01-17-2015, 14:04 | #1 (permalink) | |||
No Life Poster Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | Samsung SM-N910A Note 4 Done Sucessfully. Here is the method to wipe the EFS without Root. i. Open dialer and dial *#9090# ii. Press Menu Enter Q iii. Press Menu and hit Back, After Enter Key 0000 Wait for couple of seconds. You will be Prompted into MAIN MENU iv. Select UE SETTINGS & INFO, SYSTEM, NV BACKUP TEST, ERASE ALL EFS1/2/3 and Select YES. v. EFS WIPE is done without ROOT. ***Warning!!! I'm not responsible for anything that happens to your Device*** 2. Write IMEICERT to your phone. (NB. Use UART Cable and remember battery trick.) 3. All is DONE , Phone is UNLOCKED Also remember to back up QCN. QCN Backup Quote:
Write IMEICERT Quote:
Regards , Mediaextensins. | |||
The Following 5 Users Say Thank You to mediaextensions For This Useful Post: |
01-18-2015, 19:03 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello You can use any FTDI interface you have. if you don't have then you can buy one from gpg with cable set too. Regards Chevli GCPROKEY |
01-29-2015, 19:52 | #8 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Thank you for the credit ... I didn't wanted to release this stuff but I seen a lot people breaking their heads trying to wipe the EFS ... I also have another method with Odin just incase if the "Hidden Menu" gets patched by Samsung OTA |
01-29-2015, 19:53 | #9 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | Here is a clean QCN N910A I you guys need it .. SM-N910A_MPSS.DI.3.0.c5-00300-M9625TAARANAZM-1.7892.2_26-1-2015_20-30-29 |
The Following 6 Users Say Thank You to jusmejose For This Useful Post: |
02-04-2015, 22:25 | #11 (permalink) | |
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
Or back your own QCN before you wipe "EFS" using "QPST,z3x,Octopus" or any dongle/Box that supports "QCN" BackUP/Restore .... | |
The Following User Says Thank You to jusmejose For This Useful Post: |
02-04-2015, 22:38 | #13 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | **Note: Make sure is the correct model when loading the QCN , Because sometimes it will work and sometimes it wont!, I suggest if you just want to unlock just buy code "Online Server" this "IMEI cert" and "EFS: wipe is for Advanced users that that know what their doing, and if you have Unique "IMEI cert" ... Im not saying that your Dumb but you will save your self "Headaches" with your Customer ... ** |
