Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-18-2003, 05:51   #1 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
S55 Flash Patching
maybe some mod can make this sticky...
*** Profil Logo on MainScreen ***
;Firmware : S55 v20
;Author : ACiD [mrp]
;Homepage: www.gsm-dev.com
; uses pictures 286 to 292 (old SMS Pictures)
; sample pictures included
32CC2E: DA7216C3 DA7BF88F ; call refresh Profil Logo
3B8FF8: FFFFFFFF DA7216C3 ; call PicturePaint (Akku Symbol malen)
3B8FFC: FFFFFFFF DA927CA5 ; call GetSelectedProfile
3B9000: FFFF C08C ; movbz r12, rl4 ;hier steht jetzt die Profilnummer in r12
3B9002: FFFF F0EC ; mov r14,r12
3B9004: FFFFFFFF E6FC1E01 ;mov r12, #100
3B9008: FFFF 00EC ;add r14, r12
3B900A: FFFF E00C ;mov r12, #0 (xPos)
3B900C: FFFF E08D ;mov r13, #8 (yPos)
3B900E: FFFFFFFF DA7216C3 ; call PicturePaint (Akku Symbol malen)
3B9012: FFFF DB00 ;rets
; ##### Picture 286 #####
; Picture Table Index
0CC8F0: 32140100 20080100
; Picture Data
08FF20: 7FFFE403FFF7FF6EBF9000FFFFFF7DDF 00000000C8000080C8000080A99BCC80
08FF30: 20207F5FFF7FFE40203EEFBF7DDF00A8 AA52A2809A52AA809992A68000000000
; ##### Picture 287 #####
0CC8F8: 32140100 20080100
; Picture Data
093F20: 00008002403D3F3C012104C0663F0201 00000000808000008000000084990000
093F30: 934000473F1D003026C1E33F3301B366 8AA28000888A0000E6B1800000000000
; ##### Picture 288 #####
0CC900: 32140100 20080100
; Picture Data
097F20: 7FC0FC07E07FFF4061FE0FF0C07F4037 0000000080000000800800008CAC0000
097F30: FFBF79807F7E1FCFBCFF0FFF200F9FF9 82A800008AA80000E664000000000000
; ##### Picture 289 #####
0CC908: 31130100 20080100
; Picture Data
09BF20: 00A803F003807F00A80FFC07807F00A8 00000000700128008801420083318B00
09BF30: 3E0F07807F00A87C0F83807F00F87CC7 80A18A008AA14A0071A1290000000000
; ##### Picture 290 #####
0CC910: 31130100 20080100
; Picture Data
09FF20: FE0203F00807FFFF838E1C101FFFFFC0 000000009000800090008020F2639930
09FF30: 9806607FFFFFE0100200FFFFFFF83003 9514A2A094548A209333B19000000000
; ##### Picture 291 #####
0CC918: 31130100 20080100
; Picture Data
0A3F20: BFD7FFFFFFFF7FFEEFFFFFFBFFFFFFD7 0000000060A800009428000046A90000
0A3F30: 8FE3FFAFFFFFFE0380FFDFFFAFFC0000 24AA800094AA000062A9800000000000
; ##### Picture 292 #####
0CC920: 31130100 20080100
; Picture Data
0A7F60: 00000FFFC7C07F3478000007607F20FE 0000000082008000820080005446A4C0
0A7F70: 1FF80FC07F1FFE00003F807F39D78780 54A8CA802888A8802866A68000000000
Old 11-18-2003, 05:54   #2 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
;*** Handsfree mode on Left_Key ***
;Firmware : S55 v20
32499C: DA7106B8 DA7134F5 ; call UserPoz on LeftKey
press once -> handsfree on
press twice -> handsfree off
Old 11-18-2003, 05:55   #3 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
Handsfreemode before call
;*** activate handsfree mode befor doing by left key call version 2 ***
; Firmware : S55 v20
; Author : ACiD [mrp]
; Homepage: www.gsm-dev.com
; if you do not have an profil logo you need to read the comments.
; Source Code included.
download vkp
Old 11-18-2003, 05:57   #4 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
;*** Using LEFT_SIDE_DOWN-key for Handsfreemode ***
1) first you need the ;*** activate handsfree mode befor doing by left key call version 2 *** patch
2) undo this line:
32499C: DA7106B8 DA7B4C90
3) apply this line:
324A06: DC5C9887A897DC49 DA7134F5FA72804E
Old 11-18-2003, 05:58   #5 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; allow only "112" in keylocked mod (not 98 and 911):
2400DE: EA20 0D0F
; allow no keypress in keylock mode:
2400C2: EA20 0D1D
Old 11-18-2003, 05:59   #6 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
this is an useless patch unless you don't want to make own patches. If you want to make own patches you my need to turn
off phone without saving EEPROM:
*** Software Reset on Left_Key ***
32499C: DA7106B8 B748B7B7 ; srst (software reset)
Old 11-18-2003, 06:00   #7 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; Author : original by RizaPN improved by Chaos,
; SiNgle, mamaich ported to S55 by ACiD [mrp]
; yeahhh team work
;AT+CGSN
;Display IMEI, as usual
;AT+CGSNage,offset
;Dump 128 bytes of memory starting at address pageffset
;AT+CGSN.page,offset,data
;Search data on the given page, starting from offset. Data is a
;hexadecimal string without spaces. Offset is in range 0...3FFF.
