Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 08-24-2020, 15:49   #61 (permalink)
umardarz's Avatar
Member: 1054358
Sonork: 100.1626312
Thanks Meter: 269
A5_2020 without data loss done umt
Opening Device...Done
Physical Details:
Chip Size : 0xE8F800000 [58.24 GB]
Sector Size : 0x0200
Sector Count : 0x0747C000
Reading Partition Data...OK
Header Rev. : 0x00010000
Header Size : 0x5C
Header CRC : 0x0916B12B
Current LBA : 0x00000001
Backup LBA : 0x0747BFFF
First LBA : 0x00000022
Last LBA : 0x0747BFDE
PIT Entry Size : 0x80
Disk GUID : E2E7CCB75B4A9283D2481B0291968F6C
Parsing Partition Entries...OK
Part Count : 86
Reading Device Information...OK
Device : OPPO
Android Ver. : 9
Formatting Userdata in Safe Mode...Done
Turn on device to finalize operation.
Operation Finished.
The Following 5 Users Say Thank You to umardarz For This Useful Post:
Old 08-25-2020, 07:55   #62 (permalink)
Member: 2052925
Thanks Meter: 7
Xiaomi Redmi 6A can I remove the code without deleting the data ? supported ?
Old 08-31-2020, 17:51   #63 (permalink)
Member: 2130342
Thanks Meter: 33
thanks umt team good update
Operation : Reset FRP
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM4)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1600400 [8953] 00000000
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8953]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Requesting UMT Auth Service (FREE)...OK
Detecting Chip Type...OK
Hardware : 8953, eMMC, 32 GB
LU Count : 1 [0x03A3E000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Reading Partition Table...OK
Device : Xiaomi Redmi 6 Pro [******_india]
Brand : xiaomi
Prod.Name : ******_india
Software : ZQL1715-******_india-build-20200508170427, V11.0.7.0.PDMMIXM [Fri May 8 17:05:54 CST 2020]
Android Ver. : 9
Patch Level : 2020-05-01
Resetting FRP Lock......Done
Operation Finished.
QcFire Ver. 6.0
The Following 2 Users Say Thank You to SKNAGA For This Useful Post:
Old 08-31-2020, 20:10   #64 (permalink)
Member: 2145475
Thanks Meter: 100
Thanks UMT Team plz add smartisan pro 2s
Old 09-01-2020, 23:16   #65 (permalink)
Member: 1633439
Sonork: 100.1606152
Thanks Meter: 71
please add Samsung galaxy Note 5 N920T/N920C dump file and
emmc pinout..
thanks....
great team UMT TOOLS...
Old 09-02-2020, 08:55   #66 (permalink)
Member: 1677653
Thanks Meter: 2,769
As anyone confirm if redmi 7 mi account can be solve with umt emmc?
Thanks in advance.
Old 09-05-2020, 08:30   #67 (permalink)
umardarz's Avatar
Member: 1054358
Sonork: 100.1626312
Thanks Meter: 269
oppo A3S PIN LOCK DONE
Physical Details:
Chip Size : 0x3AB400000 [14.68 GB]
Sector Count : 0x01D5A000
Header Size : 0x5C
Header CRC : 0xD4DDDA8F
Backup LBA : 0x01D59FFF
Last LBA : 0x01D59FDE
Disk GUID : 321B1098E2BBF24BA06E2BB33D000C20
Part Count : 67
Device : OPPO
Android Ver. : 8.1.0
Patch Level : 2020-04-05
The Following User Says Thank You to umardarz For This Useful Post:
Old 09-05-2020, 18:09   #68 (permalink)
Member: 2145475
Thanks Meter: 100
Sir plz add smartisan pro 2s add edl mode reset lock & frp option thanks in advance
Old 09-06-2020, 10:45   #69 (permalink)
umardarz's Avatar
Member: 1054358
Sonork: 100.1626312
Thanks Meter: 269
Originally Posted by fidelenty View Post
PLEASE team help in next update if possible add
boot repair options-- write and read boot1, boot2, ex csd
i think not possible
Old 09-17-2020, 16:18   #70 (permalink)
mondhert's Avatar
Member: 63299
Sonork: 100.1616476
Thanks Meter: 11
pls help can't find oppo f9 in list umt emmc tool v0.3
Old 10-02-2020, 14:54   #71 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
Oppo A3S Pattern Unlock Done
Oppo A3S Pattern Unlock Done via Great UMT
The Following 3 Users Say Thank You to nafe2me For This Useful Post:
Old 10-13-2020, 09:23   #72 (permalink)
Member: 2478245
Sonork: 100.1669922:JOTECH
Thanks Meter: 10
Kindly assit me on what could be the solution to this problem. Using UMT EMMC tool on Redmi 7 onc. After writhing bootloader unlock file successfully, Phone stucks in Qualcomm HS-USB QDLoader 9008 mode, cant power on
Old 10-17-2020, 13:35   #73 (permalink)
Member: 2647694
Thanks Meter: 10
Realme 5 done
Physical Details:
Header Size : 0x5C
Header CRC : 0x68C4AF0C
Disk GUID : 9EBA3F13875D1FCA5D11678CE42C7000
Part Count : 69
Device : realme
Android Ver. : 9
The Following User Says Thank You to Rajputgsm For This Useful Post:
Old 10-24-2020, 11:17   #74 (permalink)
Member: 2696154
nice update.....thanks team
Old 11-06-2020, 11:17   #75 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
Hi, i tired to find OPPO Find X PAFM00 ISP pinout but unsuccessful, is it even possible to use emmc 0.3 for this model to remove user lock?
thanks in advance
wbr
Page generated in 0.22145 seconds with 8 queries
