05-29-2020, 16:27 | #63 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | How to Disable Screen Lock On Special in Redmi Y2&S2 because I have umt only if you can disable screen lock that mobile I Will be buy New Emmc activation & Buy New Emmc hardware special for this model because data important Please tell me Thanks & Regards By:All TECH 4 You |
05-30-2020, 07:06 | #65 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Sorry Sir Asking You I Have UMT Dongle Without Any Yearly Activation So In This Condition Can I Activate On This Dongle UMT EMMC TOOL Please Tell Me Thanks & Regards By:All TECH 4 You |
05-30-2020, 14:21 | #67 (permalink) |
Crazy Poster Join Date: Mar 2015
Member: 2357902 Status: Offline Thanks Meter: 5 | Please sir need to activate EMMC Hi Sir best UMT box please need to activate my box with EMMC tool Card connected, reading info. Serial: UMT304402761 Card have latest firmware, not need to update card firmware. Connecting to server, wait.. Sn: UMT304402761 Card state: Active Added: Monday 8 of May 2017 Active untill: Tuesday 14 of July 2020 Emmc addon is not activated in server Thanks in advace |
05-31-2020, 08:22 | #69 (permalink) | |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
I Do Borrow UMT To Other Person But Lock Still Same: Device : Xiaomi Redmi S2 Operation : Disable Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM443) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi S2 Software : PKQ1.181203.001, V11.0.5.0.PEFMIXM [Fri Mar 6 11:35:24 WIB 2020] Android Ver. : 9 Patch Level : 2020-03-01 USERDATA : Encrypted Disabling Android Locks...Done Operation Finished. QcFire Ver. 4.2 Note:I Also Try Read Pattern Lock & Reset Locks But Problem Still Same So Please Solve My Problem Thanks & Regards By:All TECH 4 You | |
05-31-2020, 18:56 | #71 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
06-04-2020, 08:24 | #73 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | I Do Again Borrow UMT To Other Person But Lock Still Same: Note:At This Time I Am Using 5.6 Latest Setup Version Device : Xiaomi Redmi S2 Operation : Disable Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM443) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi S2 [ysl] Software : PKQ1.181203.001, V11.0.5.0.PEFMIXM [Fri Mar 6 11:35:24 WIB 2020] Android Ver. : 9 Patch Level : 2020-03-01 USERDATA : Encrypted Disabling Android Locks...Done Operation Finished. QcFire Ver. 5.6 Note:I Also Try Read Pattern Lock & Reset Locks But Problem Still Same So Please Solve My Problem Thanks & Regards By:All TECH 4 You |
06-06-2020, 20:35 | #74 (permalink) | |
Br, UMT | |
06-10-2020, 09:59 | #75 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Finally My Problem Solved Code: Operation : Disable Screen Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM443) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi S2 [ysl] Software : PKQ1.181203.001, V11.0.5.0.PEFMIXM [Fri Mar 6 11:35:24 WIB 2020] Android Ver. : 9 Patch Level : 2020-03-01 USERDATA : Encrypted Disabling Screen Locks...Done Operation Finished. QcFire Ver. 5.5.1 Thanks & Regards By:All TECH 4 You |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
