huawei jkm-al00 (710CPU) fix not work???help me!!! huawei jkm-al00 (710CPU) fix not work???help me!!! jkm-al00 DownGrade dead!!!!! how can fix????? help me ,thank you!!!! DC Phoenix 0.0.0.107 user:013XXXX Device detected: COM6: HUAWEI USB COM 1.0 (COM6) BOOTLOADER File to update: Kirin710_T1_A8.1_V1 2019/7/22 6:32:16 Starting to write device... Process identifier:17034912 Writing bootloader... Writing Kirin710_T1_A8.1_V1_3.dtwork... Writing Kirin710_T1_A8.1_V1_4.dtwork... Writing Kirin710_T1_A8.1_V1_5.dtwork... Waiting for fastboot device... Device found: 2PF4C19328001584 Looking for a device in fastboot mode Device found: 2PF4C19328001584 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:2PF4C1932XXXX IMEI:86351304XXXX IMEI1:863513XXXXX MEID:A00000A77EXXXX Build number: :JKM-AL00b 8.2.0.186(C00) Model: JKM-AL00b Battery state: 0 OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Software written 2019/7/22 6:33:12 Writing device finished OK DC Phoenix 0.0.0.107 Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 2PF4C19328001584 Detecting recovery partition Current version(CURVER): JKM 9.0.2(CHN) ERECOVERY_KERNEL partition found ERECOVERY_VENDOR partition found ERECOVERY_RAMDISK partition found 2019/7/22 6:36:30 Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: 2PF4C19328001584 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:2PF4C193XXXX IMEI:86351XXXX IMEI1:8635XXXX MEID:A00000A77XXXX Build number: :JKM-AL00b 8.2.0.186(C00) Model: JKM-AL00b Battery state: 0 OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Process identifier:17034942 Getting build number... Getting base version... Getting cust version... Getting preload version... Erasing ver .. . Current version(CURVER): JKM 9.0.2(CHN) Writing rescue_recovery_kernel partition rescue_recovery_kernel partition UPDATE ...OK Writing rescue_recovery_ramdisk partition rescue_recovery_ramdisk partition UPDATE ...OK Writing rescue_recovery_vendor partition rescue_recovery_vendor partition UPDATE ...OK USB Device REMOVAL Type: @oem38.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 2PF4C19328001584 Looking for device in upgrade mode... Process was cancelled by user Cannot enter in Recovey mode Update fastboot mode failed |
Can try fix if detected in fastboot only. If only testpoint, no solution now |
