HTC M9 HIMA_UHL flashing sucesfull (repair bootloop): Starting flash process... target rom version: 4.17.161.11 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (224592 KB)... OKAY [ 14.491s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) adsp.img@100% (bootloader) cpe.img@100% (bootloader) rcdata.img@100% (bootloader) modem_st1.img@100% (bootloader) modem_st2.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 18.069s] finished. total time: 32.561s processing file 2/7... sending 'zip' (406656 KB)... OKAY [ 26.021s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_00@8% (bootloader) system.img_00@16% (bootloader) system.img_00@24% (bootloader) system.img_00@32% (bootloader) system.img_00@41% (bootloader) system.img_00@49% (bootloader) system.img_00@57% (bootloader) system.img_00@65% (bootloader) system.img_00@74% (bootloader) system.img_00@82% (bootloader) system.img_00@90% (bootloader) system.img_00@98% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 23.190s] finished. total time: 49.211s processing file 3/7... sending 'zip' (453058 KB)... OKAY [ 29.099s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_01@8% (bootloader) system.img_01@16% (bootloader) system.img_01@24% (bootloader) system.img_01@33% (bootloader) system.img_01@41% (bootloader) system.img_01@49% (bootloader) system.img_01@58% (bootloader) system.img_01@66% (bootloader) system.img_01@74% (bootloader) system.img_01@82% (bootloader) system.img_01@91% (bootloader) system.img_01@99% (bootloader) system.img_01@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 17.720s] finished. total time: 46.820s processing file 4/7... sending 'zip' (438724 KB)... OKAY [ 28.106s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_02@8% (bootloader) system.img_02@16% (bootloader) system.img_02@24% (bootloader) system.img_02@33% (bootloader) system.img_02@41% (bootloader) system.img_02@49% (bootloader) system.img_02@57% (bootloader) system.img_02@66% (bootloader) system.img_02@74% (bootloader) system.img_02@82% (bootloader) system.img_02@90% (bootloader) system.img_02@99% (bootloader) system.img_02@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 17.740s] finished. total time: 45.846s processing file 5/7... sending 'zip' (453362 KB)... OKAY [ 29.130s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_03@8% (bootloader) system.img_03@16% (bootloader) system.img_03@24% (bootloader) system.img_03@33% (bootloader) system.img_03@41% (bootloader) system.img_03@49% (bootloader) system.img_03@57% (bootloader) system.img_03@66% (bootloader) system.img_03@74% (bootloader) system.img_03@82% (bootloader) system.img_03@90% (bootloader) system.img_03@99% (bootloader) system.img_03@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 18.133s] finished. total time: 47.263s processing file 6/7... sending 'zip' (290129 KB)... OKAY [ 19.049s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_04@11% (bootloader) system.img_04@23% (bootloader) system.img_04@34% (bootloader) system.img_04@46% (bootloader) system.img_04@57% (bootloader) system.img_04@69% (bootloader) system.img_04@80% (bootloader) system.img_04@92% (bootloader) system.img_04@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 13.683s] finished. total time: 32.733s processing file 7/7... sending 'zip' (13483 KB)... OKAY [ 1.902s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) get 2 images from zip(zip_type=3) (bootloader) start@2 (bootloader) dzdata_32g.img@100% (bootloader) boot_signed.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.089s] finished. total time: 8.992s rompack updated Flash process completed. Restarting phone... rebooting... finished. total time: 0.009s htc_fastboot finished Phone DISconnected |
Thanks for the quick response. My two clips work again. Super servis for Xtc2clip. Thanks again to xtc2clip Product Manager. |
HTC D530 unlock done in 5 mins s-off using power adapter Code: 1. Checking phone connectivity....... Code: =============================== |
m8s s-off done 4/4/2019 6:32:47 AM Sending oem writesecureflag 0 4/4/2019 6:32:48 AM ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8qlul_init_sd, SD card already power on (bootloader) m8qlul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 4/4/2019 6:32:49 AM (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: 4/4/2019 6:32:49 AM (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -1921008540 (bootloader) erase_grpmult: -1921008668 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found 4/4/2019 6:32:52 AM (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:382 (bootloader) Start Verify: 3 4/4/2019 6:32:52 AM (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery OKAY |
