Huawei p9 lite cant restore STOCK ROM after write factory firmware Huawei p9 lite cant restore STOCK ROM after write factory firmware HUAWEI P9 lite FACTORY FIRMWARE write done File Name: VNS-L21_MAA001022_Factory_firmware_general_Android_6.0 _EMUI_4.1.dgtks Flash Log: Code: The file was loaded successfully |
Stock ROM write done but phone not booting to normal Flash Log: Code: Current version: VNS-L21C185B150 |
Means this stock rom firmware is not for your phone version. |
Metherd 2 also failed Flash Log: Code: 2017-10-24 12:49:40 PM Starting to write device... |
If method 2 failed problem in hardware. |
I HAVE TWO UNITS AS SAME ISSUE 1 UNIT I FLASHED OK DONE 2nd one is acccidently i wrote factory firmware (this phone) |
If after flashing factory firmware phone does not boot up problem is in hardware and no software will fix it. If phone boots up after flashing factory firmware but doesn't after flashing full stock rom then problem in your full stock rom - incompatible with this phone you flashing to and need to find different one. |
can you suggest any ROM builds? |
Sorry, no. Suggesting won't do any good. Need to know specifically. |
