Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Xolo
Old 02-05-2015, 22:34   #1 (permalink)
Member: 1942086
Thanks Meter: 13
xolo a500s lite back light problem......
Xolo a500s lite......display light to low i change the lcd and coils also same problem plz help me forum.......
Old 02-07-2015, 08:45   #2 (permalink)
Member: 1076623
Sonork: 0554200
Thanks Meter: 2
downloads software 100% ok
Old 02-23-2015, 20:32   #3 (permalink)
Member: 1942086
Thanks Meter: 13
Its hardware bro not software
Old 02-27-2015, 04:09   #4 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 42
first check its water damage or clean.. if water damage than try to clean lcd connector and check any pins break or not.. if all ok than try to change coil, 6 leg ic, and diode... hope your problem will be solved....
Purshottam
Old 03-01-2015, 07:23   #5 (permalink)
Member: 735467
Sonork: ravi_dhariya
Thanks Meter: 2
But I Have Display Ic Problem Where is it In PCB Brother
Please Show Display Ic With Picture File Please help Brother .......
Old 03-01-2015, 07:48   #6 (permalink)
sb99sameerkhan's Avatar
Member: 1978625
Sonork: 100.1661449
Thanks Meter: 39
check 6pin led transistor & coil
Old 03-01-2015, 17:39   #7 (permalink)
Member: 1942086
Thanks Meter: 13
every value is proper i change coil and diode and 6leg transistor bt not working...............
Old 08-12-2015, 13:30   #8 (permalink)
Member: 2438697
Sonork: Askaran5
Xolo a500 disply not show but set is on plz slov
Plz send me xolo a500 pcd image or light jumper
Old 10-13-2015, 20:09   #9 (permalink)
Member: 1191342
Thanks Meter: 2
xolo a500s lite speaker jumper solution pls
thanks in advance
Page generated in 0.13059 seconds with 8 queries
