Apple Watch 3 [info] Unhandled status message [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed [info] Apple device disconnected! |
You need manual select firmware by holding "shift" key when you click "restore" button |
I do it all. Watch 3 series 38 mm I connect to the laptop, hold down the Shift key, select the firmware, the process is in progress. A load circle appears on the clock, an error which I have indicated jumps out to 80%. |
You'd better post MFC logs, i couldn't guess what happened at 80% |
Today I try to flash the clock, shows this: [info] [info] Starting ... [info] Using LOCAL IPSW C:\Users\lexa52\Desktop\MFC_Watch3.3_15T567_4.3.1_ n121sAP_GPS_Restore_38mm.ipsw [info] using cached version data [info] Found device in DFU mode [info] Identified device as Apple Watch S3, n121sap, Watch3,3 [info] Extracting BuildManifest from ipsw [data] Product Version: 4.3.1 [data] Product Build: 15T567 Major: 15 [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 1815345505820838 [info] Getting ApNonce in dfu mode... [data] BA8E50E5299047F9C6D78ED75A46E794318E2B6E3ACDAE068D DB678EC76F81EE [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in dfu mode... [data] 4F39DEA6F1B7C17EF427C30D0DE5983510545B2D [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [erro] TSS server returned: STATUS=94&MESSAGE=This device isn't eligible for the requested build. [erro] TSS request failed (status=94, message=This device isn't eligible for the requested build.) [erro] tts>Unable to send TSS request [erro] Unable to get SHSH blobs for this device [info] Failed yesterday gave out other information |
hmm, seems 4.3.1 also stop signed now :-( |
S3 new firmware any chance of getting s3 new firmware |
We will announcement related information once we get news |
