Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 02-15-2016, 03:03   #1 (permalink)
Member: 322130
Thanks Meter: 57
htc nexus 9 unlock boot loader
hi
my htc nexux 9 stuck I can get bootloader I need flash this tablet I got 2 different y-cable and 2 usb sd reder when I connect to pc they both working xtcclip2 software I cant get unlock boot loader read guide from xtcclip2 website how to use y-cable connect y-cable to tablet and fastboot and simlock still not connect clip on tablet please help where iam doing mistakes
thankyou
Old 02-15-2016, 03:10   #2 (permalink)
Member: 322130
Thanks Meter: 57
With the new security you cannot simply unlock bootloader without enabling it from the menu. But sometimes, you may not have access to the menu to enable it.
To unlock bootloader using XTC 2 Clip please do the following:
1. Connect XTC 2 Clip to the Nexus 9 using Y-cable.
2. Boot to hboot.
3. Choose SIMLOCK menu. The phone will detect the clip and return to main menu.
4. Now disconnect Y cable and connect regular USB cable from PC.
5. Do 'fastboot oem unlock'.
6. Nexus 9 will erase all data and return to bootloader.
Now you can flash any firmware into your tablet.
hi
I follow this
The Following 2 Users Say Thank You to webzone136 For This Useful Post:
Old 02-17-2016, 13:33   #3 (permalink)
Member: 322130
Thanks Meter: 57
hi
can you help this unlock boot loader please
thankyou
Old 02-17-2016, 16:55   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by webzone136 View Post
hi
thankyou
Hello,
What's the problem? I thought you did it already.
Old 02-17-2016, 18:44   #5 (permalink)
Member: 322130
Thanks Meter: 57
no sir when I connect Y-cable sd adapter and tablet connect go to hbbot then simlock press its not detect clip on tablet please help
thankyou
Old 02-18-2016, 00:22   #6 (permalink)
Member: 322130
Thanks Meter: 57
https://www.youtube.com/watch?v=ysrB...ture=*********
Old 02-19-2016, 14:26   #7 (permalink)
Member: 2416253
Thanks Meter: 4,162
If I'm not wrong your power cord from Y cable is not attached anywhere ? You should plug it into PC, as it gets powered from it.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 02-19-2016, 16:36   #8 (permalink)
Member: 322130
Thanks Meter: 57
thankyou I connect usb to pc and when I go simlock on tablet
its freeze
thankyou
Old 02-25-2016, 17:18   #9 (permalink)
Member: 322130
Thanks Meter: 57
hi
please advice iam doing anything wrong to unlock bootloader
thankyou
Old 02-26-2016, 10:26   #10 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
hi
thankyou
please attach Y Cable to PC
Old 02-26-2016, 11:40   #11 (permalink)
Member: 322130
Thanks Meter: 57
hi
when I attach to pc to cable tablet go freeze
thankyou
Old 02-26-2016, 11:52   #12 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
hi
thankyou
change Y Cable and check...
Old 02-26-2016, 13:51   #13 (permalink)
Member: 322130
Thanks Meter: 57
igot 2 Y-cable and 3 microusb adapter still same
thankyou
Old 02-26-2016, 20:26   #14 (permalink)
Member: 2416253
Thanks Meter: 4,162
thankyou
Sorry, but as you understand it's hard to do anything remotely when it comes to hardware.
We have tested with our Nexus and it's working fine, other customers have reported success as well.
So please, make sure your Y cable schematic matches the one provided by us:
http://forum.gsmhosting.com/vbb/f961...cable-1977989/
Old 01-10-2017, 16:58   #15 (permalink)
Member: 2670841
I hard reboot the tablet and it freezes on detect smart sd LOADING OP82DIAG . zip
and even when i try and press simlock it freezes
Please help me!!!!!
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.44.1.0123
(bootloader) version-baseband: N/A
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP
(bootloader) version-mts: 33903942
(bootloader) cpu-revision: A03
(bootloader) serialno: HT4ADJT01165
(bootloader) cssn: 08ff00c020000000740d124700000001
(bootloader) imei: 355195000000010
(bootloader) meid: 00000000000000
(bootloader) product: flounder
(bootloader) variant:
(bootloader) platform: hTCBtegra
(bootloader) modelid: 0P8210000
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 4200mV
(bootloader) partition-layout: Generic
(bootloader) unlocked: verified
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 7acbd338
(bootloader) hbootpreupdate: 1
(bootloader) gencheckpt:
(bootloader) partition-size:hboot: 0x600000
(bootloader) partition-type:hboot: raw
Reading secure flag information... (bootloader) [ERR] Command error !!!
OKAY
Execution time is 11(ms)
Reading CID information
... (bootloader) cid: 11111111
OKAY
Execution time is 8(ms)
Reading MEID information
... (bootloader) meid: 00000000000000
OKAY
Execution time is 9(ms)
Read information completed.
Page generated in 0.24221 seconds with 9 queries
