Success stories :) Hello, If you want to report a success story - please use this thread. This will help other customers ;):cool: |
HTC M7 make s-off and supper CID done http://images.tapatalk-cdn.com/15/07...cdcc967de2.jpg http://images.tapatalk-cdn.com/15/07...9f70388efd.jpg http://images.tapatalk-cdn.com/15/07...c17b5dff39.jpg Sent from my iPhone using Tapatalk |
HTC Desire C S-off Direct Mode With XTC2CLIP HTC Desire C S-off Direct Mode With XTC2CLIP Here the some Screenshots ., How to do S-OFF Direct mode http://www.smart-gsm.net/xtc2clip/dc/XTC2CLIP-D300.jpg http://www.smart-gsm.net/xtc2clip/dc...-D300-SOFF.jpg After S-OFF Sucessfully ., Reboot phone in Bootloader mode and Read Phone information again http://www.smart-gsm.net/xtc2clip/dc...300-SOFF-1.jpg |
HTC Desire C CID Change SD Mode With XTC2clip Here the Some Screenshots http://www.smart-gsm.net/xtc2clip/dc...D300-CIDSD.jpg http://www.smart-gsm.net/xtc2clip/dc/HTCDCSD.jpg http://www.smart-gsm.net/xtc2clip/dc/HTDDC.png |
I don't know How to Say it, But IT's AMAZING box REALLY for HTC I just receive it and two HTC M8 S-off and super CID already Done. Thanks Support, we need a support for Flash File if it's possible . Thanks Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 6 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078256 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:272 (bootloader) Start Verify: 3 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery Execution time is 9375(ms) OKAY Operation finished Phone connected ! CID value has been set to super-cid. Please save to SD card and use in phone Phone connected ! |
htc desire 510 Htc desire 510 unlock s-off ok :) info read after offline unlock mode Sending getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 01.02.012_U10251_39.08.40922 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.51.401.2 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: CC499Y400282 (bootloader) imei: 353450060860475 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: a11_ul (bootloader) platform: hTCBmsm8916 (bootloader) modelid: 0PCV20000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 3532d7cc (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 1001 Execution time is 27(ms) all: Done! Sending oem readsecureflag ... (bootloader) secure_flag: 0 Execution time is 20(ms) OKAY |
M7_ul super CID done in less than 30 seconds via SD editor.Operation was so easy,just in a blink of an eye.Hope for more updates and maybe htc full rom collection availablity. Thanks so much |
Htc m9 unlock Htc m9 t-mob usa s-off super cid 11111111 & unlock done xtc2clip |
Htc one m7_ul unlock done Regards |
htc velocity 4g x710s imei change super cid DONE @ thank you Team :) |
htc one x 15 pcs unlock done :http://forum.gsmhosting.com/vbb/f961...-tell-1965321/ |
HTC M7 make s-off and supper CID done 2 Attachment(s) HTC M7 make s-off and supper CID done Writing information to service files on SD card... CID settings saved Security settings saved Done. Attachment 339408 Attachment 339407 |
i have m7-ul and i can not make s-off with tool can u help me the phone showing SD INIT FAIL |
successfully s-off htc m8 sprint harman/kardon (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078256 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:267 (bootloader) Start Verify: 3 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery Execution time is 4187(ms) OKAY Operation finished Phone DISconnected |
