Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 03-11-2019, 21:06   #1 (permalink)
Crazy Poster
Member: 2743735
[Request] Help Unlocking HTC One M7, M9 and Y-Cable
Hello,
I am trying to unlock my HTC One M9 T-Mobile phone. I do not see simlock under options when I try to unlock it when the device is directly connected into the phone.
Many of the posts I see are from years ago with a different firmware. The phone is version 7.0 of Android.
In addition, what is when set up for the y-cable? When I connect my y-cable my computer does not detect the XTC2Clip box.
Is this how it should be set up
Y
  • Micro USB - into phone
  • Male USB - into computer
  • Female USB - into Micro SD to USB converter into XTC2Clip
I also have an M7 I need to unlock and since it does not have a SD card reader I need to figure out the y cable so I may move forward with that as well.
imgur (dot) com /a/lmZld2q
Old 03-11-2019, 22:18   #2 (permalink)
Member: 2674678
Thanks Meter: 17
In ur pic I see SD mountet, so ur phone m9 has mount the xtx2clip.
Old 03-12-2019, 13:01   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
for m9 use special unlock tab selecting correct model and follow instructions
Old 03-12-2019, 14:39   #4 (permalink)
Crazy Poster
Member: 2743735
I copy the files onto the box but when I tried to do simlock tool this is what I see.
imgur (dot) com /OfnpoWH
Old 03-12-2019, 15:57   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
i think simlock menu should not come on screen
make repair clip and try again
http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/
Old 03-12-2019, 18:05   #6 (permalink)
Crazy Poster
Member: 2743735
I did this but now I can't boot to FTM, when I use the XTC2Clip software to go into this mode the phone reboots and turns on.
Old 03-13-2019, 08:22   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Did u try sim now ?
Check if unlocked or not
Check clip if log txt created
Sent from my iPhone using Tapatalk
Old 03-13-2019, 14:45   #8 (permalink)
Crazy Poster
Member: 2743735
I put a new sim and it looks fine, but in download mode it still says LOCKED.
Old 03-13-2019, 16:44   #9 (permalink)
Crazy Poster
Member: 2743735
I tried it on a Spring M9, but after it still says sim locked.
Old 03-13-2019, 16:52   #10 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Sprint m9 use sprint tab
Old 04-10-2019, 20:49   #11 (permalink)
Crazy Poster
Member: 2743735
I did, but after following the instructions it doesn't seem to be unlocked.
Old 04-12-2019, 08:41   #12 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
when unlock is success do not reset phone as per last instruction in software
insert gsm sim and select gsm option in network options
Old 04-12-2019, 17:36   #13 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello sir,
I just wonder if you finally could S-OFF your phone?
Old 04-12-2019, 19:32   #14 (permalink)
Crazy Poster
Member: 2743735
For the M7, no. M9 yes.
Page generated in 0.25068 seconds with 8 queries
