S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
06-10-2005, 19:21 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | STEP by STEP of X65 Imei Change by Trixxi3 Preliminar: - This works on phone versions <36 - After this you canīt upgrade with WSUP/Update, youīll lose your new imei. - After this you canīt unlock with any soft, youīll lose your new imei. - After this you can change ffs. Correct way. 1 - Downgrade with any way to <36 version. 2 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode" 3 - Go to "Codes" and press "Auto Open All" 4 - Go to "Flash", mark "Pause" and "New BCore V22" 5 - Press "Do Job" and wait for finish. 6 - Turn Off mobile if not auto off. 7 - Go to "Settings" and press "Service Mode" 8 - Go to "Flash" and mark "Recalculate Keys in Flash" (two more options will be auto mark, all itīs ok) If any advice of Wrong entry appear return to codes section and fill Skey and Bkey with any numbers. 9 - Press "Do Job" and wait for finish. 10 - Go to "Settings" and press "Service Mode" 11 - Go to "Codes" and press "Auto Open All" 12 - Press "Freia.log" and save file with any name, but remember this name later 13 - Press "x65flasher.ini" and save file in x65flasher dir. 14 - Open x65flasher.exe and Press "Connect" 15 - Change "Leght" to 40000 and Press "Read Flash", save file 16 - Open SSWx65.exe and write your ESN, calculated by Papuas, Inverted in "Phone Id" EX: In codes section of Papuas you get ESN: A1B2C3D4, then write in "Phone Id" of SSWx65.exe in this way: D4C3B2A1. 17 - Write new imei in "New phone Imei" and Press "Dissable OTP", select file saved in step 15. 18 - Save file. 19 - Open x65flasher, select Leght to 40000 and Press "Write Flash", select file saved in step 18. 20 - Press OK to Skip Write BCore confirmation. 21 - Open mapper.exe, select log file saved in step 12, write imei of step 17, MUST TO BE THE SAME! 22 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode", Go to "Codes" and press "Enter Skey in Phone" 23 - In right window must see "Telephone in Factory Mode" 24 - Open Siemens EEPROM tool.exe, Press "Init", Press "Load" and select map file saved in step 21, Press "Select All" in left side, Press Right Arrow, Press "Select All" in right side, Press "Save Selected". 25 - Turn OFF your mobile, and turn ON again for confirmation of new Imei. GOOD LUCK. PS: Sorry my bad english and thx to all people involved in development of all aplications used in this Step by Step. WBR Trixxi3 |
The Following 4 Users Say Thank You to Trixxie For This Useful Post: |
06-16-2005, 18:16 | #2 (permalink) |
Freak Poster Join Date: Feb 2005 Location: World Wide Age: 54
Member: 120932 Status: Offline Thanks Meter: 58 | Hello to all, the same software q is for the change of IMEI of the C65 it will also be good me for the same thing in the C66? |
The Following User Says Thank You to Cell-Manager For This Useful Post: |
06-16-2005, 18:30 | #3 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Turkey Age: 43
Member: 2088 Status: Offline Sonork: 100.1630154 Thanks Meter: 57 | you have described the whole operation in 25 steps but it takes approx 3 minutes to do it but after some practicing also without using papuasutils. Regards |
The Following User Says Thank You to Murat Bekar For This Useful Post: |
06-29-2005, 11:46 | #12 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | still in project trixxie! we have developed few apps for doing it more easy, next time we talk I will explain u ... but this project will finish, sure. nice to see u |
07-02-2005, 23:52 | #15 (permalink) | |
Member: 120932 Status: Offline Thanks Meter: 58 | Quote:
STEP 5 in LG KG200 IMEI CHANGE | ufuktakiadam | LG | 3 | 11-23-2009 16:30 |
1112 imei change by patch credits consume but imei is still that | sairat | Universalbox | 0 | 07-14-2009 08:54 |
How to change bb5 imei change by universal box | shmily | Nokia Base Band 5 ( BB-5 ) | 19 | 11-27-2008 09:58 |
step by step | elsokary | ARM9 BASED M62 / M62+ | 0 | 03-08-2005 03:46 |
