08-24-2020, 15:49 | #61 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: Live pakistan Age: 46
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | A5_2020 without data loss done umt Quote:
The Following 5 Users Say Thank You to umardarz For This Useful Post: |
08-31-2020, 17:51 | #63 (permalink) |
Banned Join Date: Feb 2014 Location: hyderabad
Member: 2130342 Status: Offline Thanks Meter: 33 | thanks umt team good update Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 6 Pro [******_india] Brand : xiaomi Prod.Name : ******_india Software : ZQL1715-******_india-build-20200508170427, V11.0.7.0.PDMMIXM [Fri May 8 17:05:54 CST 2020] Android Ver. : 9 Patch Level : 2020-05-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.0 |
09-05-2020, 08:30 | #67 (permalink) | |
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | oppo A3S PIN LOCK DONE Quote:
The Following User Says Thank You to umardarz For This Useful Post: |
10-02-2020, 14:54 | #71 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | Oppo A3S Pattern Unlock Done Oppo A3S Pattern Unlock Done via Great UMT |
The Following 3 Users Say Thank You to nafe2me For This Useful Post: |
10-13-2020, 09:23 | #72 (permalink) |
Insane Poster Join Date: Oct 2015 Location: LAGOS/ NIGERIA
Member: 2478245 Status: Offline Sonork: 100.1669922:JOTECH Thanks Meter: 10 | Kindly assit me on what could be the solution to this problem. Using UMT EMMC tool on Redmi 7 onc. After writhing bootloader unlock file successfully, Phone stucks in Qualcomm HS-USB QDLoader 9008 mode, cant power on |
10-17-2020, 13:35 | #73 (permalink) |
Junior Member Join Date: Nov 2016 Location: Toba Tek Singh
Member: 2647694 Status: Offline Thanks Meter: 10 | Realme 5 done Opening Device...Done Physical Details: Chip Size : 0xE8F800000 [58.24 GB] Sector Size : 0x0200 Sector Count : 0x0747C000 Reading Partition Data...OK Header Rev. : 0x00010000 Header Size : 0x5C Header CRC : 0x68C4AF0C Current LBA : 0x00000001 Backup LBA : 0x0747BFFF First LBA : 0x00000022 Last LBA : 0x0747BFDE PIT Entry Size : 0x80 Disk GUID : 9EBA3F13875D1FCA5D11678CE42C7000 Sector Size : 0x0200 Parsing Partition Entries...OK Part Count : 69 Reading Device Information...OK Device : realme Android Ver. : 9 |
The Following User Says Thank You to Rajputgsm For This Useful Post: |
11-06-2020, 11:17 | #75 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Serbia Age: 40
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | Hi, i tired to find OPPO Find X PAFM00 ISP pinout but unsuccessful, is it even possible to use emmc 0.3 for this model to remove user lock? thanks in advance wbr |
