11-25-2009, 04:06 | #1 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | *** Cyclone Box Firmware v01.0C Avaiable *** Quote:
- SmartCard reset procedure rewritten from scratch, SC Reset takes now 20-30ms instead 0.5 - 1s - Baud autonegotiation for SmartCards added using FI/DI ATR Parameters, this results faster card transactions, etc. - Clock speed negotiation added for some cards (up to 20MHz) - Added support for protocol autonegotiation (T=0, T=1), for some cards - Added support for D5xxxxxx and D6xxxxxx series Cyclone Cards (TPDU problem) - More debug messages while dealing with Smartcard added - Minor changes and bugfixes If your box working ok, and you aren't encountering SmartCard problem(s), update is not necessary. Best Regards, More coming.............. Cyclone Team | |
The Following 49 Users Say Thank You to karwos For This Useful Post: |
11-25-2009, 04:57 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Quote:
Hope next update 9DDB hash (3600c, 5220, 7210c, 7310, 6600s, 6600f, 7610s...) unlock support. b.r. | |
The Following 7 Users Say Thank You to kungpaoski For This Useful Post: |
11-25-2009, 05:03 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: nothing
Member: 494167 Status: Offline Thanks Meter: 292 | thanks for this good update my box super dct4 is activated again with this update wich i lost this feature with last update thaks again here is my log Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number: C0000237 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D0000151 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.04v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.96v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
The Following 3 Users Say Thank You to software zone For This Useful Post: |
11-25-2009, 05:27 | #8 (permalink) |
Insane Poster Join Date: Jan 2005
Member: 108273 Status: Offline Thanks Meter: 8 | Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0A, (Nov 6 2009 01:26:23, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number: C000xxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Security Card Reset Error -> Possible error: Security card is not responding for reset Initialization has failed -> Security card was not found! |
11-25-2009, 05:32 | #9 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | thanks for cyclone teams this good update Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number: C0000949 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D20001EA Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.16v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.09v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work |
11-25-2009, 05:32 | #10 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Zenica - BiH
Member: 55342 Status: Offline Sonork: 100.1619358 Thanks Meter: 281 | This update for Cyclone is Smnartcard problems only like Cyclone Nokia Application v01.0A.When for the real big bomb update.................... |
11-25-2009, 06:01 | #12 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Vi Age: 37
Member: 169753 Status: Offline Thanks Meter: 3 | What is my problem? Checking for card presence... Security card found with ATR [3BFA1300008131FE454A434F50343156323****] Fetching data... Security Card Process APDU Error -> Received TPDU NAD byte is not addressed for this device Security Card Fetch Card SN Error -> APDU Process problem Card reading error -> Problem with reading Card S/N |
11-25-2009, 06:15 | #14 (permalink) |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | update box ok Updating Security Area... Security Area Updated, Took: 0.109s Updating Main Firmware... Main Firmware Updated, Took: 10.750s Disconnected from Cyclone Server Box Maintenance finished successfully Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application |
cyclone box can't change to main mode [SOLVED - Thanks HRCO] | banalven1 | Cyclonebox | 5 | 03-29-2010 09:34 |
Cyclone Nokia Application v01.18, (Feb 10 2010 | bosnian | Cyclonebox | 3 | 02-12-2010 17:18 |
cyclone box firmware rellasse | vaghubha_sodha | Cyclonebox | 0 | 01-03-2010 04:40 |
Cyclone Box Firmware v01.0C Avaiable %1000 OK OK | .::TR_LAZ::. | Cyclonebox | 0 | 11-26-2009 13:56 |
*** Cyclone Box Firmware v01.0C Avaiable *** | SiRoYa | Service Products News & Updates | 0 | 11-25-2009 18:45 |
