02-11-2019, 04:37 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | ONly expert can help me IPHONE7 audio ic reballed - HOME BUTTON NOT WORKING I REBALLED 25+ AUDIO IC BEFORE 1. I reballed audio ic iphone7, and AUDIO WORK 100% NOW 2. Before reball audio IC home button worked 100% 3. After reball Audio IC, home button give error "UNABLE TO ACTIVATE TOUCH ID ON IPHONE" 4. DIODE MODE RESISTANCE VALUE HOME BUTTON MOTHERBOARD CONNECTOR verify good ok 100% 5. Diode mode RESISTANCE value HOME BUTTON ON LCD verify good ok 100% what is wrong with HOME BUTTON? HOW TO FIX HOME button? IOS 12.1.3 Please help me |
02-11-2019, 23:41 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | IPhone 7 and 8 homebuttons fail to work most of the time when u10 is damaged on the homebutton cable from opening the phone. In the picture it is black but in the real world it is silver. Replace this ic and your homebutton will work most of the time. So That is why your diode readings are perfectly good. Because the fault is not on the board. And it is not related to the audio ic repair you did. Enjoy and hit the thanks button if this was useful to you. |
The Following 2 Users Say Thank You to HDccam For This Useful Post: |
02-17-2019, 14:59 | #6 (permalink) |
Major Poster Join Date: Jan 2017 Location: Saint-Georges, Quebec, Canada
Member: 2672718 Status: Offline Thanks Meter: 4 | many video on youtube you see reball only needed for audio ic there a chip on board for home button dont know it is on iphone 7 |
The Following User Says Thank You to Servicesinfocel For This Useful Post: |
