Lenovo General Lenovo phones discussion, firmwares, solution, help |
04-18-2019, 21:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | I need to remove FRP Lenovo Tab E10 I am involved trying to remove an FRP to Lenovo Tab E10 and I could not give solution. I Tried with several boxes, I can not remove the account. Can you please give me some solution for this? Thank you Last edited by Brka; 04-18-2019 at 21:17. Reason: removed boxes. |
04-18-2019, 21:18 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Maybe, as soon as you post EXACT and FULL model of your device. You can also enter recovery and see what is written inside, or post some picture of it. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
04-19-2019, 00:23 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
now, while in that boot menu, use volume up and down keys, and enter RECOVERY ... there is exactly written which software version/model is currently inside that specific device. Post those details too. (or use different key combination to enter recovery) b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
04-19-2019, 13:59 | #5 (permalink) | |
Member: 517318 Status: Offline Thanks Meter: 88 | Quote:
the recovery does not show anything that can help, I think Thanks | |
04-19-2019, 20:51 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Okay, but without knowing EXACT model, I am not able to help you. Try to find exact model number and post here. b.r. Alex
04-23-2019, 20:54 | #8 (permalink) | |
- boot into fastboot mode (Power off device - press on/off + Volume UP - device restarts to fastboot mode) - install minimal ADB, open command prompt - issue command: fastboot oem unlock-go - check device screen and command output - if needed, confirm bootloader unlock on device - after full power-on of device, shut it down again - repeat entering fastboot mode on device - issue fastboot command: fastboot erase config - check output if okay - if okay, issue fastboot command: fastboot reboot frp should be gone. b.r. Alex
04-24-2019, 21:10 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | There is still possibility, but is dangerous and I would not recommend doing anything else via PC. Reason: I don't have full rom for your device, and cant make frp remove package. If you manage to get full flashable rom for same exact version of your device (and same hardware code - which should be for your device : code 10), you can forward that package, and I can make FRP remover. (But is still dangerous if you don't know what are you doing). p.s. If you have some BOX with QUALCOMM module, it will be easy task. write PM if so, I will send you needed loader. b.r. Alex