;AT+CGSN*page,offset,data
;Write data to memory (RAM) at address pageffset. Data is a hexadecimal
;string without spaces.
;AT+CGSN@seg,offset
;Inter-segment call to address segffset. On return, values of r14 and r15
;will be displayed. Note that seg is the segment, not the page (eg. if you
;wrote procedure to 11:500, call it at 4:4500). Procedure should end with
;far return. No need to serve WD because S55 turns it off
001E42A2: 147EE000 549C6100
00219BBE: FFFFFFFFFFFFFFFF E004BB029DFECB00
00219BC6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49992827F230008D0C47F20A008D06
00219BD6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F2DF00292747F20F00ED035C447182
00219BE6: FFFFFFFFFFFF CB001F88CB00
00219BEC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088E088F088C0E00C88C088D0F182
00219BFC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7C44F19266F40F0F47F90A008D010997
00219C0C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47F80A008D01098706F430308840F0C0
00219C1C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FCFF3FF2FD02FEDAE21203080698C0
00219C2C: FFFFFFFFFFFFFFFF 98F098E09850CB00
00219C34: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F01E7C81E00DBBD8F01EE6FD2000BBD4
00219C44: FFFF CB00
00219C46: FFFFFFFF 998C7C44
00219C4A: FFFFFFFFFFFFFFFFFFFF E004BBBC8D01BBBACB00
00219C54: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAE15ECDF084F095DC49993827F32A00
00219C64: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02FAE0147EBBA9F0F4BBA7F0E44930
00219C74: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1729342D2127F312002D18E6FD0D0A
00219C84: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBB3E17BE1FAE6FD2000DC4F992EBBAC
00219C94: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D0A29A12DF99DF629B19DF30D25
00219CA4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBD28D23DC4FB98E08E10DFADA61F29C
00219CB4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBBFF0EFBBBD0D1926F04000F020BBC3
00219CC4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D03B98208210DFB2020A758A7A708E1
00219CD4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0AF010F0DEF0C2DC4F998D498D3DF5
00219CE4: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 28C13DFABBA506F04000FAE1C4C5
00219CF2: FFFFFFFFFFFF ECFFECFEDB00
Old 11-18-2003, 06:01   #8 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; Disable Java verification
; Author : original by ?Chaos?, ported to S55 by ACiD [mrp]
5B4826: 3D 0D
Old 11-18-2003, 06:02   #9 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; deletes the "copy all entrys to addressbook question and the
; selection of default book on sim change or twin bill change
8B2B06: DA927264 E6FC1000 ; mov r12, #10h
8B2B0A: 48403D04 DA730E87 ; calls HideSelectDefaultBook()
8B2B0E: DA92C29A FACB322B ; don't ask to copy bull****
Old 11-18-2003, 06:03   #10 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; left_key for changing profile
; Author : Braindead
; Homepage: www.hundkotzemaus.de
32499C: DA7106B8 DA73D022 ; call SelectProfileMenu
; left_key for flex_mem
32499C: DA7106B8 DA74240C
Old 11-18-2003, 06:04   #11 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; change batt down sound into...
; Author : RizaPN, ACiD [mrp]
;4EFFD9: 3C 1C ; Tut
4EFFD9: 3C 0C ; ausschalten
;4EFFD9: 3C 4C ; klick (keypressed)
Old 11-18-2003, 06:04   #12 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; Yet another Profil Logo
; Provider Name -> Profil Logo
VKlay Patch
Source Code
Old 11-18-2003, 06:06   #13 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; change style of locked softkey
; Version 1:
5CAF80: AA 00
; Version 2:
5CAF80: AA FF
Old 11-18-2003, 06:06   #14 (permalink)
Acidmrp's Avatar
Member: 15315
Thanks Meter: 1
; shows the time instat of the provider name.
; Provider Name -> Time
; v2 should now work with any provider
download vkp
Old 11-22-2003, 16:45   #15 (permalink)
dspmobile's Avatar
Member: 29130
Thanks Meter: 5
; Unhide Explorer Menu for Phone without SIM Card
108976: C404 5E05
But there is a little problem if you use Option "Sent via ... " when you are without SIM card.
It switches off the phone !
S55 flash with wrong flash file. WillGsm E-Gold Based Phones 2 01-29-2005 13:58
S55+blacklist patch KERKENNAH E-Gold Based Phones 1 12-19-2004 09:57
S55 Flash Patching :) Acidmrp E-Gold Based Phones 3 09-21-2003 19:55
S55 flashing 2% zoki E-Gold Based Phones 3 06-10-2003 22:07
S55 flashing zoki E-Gold Based Phones 4 03-31-2003 07:53
Page generated in 0.21112 seconds with 10 queries
