07-28-2015, 13:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | BlackBerry Z10 STL100-2 LTE (LDR) Code: Chimera Mobile Phone Utility version: 7.21.1421 @ 2015-07-29 [Get info started.] Bootrom info Bootrom version: 5.35.0.29 Metrics version: 6.43 Build user: ec_agent Build date: Nov 3 2012 Build time: 09:10:26 OS ID: 0x051d0001 HWID override: 0 OS info OS version: Build user: ec_agent Build date: Feb 19 2013 Build time: 02:42:36 Device info Device name: RIM BlackBerry Device BSN hash: 25afe4ef284c4b043972a8bb6eb6d2c922fc918c BSN: 1137909442 Model number: BlackBerry Z10 STL100-2 LTE HWID: 0x8700240a PIN: 0x2abd93e6 ECID: 10003 Flash info Manufacturer: 0x15 Device Id: 0x10 Product name: MAG2GA Revision: 1.2. Manufacturing date: 2014 January Number of blocks: 0x3a400 Block size: 0x10000 Page size: 0x1000 Serial number: 0xee1d7fd3 Get info done. Finished at local time: [07.29.15 01:17:56] WorkID: 6223676 |
07-28-2015, 13:48 | #2 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | i NUKE the phone still not solve yet, when i press volume up the light indicate green light when press volume down give red light Code: Chimera Mobile Phone Utility version: 7.21.1421 @ 2015-07-29 [Nuke phone] Starting nuke process Waiting for boot mode If it doesn't connect in 10 seconds, unplug the USB cable and plug it in again Nuking the phone. Please wait until the red LED extinguishes. This may take a few minutes. Nuking done. Finished at local time: [07.29.15 01:26:55] WorkID: 6223801 thanks |
07-28-2015, 14:11 | #3 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | after flashing not solve Code: Chimera Mobile Phone Utility version: 7.21.1421 @ 2015-07-29 [Software change started.] Phone is in loader mode Connected to loader Querying meminfo Downloading files Extracting BAR files Extracting: qcfm.image.com.qnx.qcfm.qc8960.factory_sfi.desktop.BB10_3_2_CPLUS.840.856548.signed Extracting: qcfm.image.com.qnx.qcfm.radio.qc8960.BB10_3_2_CPLUS.841.856548.signed. Flashing file Parsing file Start flashing Flashing has been finished Reconnected Flashing file Parsing file Start flashing Flashing has been finished Flashing has been finished successfully Finished at local time: [07.29.15 02:01:04] WorkID: 6224257 |
07-28-2015, 14:17 | #4 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | finally restart phone and i can continue on the setup but when phone sleep or screen light turn off i can't press any key to back inside all i do just press the power until the restart again will make a little rest and post again thanks |
07-31-2015, 05:57 | #7 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | the status of the phone was power up and loading once loading bar done then its restart again, and after flash i can go thought inside and use the phone after a few second the phone back to before status when i press volume like i post before the process its goes well and normal but after its back to before. i will try to flash with another file and update the result thanks |
07-31-2015, 13:32 | #8 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,781 | reply Dear Sir, if your customer need urgent the phone, flash an 10.3.2 software into the phone. If you have time, please wait for the next update, we will have solution fr the problem. Best regards Chimera Team Quote:
08-03-2015, 00:40 | #9 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
thanks | |
08-05-2015, 18:58 | #11 (permalink) | |
after flash i think a little bit change now with the phone but the phone have problems with battery a little bit low still try to charging. working ID: 6338288 i will post the result later | |
