03-12-2018, 02:35 | #5431 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
03-12-2018, 02:35 | #5432 (permalink) | |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | lenovo a5000 patternlock solved Quote:
03-13-2018, 10:19 | #5433 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Bangladesh Age: 40
Member: 1703431 Status: Offline Sonork: 100.1619192 QQ 3271159180 Thanks Meter: 2,106 | Samsung_SM-J100H Apps Lock Removed With Format / Reset Done By CS-Tool Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM28 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA01 CPU_ID: 6572 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A2058494E5948 CHIP : MT65720000 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:19 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
03-13-2018, 10:21 | #5434 (permalink) |
Member: 1703431 Status: Offline Sonork: 100.1619192 QQ 3271159180 Thanks Meter: 2,106 | Samsung_SM-J100H Read Firmware Done By CS-Tool Code: Action : Read Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM17 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA01 CPU_ID: 6572 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A2058494E5948 CHIP : MT65720000 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Reading Project Property ... done. Making dir: C:\\MT6572_samsung_SM-J100H_Android4.4.2_ALPS.KK1.MP7.V1_20180311_125753\...[ok] Reading preloader ......ok New EMI config is detected, auto added it to User Database, cnt=5 Saved to: C:\Program Files\CS-Tool\CST_MainSoftware\private\db\emi\ Reading mbr ......ok Reading ebr1 ......ok Reading nvram ......ok Reading uboot ......ok Reading bootimg ......ok Reading recovery ......ok Reading sec_ro ......ok Reading logo ......ok Reading android ......ok Reading cache ......ok Reading usrdata ......ok All done. Files saved to: C:\\MT6572_samsung_SM-J100H_Android4.4.2_ALPS.KK1.MP7.V1_20180311_125753\ Action completed Time taken : 00:12:27 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
03-16-2018, 21:52 | #5436 (permalink) |
Registered User Join Date: Jan 2010 Location: France
Member: 1199489 Status: Offline Sonork: tarek Thanks Meter: 3 | Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM13 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: 0000 CPU_ID: 0633 Action completed Time taken : Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
03-16-2018, 21:52 | #5437 (permalink) |
03-17-2018, 07:55 | #5438 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Sonovo S105 No call Log reset Done!!! Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM253) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00EF004000160000 NOR Size : 4MB NOR Name : SF_W25Q32BV Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x003C0000, Size=0x00040000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
The Following User Says Thank You to sajid01913 For This Useful Post: |
03-17-2018, 16:38 | #5439 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | KIMFLY M4 READ INFO AND FORMATING DONE Code: Action : Read Info Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM11) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Reading Project Property ... Brand : M4 Phone Model : M4 Android Ver : 6.0 CPU/Processor : SP7731C_V1.0.0 SPD Project ver : sp7731c_1h10_32v4_oversea-user 6.0 MRA58K eng.lxt183.20170218.112817 release-keys SW Version : MRA58K release-keys Userdata State : Normal Action completed Time taken : 00:00:28 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
The Following User Says Thank You to fokal2008 For This Useful Post: |
03-17-2018, 16:57 | #5440 (permalink) | |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | psp3503duo reset all settings/frp 1.60 Quote:
03-17-2018, 16:58 | #5441 (permalink) | |
The Following User Says Thank You to Xaker2012 For This Useful Post: |
03-18-2018, 09:58 | #5442 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony D51i Password Reset Done Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM457 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB00 CPU_HW: 8000 CPU_ID: 6260 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6260 CPU ID : 00000000 NOR ID : 002C00CB00180000 NOR Size : 16MB NOR Name : [Numonyx] N25W128 NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Formatting ... Format done. Action completed Time taken : 00:01:25 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
03-18-2018, 09:59 | #5443 (permalink) |
03-18-2018, 10:01 | #5444 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Symphony i10 FRP Done Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM156 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6580 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100463832324D42 CHIP : MT65800000 CPU ID : EMMC ID : 150100463832324D42 EMMC Size: 16GB, usable capacity: 14.57GB EMMC Name: eMMC_Samsung_F822MB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:21 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
