Help me,COL-AL10 Unlock bootloader error. Fastboot provided info: CPU: kirin970 Model: COL-AL10 Firmware: COL-AL10 9.0.0.187(C00E181R1P20) Vendor: all Country: cn MEID: A000008E34AA80 SN: VBJDU18420014289 PCB SN: DU5DYJ184N069282 WIFI MAC: 909497DA8F75 BT MAC: 909497DA7316 Theme color: black Device color: green FBLOCK: 1 Bootloader FB lock: unlocked Bootloader User lock: locked Found signed IMEI: IMEI1: 867551033873435 IMEI2: 867551034032908 IMEI3: 867551034253876 SIM NW_LOCK status: UNLOCKED Found NV data: Modems: 3 IMEI1: 867551033873435 IMEI2: 867551034032908 IMEI3: 867551034253876 PESN: 80FE86F2 MEID: A000008E34AA80 Found OEM data: IMEI:867551033873435 IMEI1:867551034032908 MEID:A000008E34AA80 Model: COL-AL10 Firmware: COL-AL10 9.0.0.125(C00E125R1P18) Rescue: rescue:Chipset-boston 8.1.0.001(0169) Vendor: all Country: cn Version limitation: ON SIMCARDMODE: double Bootloader User lock: locked Phone ID: 5CB767CE11374BA 2023-03-15 16:50:13.113 Repairing... 2023-03-15 16:50:13.519 error - invalid parameter! Memo log saved to |
You can not unlock the bootloader for it on software, you can only read the bootloader code from it via testpoint mode. |
Yes, I can, I changed a phone Unlock bootloader successfully. But often I run into this problem. Fastboot provided info: CPU: kirin970 Model: COL-AL10 Firmware: COL-AL10 10.0.0.182(C00E182R1P5) Vendor: all Country: cn SN: VBJDU18927012863 PCB SN: DU5DYJ189W077244 WIFI MAC: B48655895B1A BT MAC: B4865589379F Theme color: black Device color: purple FBLOCK: 1 Bootloader FB lock: unlocked Bootloader User lock: locked Found signed IMEI: IMEI1: 863381042028308 IMEI2: 863381042203935 IMEI3: 863381042261511 SIM NW_LOCK status: UNLOCKED Found NV data: Modems: 3 IMEI1: 863381042028308 IMEI2: 863381042203935 IMEI3: 863381042261511 PESN: 80F32FF8 MEID: A000009B2D8023 Found OEM data: Model: COL-AL10 Firmware: COL-AL10 9.0.0.181(C00E181R1P20) Rescue: rescue:Chipset-boston 8.1.0.001(0220) Vendor: all Country: cn Version limitation: ON SIMCARDMODE: double Bootloader User lock: locked Phone ID: 562AF81241084C1 2023-03-15 18:58:57.589 Repairing... 2023-03-15 18:59:01.533 Write FB User lock not supported for this model, skipped! 2023-03-15 18:59:01.879 Write partition oeminfo... 2023-03-15 18:59:04.096 Write partition oeminfo success! 2023-03-15 18:59:04.112 Unlocking restrictions... 2023-03-15 18:59:04.158 Unlock restrictions success! 2023-03-15 18:59:04.158 Done! Memo log saved to D:\Tools\HCU_378\Logs |
No, you can not - https://hcu-client.com/hcu-features-by-tp-xloader/ unless your device runs Kirin710 or Kirin980 cpu. |
