Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 01-14-2019, 06:17   #1 (permalink)
Crazy Poster
Member: 2583933
Thanks Meter: 19
HUAWEI MATE 9 MHA-AL00 bricked
Hello,
i have HUAWEI MATE 9 MHA-AL00
i got this device brciked in HUAWEI USB COM MODE
someone flash it by board fw
then
i debricked the device by write
Kirin960_T2_A7.0_V3
beacuse main TP board fw seems not compatble with device BL VER
MHA-AL00A_HLMHAAL00AM00A064_Board Software_inc_testpoint.dgtks not work
any way debricked by this
Kirin960_T2_A7.0_V3
Device detected:
COM77: HUAWEI USB COM 1.0 (COM77)
BOOTLOADER File to update: Kirin960_T2_A7.0_V3
OEM File to update: MHA-L29
1/14/2019 7:04:26 AM Starting to write device...
Writing bootloader...
Writing Kirin960_T2_A7.0_V3_3.dtwork...
Writing Kirin960_T2_A7.0_V3_4.dtwork...
Writing Kirin960_T2_A7.0_V3_5.dtwork...
Waiting for fastboot device...
Device found: 0123456789ABCDEF
Looking for a device in fastboot mode
Battery state: 4312mv
Writing OEMINFO partition
OEMINFO partition UPDATE ...OK
Software written
1/14/2019 7:05:05 AM Writing device finished OK
after this if i tick reboot button or just unplug usb cable
ANDROID reboor reason
coldboot
NA
check-boot-mode
try to flash many files all logs is same
MHA-AL00 , L29 , L09 , TL00
4 board fw files also
HLMHAAL00AM00A070 , 71 , 69 , 74
all logs is same
FAIL image verification error
C:\Users\my\Downloads\MHA-TL00A_C01B213_Firmware_China_Nonspecific_Android7. 0_EMUI5.0.APP
Looking for a device in upgrade mode
No devices detected in upgrade mode
1/14/2019 6:55:01 AM Starting to write device in FASTBOOT mode...
Battery state: 5391mv
Extracting partition XLOADER...
Writing XLOADER partition
XLOADER partition UPDATE :FAIL image xloader1 verification error
Cannot get FBlock info from device
Trying to unlock device...
Extracting partition FW_LPM3...
Writing FW_LPM3 partition
FW_LPM3 partition UPDATE :FAIL image verification error
Extracting partition FASTBOOT...
Writing FASTBOOT partition
FASTBOOT partition UPDATE :FAIL image verification error
Extracting partition VECTOR...
Writing VECTOR partition
VECTOR partition UPDATE :FAIL image verification error
Extracting partition MODEMNVM_UPDATE...
Writing MODEMNVM_UPDATE partition
MODEMNVM_UPDATE partition UPDATE ...OK
Extracting partition TEEOS...
Writing TEEOS partition
TEEOS partition UPDATE :FAIL image verification error
Extracting partition TRUSTFIRMWARE...
Writing TRUSTFIRMWARE partition
TRUSTFIRMWARE partition UPDATE :FAIL image verification error
Extracting partition SENSORHUB...
Writing SENSORHUB partition
SENSORHUB partition UPDATE :FAIL image verification error
Extracting partition FW_HIFI...
Writing FW_HIFI partition
FW_HIFI partition UPDATE :FAIL image verification error
Extracting partition BOOT...
Writing BOOT partition
BOOT partition UPDATE ...OK
Extracting partition RECOVERY...
Writing RECOVERY partition
RECOVERY partition UPDATE ...OK
Extracting partition RECOVERY2...
Writing RECOVERY2 partition
RECOVERY2 partition UPDATE ...OK
Extracting partition DTS...
Writing DTS partition
DTS partition UPDATE ...OK
Extracting partition CACHE...
Erasing CACHE partition
Partition CACHE erased
Writing CACHE partition
CACHE partition UPDATE ...OK
Extracting partition SYSTEM...
Writing SYSTEM partition
sending sparse file 469762048 bytes
send sparse file OK
send sparse file OK
send sparse file OK
send sparse file OK
send sparse file OK
sending sparse file 349806240 bytes
send sparse file OK
SYSTEM partition UPDATE ...OK
Extracting partition ISP_FIRMWARE...
Writing ISP_FIRMWARE partition
ISP_FIRMWARE partition UPDATE :FAIL image verification error
Extracting partition MODEM_FW...
