I dont have but you Can try with online package firmware |
Looking for a device in upgrade mode COM10: Android Adapter PCUI (COM10) COM11: DBAdapter Reserved Interface (COM11) 02/04/2020 9:45:42 pm Starting to write device in UPGRADE mode... Device found: EDN0219B16014237 Old slow algo NOT selected 02/04/2020 9:45:45 pm start to write update file File to update: D:\Taurus-AN00B 10.0.0.195(C00E190R7P2)_Firmware_EMUI10.0.0_05016B MA_2\dload\LIO-AN00P-10.0.0.195 BASE.APP File size: 5,163,909,008 bytes Current version(BASE_VER): TAS-LGRP3-CHN 10.0.0.190 Process identifier:23734652 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 54: SHA256RSA...OK Writing file 2 of 54: CRC...OK Writing file 3 of 54: BASE_VERLIST... Error downloading file 3 of 54 Error writing software 02/04/2020 9:45:59 pm Writing device finished with ERROR First I select LIO-AN00P 10.0.0.195 file and tick Upload to Server then I rename TAS-AN00B FILE to same as lio and untick server option and tick Bypass Option and Flash It but It is not working. Can you please guide me where I am doing wrong. |
And you have LIO-AN00P |
I can Flash LIO-AN00P 10.0.0.195 Firmware But I need to remove Huawei ID If I flash TAS firmware it will unlock Huawei ID Both have 990 5G |
then try flash in fastboot with rescue, bypass selected. |
I mean the emergency rescue recovery partition. Cannot get length error. |
hcu client bought a 72 "unlimited access" only to get 19 credits :mad::mad::mad::mad: |
unbrick P30 Lite hi sir help me to unbrick p30 lite. it stuck in recovery mode and what ever i flashed it give me error. please need your help |
Can you share one full log with error? |
finaly solved with this new version of dc phoenix. i cheicked rescue recovery and bypass version cheick box and flash goes without error here is full logs: Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: L2NDU19509041291 Detecting recovery partition File size: 4*435*133*648 bytes Current version(BASE_VER): Marie-LGRP2-OVS 9.1.0.270 ERECOVERY_KERNEL partition found ERECOVERY_RAMDISK partition found ERECOVERY_VENDOR partition found 2020-04-28 09:56:54 Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: L2NDU19509041291 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :MAR-L21A 9.1.0.317(C432E5) Model: MAR-LX1A Vendor/Country: hw/eea Battery state: 4381mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Getting base version... Base Version: MAR-LGRP2-OVS 10.0.0.167 Getting cust version... Cust Version: MAR-L21A-CUST 10.0.0.8(C432) Getting preload version... Preload Version: MAR-L21A-PRELOAD 9.0.1.3(C431R2) Process identifier:24137236 Erasing ver .. . File size: 4*435*133*648 bytes Current version(BASE_VER): Marie-LGRP2-OVS 9.1.0.270 Writing rescue_recovery_kernel partition RESCUE_RECOVERY_KERNEL partition update ...OK Writing rescue_recovery_ramdisk partition RESCUE_RECOVERY_RAMDISK partition update ...OK Writing rescue_recovery_vendor partition RESCUE_RECOVERY_VENDOR partition update ...OK Uptade recovery parttion OK USB Device REMOVAL Type: @oem103.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: L2NDU19509041291 Looking for device in upgrade mode... USB Device INSERTION Type: @oem118.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: L2NDU19509041291 USB Device REMOVAL Type: @oem68.inf,%vfsusbdevicename0011%;Synaptics FP Sensors (WBF) (PID=0011) VidPid: VID_138A&PID_0011 Instance id: 17eef56fdd91 USB Device INSERTION Type: @oem68.inf,%vfsusbdevicename0011%;Synaptics FP Sensors (WBF) (PID=0011) VidPid: VID_138A&PID_0011 Instance id: 17eef56fdd91 COM5: Android Adapter PCUI (COM5) COM6: DBAdapter Reserved Interface (COM6) Enter recovery mode OK 2020-04-28 09:57:26 Starting to write device in UPGRADE mode... Device found: L2NDU19509041291 Old slow algo NOT selected 2020-04-28 09:57:30 start to write update file File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_base\UPDATE.APP File size: 4*435*133*648 bytes Current version(BASE_VER): Marie-LGRP2-OVS 9.1.0.270 Process identifier:24137255 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 46: SHA256RSA...OK Writing file 2 of 46: CRC...OK Writing file 3 of 46: