Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 09-29-2018, 19:33   #1 (permalink)
Durgaraob's Avatar
Member: 1873923
Thanks Meter: 41
Umt working or not for redmi note5 pro 8.1.0 ?????
Does umt working or not
Note 5 pro 8.1.0 mi account
Old 09-29-2018, 19:39   #2 (permalink)
Member: 2684136
Thanks Meter: 85
Redmi Note 5 Pro (Test)
-- Alternative Loader for Devices not supported in Auto Mode.
-- Need to select Brand and Model manually in Qcfire 2.9
Old 09-29-2018, 19:55   #3 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,557
You need to use Test Model only if Auto Method does not work.
Br,
UMT
Old 09-30-2018, 04:02   #4 (permalink)
Member: 1862559
Thanks Meter: 4
Not Done
Not Working
Device : Xiaomi Redmi Note 5 Pro (Test)
Operation : Reset Mi Account
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM31)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1C00C00 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Preparing Loader...Done
Sending Loader [Note5Pro]...Done
Executing Loader...OK
Detecting Chip Type...Failed
VIP Enabled / Auth Enabled Device!
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5=
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 2.9
Old 09-30-2018, 05:26   #5 (permalink)
Riz_Mobile's Avatar
Member: 2559216
Thanks Meter: 220
Originally Posted by crackpad View Post
Not Working
Operation Finished.
QcFire Ver. 2.9
Sometime i was also get this error,error belongs to wrong driver,connection between device and pc and data cable.
Try install latest drivers
Make sure battery is connected in mob.
Use another port/cable.
Note-the above problem is confirmed bcoz i tested Lower and latest higher version of firmware is working in qcfir.
Old 09-30-2018, 07:46   #6 (permalink)
Member: 1623940
Thanks Meter: 22
Use 2.8
not working
device : Xiaomi redmi note 5 pro (test)
operation : Reset mi account
checking for existing devices...not found
turn off phone, hold vol up + vol down and insert usb cable.
Some phones may need special boot cable or testpoint for edl mode.
Found port : Qualcomm hs-usb qdloader 9008 (com31)
driver info : Qualcomm incorporated, qcusbser.sys, 2.1.2.2
connecting to phone...ok
waiting for response...ok
init handshake sequence...ok
hardware id : E1c00c00 [8996] 00000000
opk_data : F7337fe47b192ef4d1ba34cb4e879f0c6b771d06d2de87bf21 f65ba3303834e1
initializing protocol...ok
preparing loader...done
sending loader [note5pro]...done
executing loader...ok
detecting chip type...failed
vip enabled / auth enabled device!
Error log : Pd94bwwgdmvyc2lvbj0ims4wiiblbmnvzgluzz0ivvrgltgiid 8+cjxkyxrhpgo8bg9nihzhbhvlpsjfuljpujogt25sesbub3ag yw5kihnpzyb0ywcgy2fuigjlihjly2v2awvkigjlzm9yzsbhdx rozw50awnhdglvbi4ilz4kpc9kyxrhpjw/eg1sihzlcnnpb249ijeumcigzw5jb2rpbmc9ilvuri04iia/pgo8zgf0yt4kphjlc3bvbnnlihzhbhvlpsjoqusiic8+cjwvzg f0yt5=
please use correct loader and check usb port / cable.
Operation finished.
Qcfire ver. 2.9
i have same issue, just use 2.8ver
problem solved
Old 09-30-2018, 07:56   #7 (permalink)
Registered User
zakirn's Avatar
Member: 7457
Thanks Meter: 21
REDMI note 5 pro 10000000% working with version 9.5.13 after mi account unlock its lost wifi, not worry use update with versionn 10.0 make it factory reset with sideload. now all clear, everything is ok. use qualcomm 2.8
Page generated in 0.26031 seconds with 8 queries