htc 10 s-off done after flashing twrp Please wait, preparing your phone... HTC 10 detected Android release: 8.0.0 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, processing your request... Finished. Your phone will be S-OFF on restart. Phone DISconnected |
xtc 2 clip new active pls anytime help me |
HTC Desire 610 A3_UL LOGO HANG DONE HTC Desire 610 A3_UL LOGO HANG DONE http://blog.prasadcellcare.com/wp-co...-27_170747.png BRO PRASAD |
HTC A9 2pq9100 FRP Code: Starting FRP unlock procedure |
Trying to connect in Sprint mode... Trying to connect on COM518 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, generating unlock hash... Process finished SUCCESSFULLY Please restart your phone for the changes to take effect Note: If your phone is M7 - please do S-OFF first and then unlock again In case of calls/network problems, please do reset by: Open phone dialer, type ##786#, wait for the menu to appear Press MENU in top right corner and select RESET Enter SPC code Wait for the phone to verify the code and reboot Phone DISconnected Phone connected [FA5CTSY00009] *** ADB mode HTC SENSE |
htc 728w frp done one click Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Removing FRP ... Done. FRP was removed. Phone DISconnected Detected phone in mass-storage mode, trying to switch to ADB... Successfully Detected phone in mass-storage mode, trying to switch to ADB... Successfully |
htc 720 frp done Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Removing FRP ... Done. FRP was removed. Phone DISconnected |
... OKAY Execution time is 33(ms) imei: 356061061045425 Execution time is 2(s) FAILunknown command getvar:modelid FAILED (remote: unknown command) Execution time is 3(ms) FAILunknown command getvar:cidnum FAILED (remote: unknown command) Execution time is 2(ms) sending 'zip'... (240356 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) GPT is up-to-dated. [524288] (bootloader) Perform pre-update (bootloader) start@12 (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) apppreload.img@BYPASS (bootloader) cota.img@BYPASS (bootloader) preloader.bin@100% (bootloader) lk_verified.bin@100% (bootloader) hosd_verified.img@100% (bootloader) boot_verified.img@BYPASS (bootloader) recovery_verified.img@BYPASS (bootloader) tee1.img@100% (bootloader) logo_verified.bin@100% (bootloader) Perform hardware reset (bootloader) tee2.img@100% (bootloader) secro_verified.img@100% FAIL90 hboot pre-update! please flush image again immediately FAILED (remote: 90 hboot pre-update! please flush image again immediately) For "hboot-preupdate" response, restart the same procedure for device LC56TYF05073... sending 'zip'... (240356 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) GPT is up-to-dated. [524288] (bootloader) start@12 (bootloader) pg2fs_ship_signkey.img@100% (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) cota.img@100% (bootloader) preloader.bin@100% (bootloader) lk_verified.bin@100% (bootloader) hosd_verified.img@100% (bootloader) boot_verified.img@100% (bootloader) recovery_verified.img@100% (bootloader) tee1.img@100% (bootloader) tee2.img@100% (bootloader) secro_verified.img@100% (bootloader) logo_verified.bin@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (348849 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@1 (bootloader) system.img_00@11% (bootloader) system.img_00@22% (bootloader) system.img_00@33% (bootloader) system.img_00@44% (bootloader) system.img_00@55% (bootloader) system.img_00@66% (bootloader) system.img_00@77% (bootloader) system.img_00@88% (bootloader) system.img_00@99% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (377860 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@1 (bootloader) system.img_01@11% (bootloader) system.img_01@22% (bootloader) system.img_01@33% (bootloader) system.img_01@44% (bootloader) system.img_01@55% (bootloader) system.img_01@66% (bootloader) system.img_01@77% (bootloader) system.img_01@88% (bootloader) system.img_01@99% (bootloader) system.img_01@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (283458 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@1 (bootloader) system.img_02@10% (bootloader) system.img_02@21% (bootloader) system.img_02@32% (bootloader) system.img_02@43% (bootloader) system.img_02@54% (bootloader) system.img_02@65% (bootloader) system.img_02@76% (bootloader) system.img_02@87% (bootloader) system.img_02@98% (bootloader) system.img_02@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (300774 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@1 (bootloader) system.img_03@11% (bootloader) system.img_03@22% (bootloader) system.img_03@33% (bootloader) system.img_03@44% (bootloader) system.img_03@55% (bootloader) system.img_03@66% (bootloader) system.img_03@77% (bootloader) system.img_03@88% (bootloader) system.img_03@99% (bootloader) system.img_03@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (292826 