02-06-2016, 22:02 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | GCPro Box UART Port Not working Using Version...1.0.0.0026 Selected Port VCP0 = COM5 Selected Model GT-I5503 Selected Task SAMSUNG READINFO Searching phone... No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN... Phone Not Found Retry Please. Total Time Take...00:00:12 I been using this box for the past month, UART port works fine. But last few days i noticed that i did not work anymore. I have to use another BOX's UART port to fix my phones. (Octoplus Box) Both Com Ports use the same driver. Driver Provider: FTDI Driver Date: 1/6/2016 Driver Version: 2.12.12.0 did my box's UART actualy failed/broke? is that common? or could be some settings, or configuration? If it could be configuration, could anyon e point me to the direction where I should look? Thanks a million! |
02-11-2016, 13:55 | #6 (permalink) |
Freak Poster Join Date: Mar 2008 Location: kabul AFGHANISTAN Age: 35
Member: 724190 Status: Offline Sonork: zabih Thanks Meter: 16 | my probleme same urt port notworking Selected Port Com:13 Selected Model SM-G920F Selected Task SAMSUNG DRK FIX Started Samsung DRK Fix... No reply on samsung mode.. DIAL *#0*# AND TRY AGAIN... !!! Fail !!!! Total Time Take...00:00:07 Log Saved |
02-11-2016, 14:49 | #7 (permalink) | |
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
I got mine working, Check the drivers for both the com port and the serial to USB converter, make sure they are the same version.. In mine case it was windows update that messed it up.. I downgraded to back to the 02.18 version and worked perfect Sent from my iPhone using Tapatalk | |
02-12-2016, 23:12 | #8 (permalink) |
Freak Poster Join Date: May 2013
Member: 1947667 Status: Offline Thanks Meter: 31 | You can get a UART port emulator as an alternative |
03-26-2016, 20:14 | #13 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Remember here is a support area.. they can help to check variants in yours ftdi files.. after check driver problem (delete Ftd*.*) then install drivers compatible FTDI Box.- Use OLD ns Pro BOx Like a Interfaze o talk with your resseller, maybe your Box is damage under Guarranty.- Compare Shipping and Other Interfaz for UART like altenative .. br Polaco |
11-30-2018, 16:06 | #14 (permalink) |
Freak Poster Join Date: Jul 2016 Location: Chile Age: 41
Member: 2601431 Status: Offline Thanks Meter: 35 | My doesn't work... I tried forcing the drivers from support and the same result... I have windows 10, i will try with win 7 and i will post the result later here. |
12-05-2018, 01:31 | #15 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Here are some suggestions... 1. In device manager change the uart box com port number to 1 or 2 since those two are automatically reserved port numbers under windows, and they never get overwritten by new usb modem/serial port installations. The biggest problem is when more than one ports shares/overwrites the same com port number. Also, unplug all other boxes and dongles, and only have one plugged in at a time which you're currently working on. 2. There are lots of fake FTDI chip boxes out there, therefore use driver version 2.10.0.0 or lower in order to avoid being disabled. 3. Use this handy little app called Comport Setter on windows to manage which ports are available for enumeration. It lets you reserve certain ports or clear them all to become available during port installation. https://androidfilehost.com/?fid=745425885120755601 Enjoy! |
The Following User Says Thank You to BillA For This Useful Post: |
