Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 08-08-2015, 15:56   #16 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 130
When team update fix error IMSI Sim Lock for HTC ?
Old 08-08-2015, 16:51   #17 (permalink)
Member: 1538766
Sonork: 1626907
Thanks Meter: 18
please add for htc windows phone, for example htc radar, omega, etc
thanks
Old 08-09-2015, 00:20   #18 (permalink)
Member: 2078045
Thanks Meter: 151
wold first tool change htc security on a security off good idea
Old 08-09-2015, 02:06   #19 (permalink)
Member: 2335578
Thanks Meter: 105
nvm.....................................
Old 08-09-2015, 02:07   #20 (permalink)
Member: 2335578
Thanks Meter: 105
Starting bootloader unlock procedure
Phone detected, reading token...
Error: Unexpected token format:
... (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp
(bootloader) [KillSwitch] Last Byte is 0X00, disable unlock
(bootloader) [KillSwitch] oem unlock Turn Off!
Execution time is 87(ms)
OKAY
Old 08-09-2015, 04:20   #21 (permalink)
Member: 2372105
Sonork: 100.1667845
Thanks Meter: 61
HTC bootloader unlock all features very cool, it makes things extremely easy carrying. Thanks XTC .....
Old 08-09-2015, 04:21   #22 (permalink)
Member: 455296
Sonork: xxxxxxxxx
Thanks Meter: 66
- Bootloader Unlock, Doest it wipe Device?!
Old 08-09-2015, 07:12   #23 (permalink)
Member: 2420279
Thanks Meter: 22
I tried the unlock on my Verizon M8, with CID VZW__001, and got the following output
Token detected successfully
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Sending flash unlocktoken unlocktoken_HT435SF03725 . bin
Execution time is 151(ms)
sending 'unlocktoken' (0 KB)... OKAY
writing 'unlocktoken'... FAILNot support on this device!
FAILED (remote: Not support on this device!)
Error: The unlock token was not accepted by the phone. Try to re-calculate it again.
So, first of all it failed for some reason.
Also, I'm wondering if it had been successful, would it have wiped my data?
P.S. There was no spaces between "unlocktoken_HT435SF03725 . bin" - but with only 3 posts, the forum thinks it is a link.
Old 08-09-2015, 10:57   #24 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
https://forum.gsmhosting.com/vbb/****************************/?2601t7azottbj1y
xtc2tool_1.07_setup - Download - 4shared
hope this will helpful for users
The Following User Says Thank You to kariakala For This Useful Post:
Old 08-09-2015, 17:45   #25 (permalink)
Member: 2213752
Sonork: http://forum.gsmhosting.c
I need to know more about XTC 2 tools, is it a dongle, box or software that i only instal on a system
Old 08-10-2015, 14:19   #26 (permalink)
Member: 2416253
Thanks Meter: 4,162
Yes it does. It will reset the device and unlock the bootloader.
Old 08-10-2015, 14:20   #27 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Some firmware/hboot versions do not allow bootloader unlock.
Usually you can simply reflash with any other generic firmware and then do the unlock.
And yes, it will wipe the data as it's needed for the unlocking process to be done, sorry.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 08-10-2015, 15:43   #28 (permalink)
Member: 784593
Thanks Meter: 15
please add modelid change support
Old 08-10-2015, 16:21   #29 (permalink)
Member: 2416253
Thanks Meter: 4,162
It's not a very good idea, because in most cases you will mess your phone.
However, you can change the modelid on some phones after S-OFF using writemid command.
Old 08-10-2015, 18:52   #30 (permalink)
Member: 170641
We thank the masters how health efforts
Page generated in 0.21174 seconds with 9 queries
