Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 7 / iPhone 7 Plus
Old 06-26-2019, 11:41   #1 (permalink)
Member: 2909862
Thanks Meter: 6
Fix iPhone 7 home button not working
Interduce three iPhone 7 home button replacement part for iPhone 7 home button not working repair.
REWA Customized Charging Port Flex Cable
Function:
The lightning earphone is not available. We can’t here voice with the earphone plugged-in.
The hand feel of the home button is not so comfortable as the original.
No vibrate alert when returning to home.
Touch ID function is not available.
upgraded version of Customized Charging Port Flex Cable
Restore return-to-home function
Support PD fast charging
Support different type of charger adapters from 0.5A-2.4A
Be able to take screenshots on all iOS versions
More comfortable touch feeling
What Can HX 2nd iPhone Universal Home Button Do?
1. Pair Bluetooth directly
2. Restore return-to-home function
3. Take screenshot
4. Open Siri successfully
5. Reveal running apps
Hot-selling 2nd Gen Universal Home Button
It can solve iPhone 7- iPhone 8 plus home button not working issue.
Which one will you choose for your repair?
The Following 2 Users Say Thank You to Joyee Zhang For This Useful Post:
Old 06-27-2019, 05:24   #2 (permalink)
Member: 2833946
Thanks Meter: 108
Definitely choose the universal home button. That is easy to install and works well.
The Following User Says Thank You to AmieeWhite For This Useful Post:
Old 08-01-2019, 20:09   #3 (permalink)
Member: 2903725
You can find the button at: https://www.elitecellparts.com/iphon...lex-black.html
Hope it will help you.
Old 09-16-2019, 07:47   #4 (permalink)
Member: 2861866
Thanks Meter: 71
The iPhone 7 home button will only work with the original home button that it was shipped with; if it breaks and needs to be replaced, it means that the replaced home button would be a non-functional home button. No Touch ID and no return-to-home functionality. It can restore the return-to-home function of your home button through use customized charging port flex cable.
Old 05-16-2022, 07:43   #5 (permalink)
Member: 379652
Any solution for Universal Home Button replaced still no function on iphone7. The home button brand is YF. Touch ID will will not work but need the return to home function only.
Old 08-23-2022, 05:13   #6 (permalink)
Member: 2971749
I've used the newer revision aftermarket home buttons found on Amazon with good results, it'll return the use of the home button function but nothing can bring back touch ID. Just make sure it's the newer revised ones, those are just a direct install
Old 10-13-2022, 11:51   #7 (permalink)
Member: 901949
Thanks Meter: 50
does it works on ios15 devices?
i use YT universal home button on a normal (original home button and fingerprint functioning normal) iPhone 7 iOS15, i just wanted to test that the fake universal home button is working.
its not working on ios15, so i put back the original home button, it says my button is broken, and fingerprint is not available,
now this is bad, how can i regain access to my original home button on iPhone 7, ios15? do i need to restore it using itunes?
the universal home button i tested on ios13 and it works fine, only on ios14 & ios15 i tested not working
Old 10-13-2022, 11:52   #8 (permalink)
Member: 901949
Thanks Meter: 50
can i know what is your current ios with YF home button working?
Old 12-06-2022, 12:29   #9 (permalink)
Member: 3026866
Have you used this service?
Page generated in 2.78902 seconds with 8 queries
