 KB FWRITE DONE: ST 0x0000041000 abootbak 446,14 KB FWRITE DONE: ST 0x0000041800 rpm 147,71 KB FWRITE DONE: ST 0x0000041C00 rpmbak 147,71 KB FWRITE DONE: ST 0x0000042000 tz 472,14 KB FWRITE DONE: ST 0x0000042400 tzbak 472,14 KB FWRITE DONE: ST 0x0000042800 hyp 56 KB FWRITE DONE: ST 0x0000042C00 hypbak 56 KB FWRITE DONE: ST 0x0000045812 splash 2,64 MB FWRITE DONE: ST 0x0000060C40 sec 80 Bytes FWRITE DONE: ST 0x0000060C60 boot 14,6 MB FWRITE DONE: ST 0x0000070C60 system 128,01 MB FWRITE DONE: ST 0x00000B1068 system 8 KB FWRITE DONE: ST 0x00000B2058 system 125,5 MB FWRITE DONE: ST 0x00000F0C60 system 8 KB FWRITE DONE: ST 0x00000F1C50 system 126 MB FWRITE DONE: ST 0x0000130C60 system 8 KB FWRITE DONE: ST 0x0000131068 system 8 KB FWRITE DONE: ST 0x0000132058 system 125,5 MB FWRITE DONE: ST 0x0000170C60 system 8 KB FWRITE DONE: ST 0x0000171C50 system 126 MB FWRITE DONE: ST 0x00001B0C60 system 8 KB FWRITE DONE: ST 0x00001B1068 system 8 KB FWRITE DONE: ST 0x00001B2058 system 125,5 MB FWRITE DONE: ST 0x00001F0C60 system 8 KB FWRITE DONE: ST 0x00001F1C50 system 126 MB FWRITE DONE: ST 0x0000230C60 system 8 KB FWRITE DONE: ST 0x0000231068 system 8 KB FWRITE DONE: ST 0x0000232058 system 125,5 MB FWRITE DONE: ST 0x0000270C60 system 8 KB FWRITE DONE: ST 0x0000271C50 system 126 MB FWRITE DONE: ST 0x00002B0C60 system 8 KB FWRITE DONE: ST 0x00002B1068 system 8 KB FWRITE DONE: ST 0x00002B2058 system 125,5 MB FWRITE DONE: ST 0x00002F0C60 system 8 KB FWRITE DONE: ST 0x00002F1C50 system 126 MB FWRITE DONE: ST 0x0000330C60 system 8 KB FWRITE DONE: ST 0x0000331C50 system 126 MB FWRITE DONE: ST 0x0000370C60 system 8 KB FWRITE DONE: ST 0x0000371C50 system 104,89 MB FWRITE DONE: ST 0x00003B0C60 system 8 KB FWRITE DONE: ST 0x00003F0C60 system 8 KB FWRITE DONE: ST 0x0000430C60 system 8 KB FWRITE DONE: ST 0x0000431C50 system 109,84 MB FWRITE DONE: ST 0x0000468B18 system 16,04 MB FWRITE DONE: ST 0x0000470C60 persist 4,98 MB FWRITE DONE: ST 0x0000480C60 cache 1,47 MB FWRITE DONE: ST 0x00004C0C60 cache 8 KB FWRITE DONE: ST 0x00004C0D28 cache 8 KB FWRITE DONE: ST 0x0000500C60 cache 8 KB FWRITE DONE: ST 0x0000501760 cache 4,11 MB FWRITE DONE: ST 0x0000503C60 recovery 15,17 MB FWRITE DONE: ST 0x0000560800 userdata 4,93 MB FWRITE DONE: ST 0x00005A0800 userdata 8 KB FWRITE DONE: ST 0x00005A1F88 userdata 8 KB FWRITE DONE: ST 0x00005E0800 userdata 8 KB FWRITE DONE: ST 0x00005E17E8 userdata 126,02 MB FWRITE DONE: ST 0x0000621F88 userdata 8 KB FWRITE DONE: ST 0x0000660800 userdata 8 KB FWRITE DONE: ST 0x00006A0800 userdata 8 KB FWRITE DONE: ST 0x00006A1F88 userdata 8 KB FWRITE DONE: ST 0x00006E0800 userdata 8 KB FWRITE DONE: ST 0x0000720800 userdata 8 KB FWRITE DONE: ST 0x0000721F88 userdata 8 KB FWRITE DONE: ST 0x0000760800 userdata 8 KB FWRITE DONE: ST 0x00007A0800 userdata 8 KB FWRITE DONE: ST 0x00007A1F88 userdata 8 KB FWRITE DONE: ST 0x00007E0800 userdata 8 KB FWRITE DONE: ST 0x0000820800 userdata 8 KB FWRITE DONE: ST 0x0000860800 userdata 8 KB FWRITE DONE: ST 0x00008A0800 userdata 8 KB FWRITE DONE: ST 0x00008E0800 userdata 8 KB FWRITE DONE: ST 0x0000920800 userdata 8 KB FWRITE DONE: ST 0x0000960800 userdata 8 KB FWRITE DONE: ST 0x00009A0800 userdata 8 KB FWRITE DONE: ST 0x00009E0800 userdata 8 KB FWRITE DONE: ST 0x0000A20800 userdata 8 KB FWRITE DONE: ST 0x0000A60800 userdata 8 KB FWRITE DONE: ST 0x0000AA0800 userdata 8 KB FWRITE DONE: ST 0x0000AE0800 userdata 8 KB FWRITE DONE: ST 0x0000B20800 userdata 8 KB FWRITE DONE: ST 0x0000B60800 userdata 8 KB FWRITE DONE: ST 0x0000BA0800 userdata 8 KB FWRITE DONE: ST 0x0000BA1F88 userdata 8 KB FWRITE DONE: ST 0x0000BE0800 userdata 8 KB FWRITE DONE: ST 0x0000C20800 userdata 8 KB FWRITE DONE: ST 0x0000C21F88 userdata 8 KB FWRITE DONE: ST 