08-13-2017, 16:39 | #53 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2743263 Status: Offline Thanks Meter: 4 | So there is a public method. It is not discovered by me but i will bring it here. Before doing this, I have had on my Pixel access with Sidebar apk, and had to download from rootjunkysdl . com the following apps: com . rootjunky . frpbypass-1.0 . apk, android 5 Google Account Manager and gam6 . apk (from site go to "Apps" - "FRP" - "Android7 . 0"). Essentially you must upgrade to Android O Preview Beta (July patch, NOT AUGUST!!!!), This can be done with adb and fastboot even if the bootloader and usb debugging are off. After upgrade, uninstall the Google Account Manager, and try to install one of those you have downloaded (gam6 or android 5 google account manager - try more times if it fails - for me gam6 worked ). When you succeed, install com . rootjunky . frpbypass, open, select the three dot in top right corner, and then sign in with new google account. Now you can Factory reset and the account will still be the one you loged in with. Good luck! |
The Following User Says Thank You to moonstar111 For This Useful Post: |
08-13-2017, 22:11 | #54 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | Quote:
I have sailfish on 7.1 with FRP and ready to test 1. Any link for Android O July Preview for sailfish ? 2. After you login with your account and reset you say your new account stays on. It cannot be removed ? Also Developer cannot be activated ? No OEM unlock ? Thanks | |
08-13-2017, 22:32 | #55 (permalink) |
Member: 2743263 Status: Offline Thanks Meter: 4 | 1. The Android O link should be https : // developer . android . com/preview/download-ota . html (cannot post links yet). The file should contain OTA 170623 for July patch. 2. After login with my account and reset, actually my account was gone, no frp anymore (maybe I should have reactivated for frp lock), so no problem, you can remove the account as you like. On my phone, I think verizon, I activated after that developer options and I also can OEM unlock (i did not do it yet though). |
