07-07-2020, 15:13 | #51 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,445 | Quote:
To check if device is supported or not, simply goto Device Manager and check if the device you want to use with UMT EMMC lists under Disk Drive section. If it is listed in other section, you can not use it with UMT EMMC. Br, UMT | |
07-15-2020, 17:16 | #52 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Oppo a1k password & frp done Code: Opening Device...Done Physical Details: Chip Size : 0x747C00000 [29.12 GB] Sector Size : 0x0200 Sector Count : 0x03A3E000 Reading Partition Data...OK Header Rev. : 0x00010000 Header Size : 0x5C Header CRC : 0x68AF0716 Current LBA : 0x00000001 Backup LBA : 0x03A3DFFF First LBA : 0x00000022 Last LBA : 0x03A3DFDE PIT Entry Size : 0x80 Disk GUID : 00000000000000000000000000000000 Sector Size : 0x0200 Parsing Partition Entries...OK Part Count : 44 Reading Device Information...OK Device : OPPO Android Ver. : 9 Patch Level : 2019-10-05 Formatting Userdata in Safe Mode...Done Turn on device to finalize operation. Operation Finished. Resetting FRP...Done Operation Finished. |
The Following 6 Users Say Thank You to Yusuf Lawal For This Useful Post: |
07-30-2020, 18:58 | #56 (permalink) | |
But Software will only show it when eMMC is correctly connected. Br, UMT | |
The Following User Says Thank You to U.M.T For This Useful Post: |
08-14-2020, 13:06 | #58 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Where to location operation log folder? If not available, please add in next update.. Thanks in advance. MEANWHILE OPPO A3S CPH1853 PASSWORD & FRP RESET DONE. |
The Following 3 Users Say Thank You to Yusuf Lawal For This Useful Post: |
08-15-2020, 05:32 | #59 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | According to research, we have two types of oppo A3s; (cph1803 & cph1853). In umt emmc tool there is only one isp pinout image exist, please add second pinout image. Thanks in advance. |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
08-22-2020, 14:07 | #60 (permalink) |
Registered User Join Date: Nov 2014 Location: PAKISTAN
Member: 2292286 Status: Offline Thanks Meter: 20 | 2 Resistance of 150omh is mandatory or not? Oppo A1k cph1923 Clk+Cmd+data0+Gnd is mandatory and For Vcc and Vccq use Usb cable my question is that 2 Resistance of 150omh should be attache or no need of that resistance kindly guide and reply. |