0x0000C60800 userdata 8 KB FWRITE DONE: ST 0x0000CA0800 userdata 8 KB FWRITE DONE: ST 0x0000CE0800 userdata 8 KB FWRITE DONE: ST 0x0000D20800 userdata 8 KB FWRITE DONE: ST 0x0000D60800 userdata 8 KB FWRITE DONE: ST 0x0000DA0800 userdata 8 KB FWRITE DONE: ST 0x0000DE0800 userdata 8 KB FWRITE DONE: ST 0x0000E20800 userdata 8 KB FWRITE DONE: ST 0x0000E60800 userdata 8 KB FWRITE DONE: ST 0x0000EA0800 userdata 8 KB FWRITE DONE: ST 0x0000EE0800 userdata 8 KB FWRITE DONE: ST 0x0000F20800 userdata 8 KB FWRITE DONE: ST 0x0000F60800 userdata 8 KB FWRITE DONE: ST 0x0000FA0800 userdata 8 KB FWRITE DONE: ST 0x0000FE0800 userdata 8 KB FWRITE DONE: ST 0x0001020800 userdata 8 KB FWRITE DONE: ST 0x0001060800 userdata 8 KB FWRITE DONE: ST 0x00010A0800 userdata 8 KB FWRITE DONE: ST 0x00010E0800 userdata 8 KB FWRITE DONE: ST 0x0001120800 userdata 8 KB FWRITE DONE: ST 0x0001160800 userdata 8 KB FWRITE DONE: ST 0x00011A0800 userdata 8 KB FWRITE DONE: ST 0x00011A1F88 userdata 8 KB FWRITE DONE: ST 0x00011E0800 userdata 8 KB FWRITE DONE: ST 0x0001220800 userdata 8 KB FWRITE DONE: ST 0x0001260800 userdata 8 KB FWRITE DONE: ST 0x00012A0800 userdata 8 KB FWRITE DONE: ST 0x00012E0800 userdata 8 KB FWRITE DONE: ST 0x0001320800 userdata 8 KB FWRITE DONE: ST 0x0001360800 userdata 8 KB FWRITE DONE: ST 0x00013A0800 userdata 8 KB FWRITE DONE: ST 0x00013E0800 userdata 8 KB FWRITE DONE: ST 0x0001420800 userdata 8 KB FWRITE DONE: ST 0x0001460800 userdata 8 KB FWRITE DONE: ST 0x00014A0800 userdata 8 KB FWRITE DONE: ST 0x00014E0800 userdata 8 KB FWRITE DONE: ST 0x0001520800 userdata 8 KB FWRITE DONE: ST 0x0001560800 userdata 8 KB FWRITE DONE: ST 0x00015A0800 userdata 8 KB FWRITE DONE: ST 0x00015E0800 userdata 8 KB FWRITE DONE: ST 0x0001620800 userdata 8 KB FWRITE DONE: ST 0x0001660800 userdata 8 KB FWRITE DONE: ST 0x00016A0800 userdata 8 KB FWRITE DONE: ST 0x00016E0800 userdata 8 KB FWRITE DONE: ST 0x0001720800 userdata 8 KB FWRITE DONE: ST 0x0001760800 userdata 8 KB FWRITE DONE: ST 0x00017A0800 userdata 8 KB FWRITE DONE: ST 0x00017E0800 userdata 8 KB FWRITE DONE: ST 0x0001820800 userdata 8 KB FWRITE DONE: ST 0x0001860800 userdata 8 KB FWRITE DONE: ST 0x00018A0800 userdata 8 KB FWRITE DONE: ST 0x00018E0800 userdata 8 KB FWRITE DONE: ST 0x0001920800 userdata 8 KB FWRITE DONE: ST 0x0001960800 userdata 8 KB FWRITE DONE: ST 0x00019A0800 userdata 8 KB FWRITE DONE: ST 0x00019A1F88 userdata 8 KB FWRITE DONE: ST 0x00019E0800 userdata 8 KB FWRITE DONE: ST 0x0001A20800 userdata 8 KB FWRITE DONE: ST 0x0001A60800 userdata 8 KB FWRITE DONE: ST 0x0001AA0800 userdata 8 KB FWRITE DONE: ST 0x0001AE0800 userdata 8 KB FWRITE DONE: ST 0x0001B20800 userdata 8 KB FWRITE DONE: ST 0x0001B60800 userdata 8 KB FWRITE DONE: ST 0x0001BA0800 userdata 8 KB FWRITE DONE: ST 0x0001BE0800 userdata 8 KB FWRITE DONE: ST 0x0001C20800 userdata 8 KB FWRITE DONE: ST 0x0001C60800 userdata 8 KB FWRITE DONE: ST 0x0001CA0800 userdata 8 KB FWRITE DONE: ST 0x0001CA17E8 userdata 2,08 MB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FWRITE DONE: ST 0x0000000021 BackupGPT 16,5 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Done in: 05:59.390 Br. Unlocker84 |
02-12-2017, 16:30 | #690 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | huawei y5ii cun u29 5.1.1 frp reset done hi phone was locked with frp with one key i removed it here is procedure first connect phone in normal mode (when it reaches wifi) then from box select huawei model y5 ii then press refresh then frp reset select frp by adb no root command promp on phone screen will pop up choose ok then phone will open to application directly enable OEM UNLOCK FROM USB DEBUG MENU THEN RESET SETTING |
The Following User Says Thank You to profkefah For This Useful Post: |
