02-07-2007, 12:34 | #1 (permalink) |
Junior Member Join Date: Feb 2007
Member: 447262 Status: Offline Thanks Meter: 0 | change cda for p990 |
02-07-2007, 21:35 | #4 (permalink) |
Member: 447262 Status: Offline Thanks Meter: 0 | mr. kulankendi, i have a few question to ask you regarding kulankendi server. but first let me explain my situation here. i have a p990 with a cda/5. i need to change my cda to a world generic one (cda/1 or cda/2). reason being, currently only ppl with the world generic cda are able to update their firmware to the latest one (r9). hence the cda change. so my questions are: 1) do i need to finalise the phone after the cda change? (bcoz i read somewhere in this forum that it'll cost 1 credit to finalize.) 2) how many credits alltogether do i need to do the cda change. (from a-z) 3) will i be able to run seus after the cda change? 4) can you provide me with a step by step instruction to perform this process. (once u're done with your samsung thingy that is). i'm really sorry if i sound dumb. it's just that i don't want anything to go wrong. |
02-08-2007, 01:51 | #5 (permalink) | |
No Life Poster Join Date: Nov 2006
Member: 384655 Status: Offline Thanks Meter: 517 | one thing, SEUS will don't change firmware in phone if phone have already latest one. ad1. In P990i is something similar to finalization but isn't same thing, when U want only change CDA then only CDA will be changed. Yes this process need to "open" GDFS loader and this cost 1 credit. ad2. 1 credit. ad3. If U will change CDA to one what really exists and is linked with firmware then for sure. ad4. I'll write all when will be ready. Always I write about new options how they work in Sticky post about news. link http://forum.gsmhosting.com/vbb/showthread.php?t=354542 is ok before give out update I must test all to be sure. P990i is not so cheap phone and any operation with GDFS will have bad end... b.r. Quote:
02-10-2007, 12:42 | #6 (permalink) | |
Member: 447262 Status: Offline Thanks Meter: 0 | Quote:
when do u think that the cda change can be available for p990? sorry for being such an @ss. it's just that today, my phone just froze on me in the middle of a very important call. hope it'll be available soon. b.r. p/s: keep up the good work. | |
02-11-2007, 19:56 | #9 (permalink) |
Member: 450489 Status: Offline Thanks Meter: 0 | Is it possible to change the CDA and then run SEUS so it updates the firmware to the latest Region 1 software right now? On the main page it says p990i is supported but I am not certain of it. Last edited by Saltank; 02-12-2007 at 11:37. |
02-13-2007, 11:11 | #11 (permalink) |
Member: 450489 Status: Offline Thanks Meter: 0 | Yay for new version! I have a problem. I cannot install those "Harmonie drivers" and anyways when I try to check info on my P990i it shows the following: Hold 'C' button and plug DCU60 USB cable. Phone Connected... Detected: DB2000: P990i Series Connecting to server... Error: EsB What's up? I tried on another computer and installed the drivers properly so now I'm going to try and change the CDA! Final edit: It worked! Congratulations! Now I upgraded to the newest firmware and it seems a lot faster. Although I actually miss the Orange customisation menu bar on the left a bit and I can't find the Opera web browser. Hmm! Last edited by Saltank; 02-13-2007 at 13:34. Reason: Status |
02-13-2007, 12:53 | #12 (permalink) | |
Member: 384655 Status: Offline Thanks Meter: 517 | If drivers are not installed correctly then I can't help U with any errors Try deinstall all drivers for P990i first , restart pc and try again. b.r Quote:
02-13-2007, 14:16 | #14 (permalink) |
Member: 450489 Status: Offline Thanks Meter: 0 | I followed the instructions as in this post: http://forum.gsmhosting.com/vbb/showthread.php?t=354542 At first I had a problem but it was obvious that I had the SE drivers installed on my main machine, I took it to another machine and followed the instructions strictly, it recognised the phone as P990 but still asked me for the drivers since I had never installed them before. 1) plug in the phone while holding C and install Harmonie drivers 2) KKlient should be able to get info from your phone 3) check the CDA change box and input the CDA you want (I Suggest Generic world 1 as in this list: http://uiq3.sourceforge.net/wiki/index.php/CDA/P990i ) |
02-13-2007, 14:26 | #15 (permalink) |
Member: 447262 Status: Offline Thanks Meter: 0 | thanx for the quick reply, now i'm uninstalling all the programs relating to se from my machine. (pc suite and symbian 9 drivers). will restart the pc and try again. will update the resultes later. |
problem after Change CDA P990 | yangyuan | KULANKENDI Server | 0 | 03-27-2008 10:51 |
For Which Complaints Use The Options ""restore File Field,cid Change,cda "" ? | zone2 | Sony Ericsson | 0 | 01-13-2008 08:50 |
Change CDA code for DB2020 with MT-Box... | kennethtse | MT-BOX | 16 | 05-03-2007 17:11 |
URGENT! Problem after changing CDA in P990 | treza | KULANKENDI Server | 19 | 03-06-2007 05:13 |
@ LEAD, Can we change CDA with Cruiser ? | rjsoo7 | Cruiser Suite | 3 | 02-14-2005 19:45 |
