01-10-2017, 05:12 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Punjab Age: 36
Member: 1298426 Status: Offline Sonork: 100.1603765 Thanks Meter: 266 | my dongle is blocked my dongle is blocked monitoring software dedicated error then blocked now changed pc and unable to found which software is this plz reply asap how to check username |
01-14-2017, 05:13 | #6 (permalink) | |
Member: 1298426 Status: Offline Sonork: 100.1603765 Thanks Meter: 266 | Quote:
01-17-2017, 10:10 | #9 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
