01-07-2021, 22:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 496 | [Solved] iPhone 7 ERROR 4013 NAND BAD AFTER FORMAT (No boot data found!!! eer:4) No way to read hard disk information >>> Initializing PCIe interface... Hard disk has been detected... >>> Initializing the hard disk... Hard disk information not detected... bad hard disk contact or damaged partition table!!!... This hard drive will report error: 9 or 6 or 14... Please try [Erase All]!!! If you still can't detect the hard disk information!!! Write [write to the hard disk partition table] >>> Operations are done... Solution: 1-Erase All (Retain partition table and boot information) 2-Hard disk initialization & Read all the l'information 3-Back up the boot data (backup boot) 4-Erase All (Erase all data,delete partition table and boot information) 5- Hard disk initialization You would get this message: >>> Initializing PCIe interface... Hard disk has been detected... >>> Initializing the hard disk... >>> Tip: This hard drive can be brushed normally... Capacity: 32GB Partition Table: nvme00 >>> Operations are done... >>> Reading hard disk information No boot data found!!! eer: 4 >>> Operations are done... 6-Reball Nand then restored that via 3utools or iTunes 7-Enter purple mode to write the backup 8-Then restored it 9- okay #repairsiphone #iphonerepairs #fixphone #fixiphone #microsoudure #microsoldering #logicboardrepair #data_recovery #ibmulti_s_fix #kinshasa #kinfixiphone #rdc Envoyé de mon iPhone en utilisant Tapatalk |
