01-23-2016, 17:39 | #1501 (permalink) |
No Life Poster Join Date: Sep 2011 Location: IN_YOUR_HEART
Member: 1661953 Status: Offline Sonork: 100.1666694 Thanks Meter: 1,377 | Qmobile R650 read security code with cs tool Qmobile R650 read security code with cs tool Code: Action : Read Codes Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM5 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6261 CPU_SW: CB01 CPU_HW: 8000 Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Reading ... password: 7070 password: 0003 Action completed Time taken : 00:00:34 Reconnect Battery/USB Cable CS-Tool Ver 1.38.4 raza400 |
01-24-2016, 11:48 | #1503 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A8 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6575 CPU_SW: E201 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. eMMC cid: 1501004E4A5330304D CHIP : MT6577 CPU ID : EMMC ID : 1501004E4A5330304D EMMC Size: 4GB, usable capacity: 3.64GB EMMC Name: eMMC_Samsung_KMNJS000ZM_B205 Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:12 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-24-2016, 11:50 | #1504 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A10 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6575 CPU_SW: E201 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. eMMC cid: 90014A2058494E5948 CHIP : MT6577 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:29 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-24-2016, 11:55 | #1505 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A60 Hang Logo Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6575 CPU_SW: E201 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. eMMC cid: 90014A2058494E5948 CHIP : MT6577 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:10 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-24-2016, 12:00 | #1506 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A300 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:08 Reconnect Battery/USB Cable CS-Tool Ver 1.38 |
01-24-2016, 17:05 | #1507 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | World's First QMOBILE X2 Music SPD Nand 7715 Format Code: Action : Format / Reset Boot : SC7715-NAND Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found : SCI USB2Serial (COM48) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... 1st Boot is done. Waiting for Boot init... Done. Switching Baudrate to 115200 Sending 2nd Boot... 2nd Boot done. Waiting for Boot init... Done. SC Boot Ver : 7715 SC Boot Mode : 7715A00000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC7715 CPU ID : 7715A000 NAND ID : 009800BC90660076906676 NAND Size: 512MB NAND Name: NAND_TYBC0A111236KC512 Boot Information completed. Loading CST Boot image to RAM... The CST Boot runs normally. Auto formatting... Format Done. Action completed Time taken : 00:00:17 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:19 | #1508 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A50 Hang Logo Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6575 CPU_SW: E201 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. eMMC cid: 90014A2058494E5948 CHIP : MT6577 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:11 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:20 | #1509 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A80 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6575 CPU_SW: E201 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. eMMC cid: 90014A2058494E5948 CHIP : MT6577 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:31 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:21 | #1510 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE A300 Imei Repaire Code: Action : Repair IMEI Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Warning !!! Imei changing is Illegal. Use this function to Restore Orginal Imei we are not responsible for illegal Act Waiting for Phone Usb... scanning the mtk usb device...... Phone found [ USB Port:COM30 ] Connecting... Phone found [ USB Port:COM30 ] Connecting... CPU: MT6572 Action completed Time taken : 00:00:00 Reconnect Battery/USB Cable CS-Tool Ver 1.38 Switching to Meta Mode... Waiting for mete ack... Done, reading... old IMEI: 352426060530152 old IMEI: 352426065530157 Repairing IMEI1: 352426060319143 done. Repairing IMEI2: 352426065319148 done. checking, pls wait ... [Restart the Phone To Verify New imei ] Action completed Time taken : 00:00:00 Reconnect Battery/USB Cable CS-Tool Ver 1.38 |
01-25-2016, 10:23 | #1511 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | SAMSUNG I8552 Hang Logo Write File Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A2058494E5948 CHIP : MT65720000 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Loading scatter file ... Read CFG done. Checking the firmware matches the current BB ... firmware is valid. Erasing all partitions ......ok Downloading preloader ......ok Updating rom info ......ok Updating partition table mirror ... Rebuild done. Downloading mbr ......ok Downloading ebr1 ......ok Downloading uboot ......ok Downloading bootimg ......ok Downloading recovery ......ok Downloading sec_ro ......ok Downloading logo ......ok Downloading android ......ok Downloading cache ......ok Downloading usrdata ......ok Downloading fat ......ok Updating rom info ......ok Updating partition table mirror ... Rebuild done. All done. Action completed Time taken : 00:03:01 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:31 | #1512 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | QMOBILE I6 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6582 CPU_SW: 0001 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 1501004B3758564D42 CHIP : MT65820000 CPU ID : EMMC ID : 1501004B3758564D42 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Samsung_K7XVMB Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:08 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:33 | #1513 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | SAMSUNG I9060 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6575 CPU_SW: E201 CPU_HW: CB00 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. eMMC cid: 1501004E4A5330304D CHIP : MT65750000 CPU ID : EMMC ID : 1501004E4A5330304D EMMC Size: 4GB, usable capacity: 3.64GB EMMC Name: eMMC_Samsung_KMNJS000ZM_B205 Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:18 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:34 | #1514 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | SAMSUNG J100 Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A2058494E5948 CHIP : MT65720000 CPU ID : EMMC ID : 90014A2058494E5948 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDMCPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:08 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
01-25-2016, 10:35 | #1515 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | SAMSUNG G530h Hang Format Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.61GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Resetting ... Resetting done. Action completed Time taken : 00:00:11 Reconnect Battery/USB Cable CS-Tool Ver 1.38.15 |