Writing MODEM_FW partition
MODEM_FW partition UPDATE :FAIL image verification error
Extracting partition HISEE_IMG...
Writing HISEE_IMG partition
HISEE_IMG partition UPDATE ...OK
Extracting partition HISEE_FS...
Writing HISEE_FS partition
HISEE_FS partition UPDATE ...OK
Extracting partition USERDATA...
Erasing USERDATA partition
Partition USERDATA erased
Writing USERDATA partition
USERDATA partition UPDATE ...OK
Software written
1/14/2019 7:02:29 AM Writing device finished - INCOMPLETE
No devices detected in fastboot mode
Cannot update device in upgrade mode
device go to HUAWEI USB COM 1.0
then i repaeat debrick operation again
Device detected:
Software written
Old 01-14-2019, 11:49   #2 (permalink)
Member: 2023196
Thanks Meter: 1,892
What you need to do after flashing loader+ oeminfo is to flash full stock rom that matches oeminfo repaired details. If that does not help and phone remains alwaus in com 1 then only main board replacement can help you.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 01-14-2019, 12:00   #3 (permalink)
Crazy Poster
Member: 2583933
Thanks Meter: 19
well ,
i think replacement is right choice
thanks for support
The Following User Says Thank You to jidophone For This Useful Post:
Old 01-21-2019, 19:59   #4 (permalink)
Member: 566943
Thanks Meter: 11
Solution to umbrick your phone is:
- after you flash bootloader Kirin960_T2_A7.0_V3
- you have to flash HLMHAAL00AM00A073_Board Software_general_7.0.0_r1_EMUI5.0_05021YVS
- in Dc phoenix select update_nv_rback.xml and flash it in advanced mode
reboot manual to update mode with usb cable in
flash the last stock firmware like 8.0.0.380 or 381+++
that's it
The Following 9 Users Say Thank You to issam_11_issam For This Useful Post:
Old 02-25-2019, 21:32   #5 (permalink)
Member: 2268606
Thanks Meter: 5
that's it
THANK YOU SO MUCH bro it worked after struggling for 3 days!.
now the IMEI is 000000000000 do you know how to fix it? i tried hcu but it's not supported!
Old 02-26-2019, 02:50   #6 (permalink)
Member: 2893014
my IMEI too is 000000000 and HCU NO HAVE SUPORT ....HOW FIX IMEI
Old 03-09-2019, 16:40   #7 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
that's it
1 - after you flash bootloader Kirin960_T2_A7.0_V3
2. Fix Imei SN wifi bt and with HCU
3.Direct unlock / read bootloader
4. reboot manual to update mode with usb cable in
The Following 3 Users Say Thank You to solgeo For This Useful Post:
Old 03-09-2019, 17:44   #8 (permalink)
Member: 2268606
Thanks Meter: 5
Thanks,but how can we fix the IMEI if it's not booting after flashing the Board Firmware that you've mentioned, it's stuck on Huawei right now after flashing the board firmware.
However the PC can detect it 'and the Adapter drivers shows up in device manager' but HCU cannot detect the phone even though drivers are installed.
can you please tell us if there is something missing?
Old 03-17-2019, 14:36   #9 (permalink)
Member: 2704336
Hi Can u link me the files needed plz cant seem to find anywhere or maybe i just don't understand, device current status is i am able to get into upgrade mode but nothing seems be be flashing
it says this when read in fastboot mode in DC-Unlocker (without * of course)
Found Phone : MHA-L29
Model : Huawei phone in fastboot mode
IMEI : *****************
Serial NR. : AHK7N17*********
Firmware : MHA-L29C432B186
plz help
Old 05-23-2019, 13:54   #10 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
So daes anybody solve problem with imei 00000000? I have same problem
Old 05-23-2019, 13:56   #11 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
yes ...
check my post ...
Old 07-15-2019, 15:00   #12 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Thanks Meter: 214
that's it
is this step can work on MHA_EMUI6.0
Old 07-25-2019, 18:21   #13 (permalink)
Member: 281857
Thanks Meter: 214
how to fix this need
what mean of
DC Phoenix 0.0.0.105
user:002BD288E9
Device found: AHK0217A12000586
7/17/2019 3:56:02 PM Starting to write device in FASTBOOT mode...
