06-15-2019, 06:11 | #1 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | HCU Client Run Error Code: 2019-06-15 10:39:44.475 Checking account 013245FE... 2019-06-15 10:39:44.484 Connecting to server... 2019-06-15 10:39:45.025 Connected! Access denied (for sharing dongle) even after uninstall same error |
06-17-2019, 15:09 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,893 | Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
The Following User Says Thank You to Namelocked For This Useful Post: |
07-10-2019, 17:55 | #4 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Ain el turck Oran
Member: 176231 Status: Offline Thanks Meter: 13 | 019-07-10 15:45:58.227 Checking account mokhtargsm... 2019-07-10 15:45:58.231 Connecting to server... 2019-07-10 15:45:58.668 Connected! Wrong username or password! |
07-11-2019, 14:12 | #5 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,893 | Quote:
06-19-2023, 17:26 | #6 (permalink) |
Junior Member Join Date: Jan 2013 Location: Yemen
Member: 1875667 Status: Offline Thanks Meter: 1 | 2023-06-19 19:06:16.927 Checking account 00B0F60BC6... 2023-06-19 19:06:16.927 Connecting to server... 2023-06-19 19:06:19.521 Connected! Access denied (for sharing dongle) help plz dongle sn 00B0F60BC6 |
06-20-2023, 07:43 | #7 (permalink) | |
Block now removed. If you do not know what service/software on your machine causes this then can only suggest using dc-unlocker from another pc. Note: receiving multiple blocks for the same reason may end up with a permanent block. | |