BASE_VERLIST...OK Writing file 4 of 46: BASE_VER...OK Writing file 5 of 46: PACKAGE_TYPE...OK Writing file 6 of 46: HISIUFS_GPT...OK Software written 2020-04-28 09:57:42 start to update cust file File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_cust_MAR-L21A_hw_eea\UPDATE.APP File size: 554*620 bytes Current version(CUST_VER): MAR_Global-CUST 9.0.1(C999) Process identifier:24137260 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: CUST_VERLIST...OK Writing file 4 of 7: CUST_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_CUST...OK Software written 2020-04-28 09:57:49 start to update preload File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_preload_MAR-L21A_hw_eea_R2\UPDATE.APP File size: 254*210*120 bytes Current version(PRELOAD_VER): MAR_GLOBAL_PRELOAD 9.0.1(C999) Process identifier:24137265 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: PRELOAD_VERLIST...OK Writing file 4 of 7: PRELOAD_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_PRELOAD...OK Software written 2020-04-28 09:57:59 start to write update file File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_base\UPDATE.APP File size: 4*435*133*648 bytes Current version(BASE_VER): Marie-LGRP2-OVS 9.1.0.270 Process identifier:24137274 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 46: SHA256RSA...OK Writing file 2 of 46: CRC...OK Writing file 3 of 46: BASE_VERLIST...OK Writing file 4 of 46: BASE_VER...OK Writing file 5 of 46: PACKAGE_TYPE...OK Writing file 6 of 46: HISIUFS_GPT...OK Writing file 7 of 46: XLOADER...OK Writing file 8 of 46: FASTBOOT...OK Writing file 9 of 46: HHEE...OK Writing file 10 of 46: DTS...OK Writing file 11 of 46: TRUSTFIRMWARE...OK Writing file 12 of 46: FW_LPM3...OK Writing file 13 of 46: DTO...OK Writing file 14 of 46: KERNEL...OK Writing file 15 of 46: TEEOS...OK Writing file 16 of 46: ISP_FIRMWARE...OK Writing file 17 of 46: VECTOR...OK Writing file 18 of 46: SENSORHUB...OK Writing file 19 of 46: FW_HIFI...OK Writing file 20 of 46: VBMETA...OK Writing file 21 of 46: MODEMNVM_UPDATE...OK Writing file 22 of 46: MODEMNVM_CUST...OK Writing file 23 of 46: RECOVERY_RAMDISK...OK Writing file 24 of 46: RECOVERY_VENDOR...OK Writing file 25 of 46: RECOVERY_VBMETA...OK Writing file 26 of 46: PREAS...OK Writing file 27 of 46: PREAVS...OK Writing file 28 of 46: ERECOVERY_KERNEL...OK Writing file 29 of 46: ERECOVERY_RAMDISK...OK Writing file 30 of 46: ERECOVERY_VENDOR...OK Writing file 31 of 46: ERECOVERY_VBMETA...OK Writing file 32 of 46: ENG_VENDOR...OK Writing file 33 of 46: ENG_SYSTEM...OK Writing file 34 of 46: CACHE...OK Writing file 35 of 46: SYSTEM...OK Writing file 36 of 46: CUST...OK Writing file 37 of 46: MODEM_FW...OK Writing file 38 of 46: HISEE_IMG...OK Writing file 39 of 46: HISEE_FS...OK Writing file 40 of 46: VENDOR...OK Writing file 41 of 46: ODM...OK Writing file 42 of 46: PRODUCT...OK Writing file 43 of 46: PATCH...OK Writing file 44 of 46: USERDATA...OK Writing file 45 of 46: VERSION...OK Writing file 46 of 46: PRELOAD...OK Software written 2020-04-28 10:07:59 start to update cust file File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_cust_MAR-L21A_hw_eea\UPDATE.APP File size: 554*620 bytes Current version(CUST_VER): MAR_Global-CUST 9.0.1(C999) Process identifier:24137597 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: CUST_VERLIST...OK Writing file 4 of 7: CUST_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_CUST...OK Writing file 7 of 7: VERSION...OK Software written 2020-04-28 10:08:07 start to update preload File to update: C:\Users\Abdoulgaf\Desktop\MAR-L21\update_sd_preload_MAR-L21A_hw_eea_R2\UPDATE.APP File size: 254*210*120 bytes Current version(PRELOAD_VER): MAR_GLOBAL_PRELOAD 9.0.1(C999) Process identifier:24137603 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 7: SHA256RSA...OK Writing file 2 of 7: CRC...OK Writing file 3 of 7: PRELOAD_VERLIST...OK Writing file 4 of 7: PRELOAD_VER...OK Writing file 5 of 7: PACKAGE_TYPE...OK Writing file 6 of 7: PTABLE_PRELOAD...OK Writing file 7 of 7: PRELOAD...OK Software written 2020-04-28 10:08:58 Writing device finished OK |
now how to bypass frp sir? |
