@LEAD ..you have broken your promise..you said that IMEI change option will be available as a option to have on cruiser..i bought the fighter because it HAD THE OPTION TO ENABLE IMEI CHANGE...YOU KNOW THAT PB 2.2 WORKS AND IS FREELY AVAILABLE ON THE NET AND IT ONLY USES A T28 Cable ..i tested it on a K700i..it read codes and it directly unlocked as well.
so what is the point buying your CRUISER if it does not have FULL CAPABILITY..
i might as throw fighter 4.43 in the rubbish tip .. just keep my T28 cable and USE PB 2.2 simple software or just buy the nemsis clip at 90usd...
LEAD my friend you will loose sales...
Lead what i suggest you implement imei change and see how many customers choose the option of imei change implement.
personally i prefer FULL CAPABLITY...I hope you have the OPTION OF CHANGE IMEI ENABLE for those customers wishing to have this option.i
i am waiting so i will buy cruiser...if it does NOT have that option..i will use nemesis clip or use PB 2.2 or 2.4....IF IT DOES HAVE FULL CAPABLITY I WILL ...THEN I WILL BUY IT..i hope you do have that option as promised. |