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@1 (bootloader) system.img_04@11% (bootloader) system.img_04@22% (bootloader) system.img_04@33% (bootloader) system.img_04@44% (bootloader) system.img_04@55% (bootloader) system.img_04@66% (bootloader) system.img_04@77% (bootloader) system.img_04@88% (bootloader) system.img_04@99% (bootloader) system.img_04@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (224097 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@1 (bootloader) system.img_05@12% (bootloader) system.img_05@25% (bootloader) system.img_05@38% (bootloader) system.img_05@51% (bootloader) system.img_05@64% (bootloader) system.img_05@76% (bootloader) system.img_05@89% (bootloader) system.img_05@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY sending 'zip'... (154 KB) OKAY writing 'zip'... (bootloader) HOSD CL#626611 (bootloader) start@2 (bootloader) userdata.img@49% (bootloader) userdata.img@99% (bootloader) userdata.img@100% (bootloader) cache.img@100% (bootloader) Update zip file OK (bootloader) end@Done sending time = 15.690 secs OKAY Flash Zip Complete Execution time is 359(s) sending time = 14.771 secs sending time = 20.366 secs sending time = 22.263 secs sending time = 16.918 secs sending time = 18.151 secs sending time = 17.406 secs sending time = 13.625 secs sending time = 1.091 secs rebooting... Execution time is 4(ms) |
Desire 820, unlock done in 3 minutes!:) |
HTC M7 Mini Flash done Starting flash process... target rom version: 7.19.401.51 found large-zip header, file count: 5 processing file 1/5... sending 'zip' (50228 KB)... OKAY [ 3.260s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [hboot], please wait... Processing [hboot], please wait... (bootloader) ...... Successful FAILED (remote: 90 hboot pre-update! please flush image again immediately) finished. total time: 5.086s preupdate done, rebooting... Phone DISconnected Phone connected [HT3BVW903125] *** Fastboot mode resending command... sending 'zip' (50228 KB)... OKAY [ 3.089s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [sp1], please wait... (bootloader) ...... Successful Processing [sbl2], please wait... (bootloader) ...... Successful Processing [sbl3], please wait... (bootloader) ...... Successful Processing [tz], please wait... (bootloader) ...... Successful Processing [rpm], please wait... (bootloader) ...... Successful Processing [adsp], please wait... (bootloader) ...... Successful Processing [pg2fs_spcustom], please wait... (bootloader) ...... Successful Processing [tp], please wait... (bootloader) ...... Successful Processing [sbl1-1], please wait... (bootloader) signature checking... (bootloader) verified fail (bootloader) ..... Bypassed Processing [sbl1-2], please wait... (bootloader) signature checking... (bootloader) verified fail (bootloader) ..... Bypassed Processing [sbl1-3], please wait... (bootloader) signature checking... (bootloader) ...... Successful Processing [cir], please wait... (bootloader) ...... Successful Processing [sbl1-4], please wait... (bootloader) signature checking... (bootloader) verified fail (bootloader) ..... Bypassed Processing [sbl1-5], please wait... (bootloader) signature checking... (bootloader) verified fail (bootloader) ..... Bypassed Processing [recovery], please wait... (bootloader) ...... Successful Processing [boot], please wait... (bootloader) ...... Successful Processing [radio], please wait... (bootloader) ...... Successful Processing [rcdata], please wait... (bootloader) ...... Successful OKAY [ 60.064s] finished. total time: 63.153s processing file 2/5... sending 'zip' (521930 KB)... OKAY [ 25.692s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [system], please wait... (bootloader) ...... Successful OKAY [ 73.199s] finished. total time: 98.891s processing file 3/5... sending 'zip' (552062 KB)... OKAY [ 25.355s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [system], please wait... (bootloader) ...... Successful OKAY [ 75.220s] finished. total time: 100.591s processing file 4/5... sending 'zip' (25433 KB)... OKAY [ 2.160s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [system], please wait... (bootloader) ...... Successful OKAY [ 16.546s] finished. total time: 18.706s processing file 5/5... sending 'zip' (499309 KB)... OKAY [ 23.538s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [dzdata], please wait... (bootloader) ...... Successful Processing [tp], please wait... (bootloader) ..... Bypassed Processing [boot], please wait... (bootloader) ...... Successful OKAY [ 21.770s] finished. total time: 45.309s rompack updated HBoot pre-update sequence Flash process completed. Restarting phone... rebooting... finished. total time: 0.046s htc_fastboot finished Phone DISconnected |
