07-29-2016, 14:57 | #47 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2589119 Status: Offline Thanks Meter: 0 | Hello I just received xtc2clip and im trying to get it to work but i get a message : there is no disk in the drive. Please insert a disk into drive \device\harddisk1\DR1. PLEASE, PLEASE HELP. Can you even access mu computer with TeamViewer. I really need it working asap. |
07-31-2016, 08:20 | #48 (permalink) |
Major Poster Join Date: Mar 2004 Location: Ir Age: 34
Member: 56799 Status: Offline Thanks Meter: 5 | ?????? Check keycard failed problem ??????? hello i updated/activated my box try with 2 different Y cable and 2-3 different micro sd readers also try re format box by this guide : IMPORTANT: How to repair filesystem after format, etc but the problem still not solved i want to soff m7_ul what should i do ? thanks |
08-02-2016, 12:39 | #50 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Chittagong, Bangladesh.
Member: 2334386 Status: Offline Sonork: 1668793 Thanks Meter: 33 | no email activation code dongle S/N: 90022857 email: [email protected] Sent from my iris 870 using Tapatalk |
08-02-2016, 23:46 | #51 (permalink) |
Junior Member Join Date: Aug 2013 Location: mexico
Member: 1992408 Status: Offline Thanks Meter: 1 | Failpermission deny (decrease_cycle_fail) Sending oem writesecureflag 3 ... (bootloader) Partition verify pass FAILPERMISSION DENY (DECREASE_CYCLE_FAIL) FAILED (remote: PERMISSION DENY (DECREASE_CYCLE_FAIL)) Execution time is 4(s) Operation finished Reading MEID information ... (bootloader) meid: OKAY Execution time is 20(ms) Read information completed. |
08-03-2016, 05:44 | #52 (permalink) |
Freak Poster Join Date: Apr 2015 Location: NEW DELHI INDIA
Member: 2376362 Status: Offline Sonork: 1664031:mohd Thanks Meter: 49 | Checking server connection... Communicating with the XTC 2 Clip ... ERROR: Cannot open smart_io.crd File downloading link is not working Please resolve this problem |
08-06-2016, 13:59 | #56 (permalink) |
Insane Poster Join Date: May 2006
Member: 280221 Status: Offline Thanks Meter: 2 | when i connect my clip into my pc asking format in drive when i connect my clip into my pc asking format in drive. when i try to format, windows says can't format. unknown size of drive. clip is new. |
08-29-2016, 19:12 | #58 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | If you get CHECK KEYCARD FAILED, Please run XTC 2 Client, read clip ID and PM me. Otherwise, repair filesystem: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ |
08-31-2016, 23:31 | #59 (permalink) |
Junior Member Join Date: Mar 2015 Location: Santo Domingo
Member: 2360925 Status: Offline Thanks Meter: 12 | NO S-OFF IT STOPPED WORKING Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8wl_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY Execution time is 5(s) Operation finished |
09-02-2016, 02:03 | #60 (permalink) |
Freak Poster Join Date: Jan 2000 Location: cyprus -england Age: 66
Member: 846 Status: Offline Thanks Meter: 31 | cheap material clip few years back i board the xtc clip after few months of use the cables brake and it was rely hard to use.nearly a year ago i buy the new xtc2clip and i used once the second time i tried to use the clip no working ,i send back to fonefun shop from where i buy and send me back with a report of out of 6 months warranty and the clip is dead.i make mistake the first time to buy the first clip and never learn and make second mistake to buy the new clip ,believe me i don't make another mistake to buy any of your products anymore. advice for anyone thing to buy xtc2clip to thing two times.very cheap materials and problematic very hard to use |
