Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
11-06-2007, 23:23 | #16 (permalink) |
Junior Member Join Date: Feb 2004 Location: POLAND Age: 47
Member: 52559 Status: Offline Thanks Meter: 2 | I have this TP cable: http://polphone.pl/u/p2489_Smart_Clip_TP_Cable.php |
The Following User Says Thank You to kulca For This Useful Post: |
02-27-2009, 03:30 | #21 (permalink) |
Junior Member Join Date: Jan 2009
Member: 947541 Status: Offline Thanks Meter: 0 | Hi friends You know its very easy to unlock any Moto V3 to V3xx Etc Just in a minute ok im sharing here my experiance (but keep in mind it can work for u as for me 10000% but u have to go in a right way) 1.Install p2k commader (for you link is here) http://s5vi.vxxxstuff.com/ its a simple software as u know for exploring al moto Phone First STEP :Important is You have to install Only p2k Driver (its in directory of installed p2k) for you moto Modem otherwise it will not work If u can see in your device manager there is Motorola USb modem installed by Original Driver of Moto so Update it with p2k commader Driver. Now Time to UNLOCK Open P2k Commander Go to OPTIONS Click on P2k/P2k05 Down P2K tunning 'select Safe Slow (if u got any error just try to change setting When Ru again Before Connect ur phone) Click on USE P2K Command Override... (if u have V3xx These above setting if not work for u to detect your phone try keep changing defferent Settings Sure it will work NOW Click OK Connect Your Phone and Install P2k Driver (If ask again) On Down Window U Should see Phone connected (if not means Phone not detected or Driver is not P2k) If this Success then on Mian Window (any Right of Left Doesnt matter ) Select " /a P2K Phone System |"It will Start your Phone Data reading and Show u on Window UP (mostly here Poeples have problem or Error because of wrong setting in OPTIONS So Use your brian i know u can do it) it will show u /a (Directory of Your Moto) No need to open it in P2k Commader you can see SEEMS on top before OPTIONS Click on SEEMS and Discover Numbers Click on SEEMS and FUNCTIONS (click on it you will see all option of Moto) Now here is ur moto Locked in Some option So NOW carefully Find and Check/Uncheck Option bellow LOCKS THERE FEATURES Call barrinf Etccc...... Uncheck 00 SIMCARD NOT REQUIRED FOR PHONE ACCESS...... Uncheck Thats ITTTTTTT on Right hand Click on WRITE SEEMS (Dont Forget Important) Now Close Function and restart Your Phone From Main Window of P2k Commader u can see on right hand SO YOUR PHONE WILL BE UNLOCKED @Free This work for me on many Moto Last time on V3xx Please if its work for u Thank Boolna Yaar ok ANY Problem Just Inform me with your logs or Pic i will help u.. BEST OF LUCK Asif |
03-02-2009, 13:28 | #22 (permalink) |
Junior Member Join Date: Mar 2009 Location: Romania -> Bucharest Age: 31
Member: 984579 Status: Offline Thanks Meter: 0 | There's a better way to unlock L7/V360... Try DualBoot ! You can download it from HERE. After you unrar the archive, do the following steps : 1. First of all, make sure your battery is FULL. In case the flash fails, you need all the power to revive it. 2. Open Flash&BackUp 3.0.6 or RSD Lite 3.7. If you use FB3, make sure the selected profile is "Motorola V360" or "Motorola V360 (with 08.A0 boot)" (if your boot loader is not 08.A0, select the normal profile). 3. Select the DualBoot L7 & V360.shx and press "Start" or whatever is in that program (I don't remember right now). After it's ready, you should do this : -turn on the phone; -turn it off; -take out the battery; -press & hold *, then connect the USB cable; -enter P2K Easy Tool v3.9 (cracked); -"Full Repair PDS Zone" (with "Motorola V360" profile); -done. |
03-02-2009, 13:29 | #23 (permalink) |
Member: 984579 Status: Offline Thanks Meter: 0 | There's a better way to unlock L7/V360... Try DualBoot ! You can download it from HERE. After you unrar the archive, do the following steps : 1. First of all, make sure your battery is FULL. In case the flash fails, you need all the power to revive it. 2. Open Flash&BackUp 3.0.6 or RSD Lite 3.7. If you use FB3, make sure the selected profile is "Motorola V360" or "Motorola V360 (with 08.A0 boot)" (if your boot loader is not 08.A0, select the normal profile). 3. Select the DualBoot L7 & V360.shx and press "Start" or whatever is in that program (I don't remember right now). After it's ready, you should do this : -turn on the phone; -turn it off; -take out the battery; -press & hold *, then connect the USB cable; -enter P2K Easy Tool v3.9 (cracked); -"Full Repair PDS Zone" (with "Motorola V360" profile); -done. It is now unlocked. |
04-18-2009, 05:12 | #24 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 974170 Status: Offline Thanks Meter: 0 | where can i download the drivers for v3xxx for p2k. Quote:
hi sir i wanted to ask you where to download the drivers for v3xxx to unlock it. and then what should i do with it thank you very much. sir. | |
how to unlock v3xx boot 06.24 | nilan | Rocker Dongle (By Legija) | 5 | 03-22-2009 19:25 |
how to unlock v3xx without T.P cable ??? | fadhel | Smart-Clip | 4 | 08-07-2008 01:56 |
how to unlock v3xx | shaheb_anl | Smart-Clip | 1 | 06-23-2008 07:44 |
how to unlock v3xx with test point???? | abdelhak_gsm | Smart-Clip | 17 | 04-07-2008 19:42 |
how to unlock v3xx boot 03.02 | juvenile | Smart-Clip | 1 | 12-18-2007 08:15 |