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: :MHA-L29 8.0.0.378(C636)
Model: MHA-L29
Battery state: 0
OEM lock state info:
FB LockState: LOCKED
USER LockState: LOCKED
OEM get bootinfo:
locked
Device with unsupported security patch
Process identifier:16922756
XLOADER partition UPDATE :FAIL Command not allowed
7/17/2019 3:56:18 PM Writing device finished - INCOMPLETE
Getting IMEI...
Getting model ...
Model: MHA-L29
Battery state: 6570mv
OEM get bootinfo:
locked
Process identifier:16922670
Getting base version...
Getting cust version...
Getting preload version...
Erasing ver .. .
Writing rescue_recovery_kernel partition
rescue_recovery_kernel partition UPDATE ...OK
Writing rescue_recovery_ramdisk partition
rescue_recovery_ramdisk partition UPDATE ...OK
Writing rescue_recovery_vendor partition
rescue_recovery_vendor partition UPDATE ...OK
USB Device REMOVAL
Type: @oem203.inf,%singleadbinterface%;Alcatel ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: AHK0217A12000586
Looking for device in upgrade mode...
USB Device INSERTION
Type: @oem75.inf,%busfilter.devicedesc%;USB Composite Device
VidPid: VID_12D1&PID_107E
COM841: Android Adapter PCUI (COM841)
COM840: DBAdapter Reserved Interface (COM840)
7/17/2019 3:53:53 PM Starting to write device in UPGRADE mode...
7/17/2019 3:54:04 PM start to write update file
File to update: MHA-L29B_8.0.0.364(C432)_Firmware_05014BFF.APP
Process identifier:16922721
Validating file...
Looking for attached port...
Preparing to write...
Extracting partition SHA256RSA...
Writing partition: SHA256RSA...
Writing partition: SHA256RSA...OK
Extracting partition CRC...
Writing partition: CRC...
Writing partition: CRC...OK
Extracting partition CURVER...
Writing partition: CURVER...
Writing partition: CURVER...OK
Extracting partition VERLIST...
Writing partition: VERLIST...
Writing partition: VERLIST...OK
Extracting partition PACKAGE_TYPE...
Writing partition: PACKAGE_TYPE...
Writing partition: PACKAGE_TYPE...OK
Extracting partition HISIUFS_GPT...
Writing partition: HISIUFS_GPT...
Writing partition: HISIUFS_GPT...OK
Writing partition: XLOADER...
Error downloading file MHA-L29B_8.0.0.364(C432)_Firmware_05014BFF_6.dtwork, partition: XLOADER
Error writing software
7/17/2019 3:54:35 PM Writing device finished with ERROR
Update fastboot mode failed
after use tp and repair boodloader
DC Phoenix 0.0.0.107
user:002BD288E9
Revision: 0
user:002BD288E9
7/24/2019 4:29:02 PM Starting to write device in FASTBOOT mode...
Getting IMEI...
Getting model ...
SN:AHK0217A12000586
IMEI:861957032669565
IMEI1:861957032674656
Build number: :MHA-L29C432B186
Model: MHA-L29
Battery state: 1252mv
FB LockState: UNLOCKED
OEM get bootinfo:
unlocked
Process identifier:17110058
Signing process may take few minutes
Trying to get data from server
sending sparse file 396131652 bytes
Waiting for answer...
send sparse file OK
sending sparse file 471228432 bytes
send sparse file OK
sending sparse file 468249804 bytes
send sparse file OK
sending sparse file 458788460 bytes
send sparse file OK
sending sparse file 454640036 bytes
send sparse file OK
sending sparse file 468827772 bytes
send sparse file OK
sending sparse file 187511712 bytes
send sparse file OK
Software written
7/24/2019 4:36:11 PM Writing device finished - INCOMPLETE
USB Device REMOVAL
Old 07-25-2019, 20:11   #14 (permalink)
Member: 281857
Thanks Meter: 214
that's it
its work now thanks alot
Old 08-19-2019, 12:59   #15 (permalink)
Member: 2644171
Thanks Meter: 4
need help what is the solution my MHA-AL00 is totally dead after failed to flash xloader in firmware . after update oem info the phone boot to fastboot mode but not accept any firmware and board soft . i tried the montioned solution but wont flash in in force update mode ( huawei usb 1.0 )
The Following 2 Users Say Thank You to evanboorn7 For This Useful Post:
Page generated in 0.25499 seconds with 8 queries
