Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-23-2019, 12:21   #46 (permalink)
Member: 2940782
Originally Posted by Namelocked View Post
Credits added back, your mobile does not contain bootloader code.
Can I try again or is it useless? How can I unlock the bootloader without a code?
Old 12-28-2019, 15:29   #47 (permalink)
Member: 2500590
mate 20 pro unlock bootloader support?
Old 01-02-2020, 11:37   #48 (permalink)
Member: 2023196
Thanks Meter: 1,891
No https://www.dc-unlocker.com/android-feature-table
Old 01-30-2020, 00:25   #49 (permalink)
Member: 1855044
lld-l31 FRP bypass failed, credits loose :(
29, 1, 2020 23:51:58
HCU Client v1,0,0,0353
Account: koumeles
Before detection connect cable to usb and enable Manufacture mode !
Qualcomm and HiSilicon: *#*#2846579#*#*
MTK: *#*#14789632#*#*
Windows: ##2846579#
ProjectMenu
1,Background setting
2,USB ports setting
Select Manufacture mode
Erase FRP
2020-01-29 23:51:58,187 Erase FRP start
2020-01-29 23:51:58,519 Reading phone info,,,
2020-01-29 23:51:59,019 Read phone info success!
Model: LLD-L31
Firmware ver,: LLD-L31 9,1,0,127(C432E6R1P4
SN: FPM4C18702004500
2020-01-29 23:51:59,050 Phone info data backup saved to file C:\Honza\MDA\!!!! PC unlock tools\HCU_348\Backup\20200129_235159_FPM4C18702004 500,BAK
2020-01-29 23:51:59,050 Connecting to server,,,
2020-01-29 23:51:59,222 Connected!
2020-01-29 23:52:00,235 Reading Certify data,,,
2020-01-29 23:52:00,378 Erase FRP fail!
Not supported/unknown chipset!
Memo log saved to C:\Honza\MDA\!!!! PC unlock tools\HCU_348\Logs\20200129_235200_HCU_EraseFrp_FP M4C18702004500,txt
Account: koumeles
Credits left: 12
Check success!
2020-01-29 23:56:28,637 Start read phone info from fastboot!
2020-01-29 23:56:29,385 Read phone info done!
Model: LLD-L31
Firmware ver,: LLD-L31 9,1,0,155(C432E6R1P4
SN: FPM4C18518001091
2020-01-29 23:56:29,415 Phone info data backup saved to file C:\Honza\MDA\!!!! lld-l31\HCU\Backup\20200129_235629_FPM4C18518001091,BA K
FB LockState: LOCKED
USER LockState: LOCKED
locked
Battery state: 3927mv
2020-01-29 23:56:38,316 Erase FRP start
2020-01-29 23:56:38,634 Reading phone info,,,
2020-01-29 23:56:39,010 Read phone info success!
Model: LLD-L31
2020-01-29 23:56:39,041 Phone info data backup saved to file C:\Honza\MDA\!!!! lld-l31\HCU\Backup\20200129_235639_FPM4C18518001091,BA K
2020-01-29 23:56:39,041 Connecting to server,,,
2020-01-29 23:56:39,213 Connected!
2020-01-29 23:56:40,194 Reading Certify data,,,
2020-01-29 23:56:40,426 Reading Certify data success!
2020-01-29 23:56:40,432 Signing Certify data,,,
2020-01-29 23:56:53,549 Erase FRP fail!
No response!
Old 01-30-2020, 16:07   #50 (permalink)
Member: 2023196
Thanks Meter: 1,891
Credits added back, Sorry, but Android 8 and later with latest security patches are not serviceable.
Old 01-30-2020, 19:22   #51 (permalink)
Member: 1855044
hcu frp lld-l31
it's not good news...
and will be? i buy credits of dc/hcu, because i read so it's possible to frp unlock.
i have two frp locked lld-l31, for what i use those credits...?
K.
The Following User Says Thank You to koumeles For This Useful Post:
Old 02-04-2020, 12:06   #52 (permalink)
Member: 2466934
Thanks Meter: 54
K.
downgrade with Hisuite (its safe)
and try again.. or inbox me
Old 02-14-2020, 15:31   #53 (permalink)
Member: 2874244
Thanks Meter: 2
When do you add dra-lx5 and y6 2019 for imei repair?
Old 03-06-2020, 22:50   #54 (permalink)
Member: 2672571
Thanks Meter: 3
Why not give eternity to test points?You are far behind other teams
The Following User Says Thank You to Amir bmt For This Useful Post:
Old 02-14-2022, 12:14   #55 (permalink)
Member: 2832748
Thanks Meter: 6
MTK debug port detecting problem
Hello,
new HCU could not detect CDC debug port. After MTK meta mode, the new driver appears (USB Composite Device and Android Adapter PCUI) but could not be detected by HCU client.
Is it drivers problem? The drivers used from DC-Phoenix installation
Please advice
thanks a lot
Old 02-14-2022, 14:17   #56 (permalink)
Member: 2023196
Thanks Meter: 1,891
DC-phoenix has no drivers. Drivers come from hisuite and nowhere else for MTK mobiles.
Old 04-02-2022, 15:58   #57 (permalink)
Member: 797068
Thanks Meter: 75
with HCU is possible unlock NCK huawei mate 20 pro Kirin 980?
Old 04-04-2022, 07:58   #58 (permalink)
Member: 2023196
Thanks Meter: 1,891
Features available for your phone on HCU check here https://hcu-client.com/supported-models.php
Old 04-29-2022, 20:56   #59 (permalink)
Member: 3011998
Can u support no test point method to remove huwaei id for y9a frl l22
Old 05-02-2022, 09:04   #60 (permalink)
Member: 2023196
Thanks Meter: 1,891
Unfortunately, this model is not supported.
Page generated in 0.18775 seconds with 8 queries
